06-22-2023, 08:48 PM | #15 |
Drives: 2016 Garnet Red Camaro 2SS Join Date: Sep 2018
Ok guys, I worked for Weights and Measures in Missouri for 10 plus years. Half of that time, I worked in the petroleum lab and was a field compliance inspector. I was the guy that checked all the stations for fuel quality and quantity.
So, for the question about tankers...most of the time there won't be a problem. There is always some sediment present but the pump filtration likely will pick it up. Water on the other hand, can get through the filtration. The fill process will stir up the tank contents. As said earlier, water being heavier will sink to the bottom. Water can get in through faulty fill caps or often times, the caps covering the tank vents are missing. So, for me...if a fill is going on, I pass. Just my $.02..... |
06-23-2023, 07:42 AM | #16 | |
Drives: 2018 Camaro SS1 1LE Join Date: Feb 2017
06-23-2023, 07:54 AM | #17 |
Drives: 2016 1LT 'Vert Join Date: Feb 2022
If it makes you feel better
If it makes you feel better then do what you need to do. I know I've moved on to the next station when a fill was occurring.
But realistically, and for all any one of us really knows, that tanker may have finished it's fill and left the station 5 minutes before you arrived... |
06-23-2023, 08:19 AM | #18 | |
I actually googled into this a bit, and sdf62 probably knows all this. Water in the holding tanks is almost unavoidable in small amounts. Larger amounts suggest ingress. The main problem is tank corrosion in older tanks, which leads to sediment which typically gets caught by the filter. There are fuel/water separators available, but it is up to the facility to decide if they are needed. And none of this makes much difference if the tanker refill of the ground tank is actively stirring things up. |
06-23-2023, 08:49 AM | #19 |
Drives: 2011 2SS/RS LS3 Join Date: Nov 2011
I avoid the station when a tanker is there....not because of bad gas, but for fear of the damn thing blowing up....lol...
06-23-2023, 10:06 AM | #20 | |
The gas station kept selling gas from that pump, all day….while accepting blame for my issue as well as the Audi. |
06-23-2023, 10:13 AM | #21 | |
Drives: 2023 Camaro ZL1 Join Date: Jan 2023
Around my home, I stick to the same stations. As long as no issues, I continue using them. I just came from a 1,500 mile cross country road trip and there were times I just had to use the gas station that was on my way. No guarantees in life, some times you just have to wing it.
2023 Camaro ZL1 6MT Summit White
06-23-2023, 10:29 AM | #22 |
Drives: 2017 Mosaic Bk ZL1 M6 Join Date: Jul 2009
I only gas up between 7:00-8:00 AM on a Saturday unless travelling, and haven't done any of that for almost 2 yrs, so I never expect to see a truck at that time.
06-23-2023, 10:35 AM | #23 |
2018 SS A8 11.85@117.06
Drives: 2018 Camaro SS A8 "Dark Knight" Join Date: Oct 2019
DARK KNIGHT
2018 SS A8 11.85 @ 117.07 GPI Tuned E85 stock tires Roto Fab CAI LT 2 intake |
06-23-2023, 10:40 AM | #24 |
Drives: 2016 Camaro 2SS Join Date: Jun 2016
Just thinking . . . if gasoline is drawn out of reservoir tank that is underground, wouldn't it be pumped from the bottom of the reservoir? I wouldn't expect it to be taken from up higher. So if it is taken from the bottom of the reservoir, and water is denser than gasoline, wouldn't it be more likely to have water pumped out if the reservoir is 'quiet'? Would it mean you would be less likely to get water when the contents being moved around when new fuel is being added from a tanker truck?
06-23-2023, 12:09 PM | #25 | |
Drives: 2020 Camaro 2SS A10 Join Date: Jun 2018
Last I heard the gas station paid for repairs and compensation for those people. So even if sediment isn't an issue might be good to wait a day just in case.
2020 Camaro 2SS A10 | Rebuilt by: CBI Street Cars | 2" SE LT Headers | 3" SE X-Pipe | 3" MBRP Axle-Back | Pri & Sec Cat Deletes | K&N Typhoon CAI | LT2 Ported | 95mm ZR1 TB | DOD Delete | BTR Stage I Cam | ECM, & E85 |Tuned by: Shane Hinds | Dyno: 510 rwhp 472 rwtq
