Vararam
View Poll Results: Which valve springs
BTR SK001 (.660" LIFT PLATINUM DOUBLE SPRING) 13 61.90%
PAC 1904 (.650" LIFT DOUBLE SPRING) 1 4.76%
PAC 1218 (.600" LIFT BEEHIVE) 7 33.33%
Voters: 21. You may not vote on this poll
Old 11-23-2018, 10:33 AM   #15
SSMY1LE
SSMY1LE's Avatar
Drives: '14 1LE RS NPP Recaro
This cam has really worked well, incredible difference from stock with just headers, tune and CAI.
Made 486 at the wheels without all the "drama" in the valvetrain.
Just thinking about a better spring than the stock ones.
'14 1LE, Recaro, Cammed, Headers, Hi Flows, CAI, Tuned, 486 RWHP
https://www.youtube.com/watch?v=H57UfKCO0EY&feature=youtu.be
SSMY1LE is offline   Reply With Quote
Old 11-23-2018, 02:51 PM   #16
eLeSthree
Drives: 2011 Camaro SS 6sp
Hows your parking lot behavior? Id say the only negative to this cam is the 110. Combined with my mcleod rxt hd clutch, its become bothersome.
2011 Camaro SS---SOLD
TMS Dart 427 FED M311s, ESS Tuning G4 Blower, DSX Triple FP Assembly, DSX FF, FIC1300, Mcleod RXT 1200HD, Edlebrock Pro Flo XT
1158whp 1017wtq.
2010 CTS-V A6 - "Stock" SOLD
630whp 658wtq
2024 F-150 RCSB 5.0 4x4
waiting for tunes...
eLeSthree is offline   Reply With Quote
Old 11-23-2018, 07:00 PM   #17
John_C
LSx FTW!!!
John_C's Avatar
Drives: 2010 Camaro 2SS RS
Texas Speed has a TSP Polished PAC .660 spring.
https://www.texas-speed.com/p-5704-t...-seatseal.aspx
I've run it for 10k miles so far with no issues. I have TFS GenX 255's with the TSP 1.72:1 roller rockers that makes my TSP VVT 3.2 cam Intake Valve Lift .657 and I rev to 6,800 to 7k rpm's frequently.
2010 2SS RS A6 781rwhp on E85
Stage 2 ProCharger D1X
Circle D 3400 Triple Disc
Kooks Jet Hot Headers
Kooks Full 3in exhaust
Trick Flow GenX 255's
Polished PAC .660's & Ti-retainers
TSP VVT 3.2 cam kit w/DoD Delete
Smith Bro's Trunnion kit
AEM X-Series OBDII Widebands
FIC ID1300x Injectors
GM ZL1 High Output Fuel Pump
DSX Tuning Flex Sensor
DSX Auxiliary Fuel System
Tim King Stage 4 Max Effort CTSV 6L90
DSS 1 piece aluminum driveshaft
JRE 6L80E / 6L90E Dipstick
NGK Iridium IX spark plugs #7 heat range
Mighty Mouse Camaro 5 Wild w/-12an and Billet Black
HP Tuners VCM Suite
John_C is offline   Reply With Quote
Old 11-24-2018, 05:17 AM   #18
SSMY1LE
SSMY1LE's Avatar
Slow speed is actually not bad, similar to stock. My tuner did a great job getting it to behave.
Old 11-24-2018, 05:29 AM   #19
SSMY1LE
SSMY1LE's Avatar
Wow you are brave, running .657 lift with .660 springs !
How's the piston to valve clearance ?
Old 11-24-2018, 12:49 PM   #20
christianchevell
old school chevy rodder
christianchevell's Avatar
Drives: 2013 2SS/RS Manual,DM exhaust,CRT
Actually he's over that lift with 1.72 ratio rockers not 1.7 too btw... Some people like to get the springs close to what they will be used at but for most its not so...…...And glad I have the Monster lt1s clutch, people have complained about the Mcleod stuff once to many times I have read, and I "heard" one clunking before in a vette, a sound I would not tolerate. No rattle here...….like stock. and 700 hp duty dual and $$$ wise using stock slave and their billet bearing support. But hey the Happy Dyno there of the ASA cam is just that, been around..... but hey its good cam, though I got with about the exactly same mods on a load bearing Mustang dyno tuned by the best around here 491 hp and 448 torque off the TSP cam 235/239 back when it had .639 and .623 lift and 110 LSA and he thought it was exceptionally good being with dual mode exhaust and electric power steering ...also.
It came out higher than the Night fury cams readings as it speced out higher in lift etc.... But hey Dynos are just measuring devices a tool for further mods, dyno jets more happy.... TSP still sells the 235 /239 cam though they reworked the intake lift as the .675 springs were as the higher lift springs are more brittle the higher you go and they could have gotten by with lessor springs and do now...…...from people who broke them having input back into TSP and its cool. Getting springs for far in excess of the lift you need will only result in a noisier valve train IMO and I know...…and increase the drama Good Luck.
christianchevell is offline   Reply With Quote
Old 11-26-2018, 03:29 PM   #21
SSMY1LE
SSMY1LE's Avatar
So I contacted Howards Cams and they suggested these:
HOWARDS CAMS 98113-K1
I'll probably go this route, thanks for all the help.
See ya again at CF9 in July
Valve Spring Series:
 Beehive
Style Of Spring:
 Beehive
Outer Overall Diameter:
 1.280
Outer Inside Diameter:
 1.035
Inner Overall Diameter:
 .900
Inner Inside Diameter:
 .650
Damper:
 No
Closed Pressure:
 115 @ 1.800
Open Pressure:
 332 @ 1.265
Rate:
 412
Max Lift:
 .600
Coil Bind:
 1.150
Retainers Included:
 Yes
Retainer Material:
 4140 Chrome Moly
Valve Locks Included:
 Yes
Valve Lock Style:
 8mm
Number of Grooves:
 Bead Lock
Valve Lock Material:
 Alloy Steel
https://www.howardscams.com/beehive-...-cams-98113-k1
Old 11-26-2018, 09:14 PM   #22
eLeSthree
I think thats a good move. You cant go wrong using exactly what the cam manufacturer recommends. Funny that the pole results show the most popular brand as the winner regardless of the cam makers spring recommendations.
1158whp 1017wtq.
630whp 658wtq
Old 11-27-2018, 08:57 AM   #23
acammer
GPI Sales Consultant
acammer's Avatar
Drives: 2011 Camaro 2SS SGM
I think the pole is probably based on those BTR Platinums having such a good track record in so many applications. I also think many people are skimming right past the relatively modest lift specs on this cam. Agree with the above - go with what your cam manufacturer recommends!
GPI Max Package 2.0: Brodix BR7 heads/GPI porting, MAX3 cam, ST2116LSR, BSR Max Lift rockers, LS7 LSXR with 103mm TB, Vararam OTR, Mcleod RXT, G-Force/Strange 9" IRS setup with 4.63 gear. 551whp, 11.1@124mph.
Got a question about a GPI product? Feel free to shoot me a message!
acammer is offline   Reply With Quote
Old 12-04-2018, 10:41 PM   #24
johnnyb305mia
Drives: 2015 Camaro SS 1LE
I have the same Howard’s cam. Car made great power. What’s everybody getting numbers wise out of this cam. I’m probably going to be sending my heads off to Texas Speed to get them ported as well as put some new valve springs, lifters, and trays while they are off. The thought of switching it up to a custom cam has come across mind. But the set up we have works really well. Just looking for a lil more on top of what we currently get. Still has stock TB, and Stock IM as well.
johnnyb305mia is offline   Reply With Quote
