dave@hennessey
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > Camaro ZL1 Forum - ZL1 Specific Topics
Old 12-18-2022, 01:02 PM   #1
ta406
Drives: Chevy Camaro
Oil pump change out
I have a 2013 ZL1 that I am going to change out my oil pump this winter. For those of you that have replaced the oil pump only, did you remove the radiator? Looks like it may be a little easier but is it worth the extra work?
Thanks
ta406 is offline   Reply With Quote
Old 12-22-2022, 04:04 PM   #2
Triple5even813
Learner of things
Drives: 2013 ZL1 M6 coupe, black
Thanks
Definitely not worth the extra work IMO
2013 M6. Cammed, straight piped, 17# boost, E85. Tuned by CHenry Motorsports. 825rwhp @ 6450, 812 rwtq @ 3500. Stock unported blower, stock heads, stock bottom end, stock throttle body. Boost only, no meth, no nitrous
Triple5even813 is offline   Reply With Quote
Old 12-22-2022, 04:57 PM   #3
FasNuf
FasNuf's Avatar
Drives: 2014 Camaro ZL1
Wow, can't image what a PITA it would be to do with all the junk in the way, especially dealing with the pickup tube and that oring.
FasNuf is offline   Reply With Quote
Old 12-22-2022, 05:30 PM   #4
tartagliazl1
tartagliazl1's Avatar
Drives: 2013 zl1 vert
yes remove the radiator it 15 minutes of more work. you will need the extra room to work.
its not that hard.
22% lower/ 2.5 upper/ 2” headers/ cat delete/ x-pipe/ 2 gallon x tank/ 100-3 pump/ fic 850/ dsx aux kit/ 103mm throttle body/ RPM 5” intake/ meth kit/ prometh lid injection/FI interchiller/ 160* stat/ ngk-7/ msd wires/ elite catch can/ tsp cam/ Che trunnions/ ported supercharger/ 1/2” lid spacer/ brick mod/BMR toe and trailing arms/ 751hp 757 tq SAE @17.3lb on a loaded dyno.
tartagliazl1 is offline   Reply With Quote
Old 12-23-2022, 06:36 AM   #5
LevonH
Chevy Enthusiast.
Drives: 2015 Camaro ZL1 Summit White
Why are you changing it?
Levon H. Bone Stock
LevonH is offline   Reply With Quote
Old 12-23-2022, 08:30 AM   #6
brick59
Sucker Punch
brick59's Avatar
Drives: 2013 Black ZL1, 2007 Silverado LTZ
Defiantly remove the radiator you're going to need the room to work, if a wrench or something slips and you punch a hole it you'll you'll be removing it and replacing it anyway.
427 Dart SHP Pro LS Block, Callies Magnum Crank, Callies Ultra I Beam Rods, Diamond Pistons, AGP twin Turbos 6865, Mast heads, Cam Motion LLR cam, Morel tie bar lifters, Crower roller rockers, NW 103MM TB, ID2600 XDS, Fore Triple, DSX, E85, ARH Turbo Headers, Corsa, Jakes stage 5 4L80, Circle D, RPM Roll Bar, BMR, Carlyle Racing 15" conversion kit.
brick59 is offline   Reply With Quote
Old 12-24-2022, 01:13 PM   #7
ta406
Thanks everyone. I am concerned about my oil pressure being around 50 psi at 6500rpm. After some research, I'm going to also drop the pan and plug the relief valve (watched FasNuf's youtube video on it) and may just shim the stock LSA pump. By all accounts, the LSA pump seems to be very reliable and only the Melling 10355HV is any "improvement". I'd really like to see closer to 60-70 psi at 6500rpm with 5w-30 oil.
Old 12-24-2022, 01:31 PM   #8
tartagliazl1
What’s your plan on dropping the oil pan? Cut the crossbar or lift the motor? I’d be more worried about that than the radiator.
Old 12-24-2022, 03:01 PM   #9
ta406
Probably cut the crossbar. Either way looks like an ass ache
2013 ZL1. Automatic, ported blower, meth, E85, 2" headers, 3" exhaust, BTR stage 3 cam, NW 103 TB, 5" CAI
Old 12-24-2022, 09:36 PM   #10
ZMEnow
Drives: ZL1, 2013, tri-coat-red, manual
If you haven’t upgraded the valve train and are consistently hitting 6500 you won’t need to worry about oil pressure in The future..
ZMEnow is offline   Reply With Quote
Old 12-24-2022, 09:38 PM   #11
FasNuf
FasNuf's Avatar
Got a video to help out.
https://youtu.be/2iqekORDMu8
Either way you slice it, the pump is a pain. I've done it in the engine and then later did the Melling HV by pulling the pan completely and doing the PRV at the same time. It was a lot more time to do the crossmember and pull the pan, but I had a ton more confidence that the oring was installed correctly. Some may say it's not necessary, but align the pump when you install it. I've often thought it wasn't absolutely necessary, but is great peace of mind that none of the parts are touching inside.
Old 12-24-2022, 11:44 PM   #12
ta406
I picked this car up last summer so there are still issues that need to get taken care of. I just picked up a CHE trunnion kit.
Old 12-24-2022, 11:50 PM   #13
ta406
I appreciate the input. I’ve built a lot of small block chevy’s in the past (pretty new to LS’s) and am a stickler when it comes to little details like that. Aligning the pump is definitely on my checklist.
