11-12-2022, 04:35 PM | #1 |
Drives: 2012 Camaro 1LT RS Join Date: Feb 2022
Check left turn signal
All, last night after getting off work, I was pulling out and my left turn signal was blinking real fast and the dash display said to check the left turn signal. The right one was find. I have not replaced these bulbs or messed with them whatsoever in the year I've had the car, and this has never happened. Any advise will be greatly appreciated!
11-12-2022, 04:40 PM | #2 |
Chevy Enthusiast.
Drives: 2015 Camaro ZL1 Summit White Join Date: Jan 2019
Bulb burned out. Front or rear.
Levon H. Bone Stock |
11-12-2022, 05:29 PM | #3 | |
Drives: Chevy Camaro SS 2010 Join Date: Aug 2022
Sequential Signals ?
11-12-2022, 05:59 PM | #4 |
I'll try replacing the bulbs, and no, I have not gotten a car wash as of recently. It did rain the other night, and I did notice some water in the trunk which was odd, so maybe some water snuck into the taillight housing?
11-12-2022, 06:19 PM | #5 |
2&THEHIT
Drives: 5th Gen Camaro; 5th Gen Ram 3500 Join Date: Mar 2018
If it's flashing fast then you need a new light. It's not hard to get to, just pull up the 3 plastic fasteners that cover the triangular piece covering the lights. then spin the bulb harness to get the bulb out of the lens
11-12-2022, 07:21 PM | #6 |
Water in the trunk could be the sunroof drain tubes came disconnected...if you have a sunroof. Located in both sides of upper trunk area.
11-12-2022, 11:12 PM | #7 |
Thanks! I will definitely replace the bulbs. And I do not have a sunroof, unfortunately. Its possible I just forgot to shut it all the way, and it rained that night. Not likely, but possible. Thanks for the input everyone!
