06-06-2016, 11:40 AM | #1 |
Another Oil Pressure Thread - "OIL PRESSURE FILTER"
So I found out today that the LS 3 has an "OIL PRESSURE FILTER - Dorman# 917-143" (GENERAL MOTORS #12585328)
Could this be something that has been causing all these oil pressure issues ?? I haven't had any issues yet but it is always in the back of my mind. Product description describes as "Save time and money with Dorman's Engine Oil Pressure Filter. Now, you can replace just the failed filter screen instead on the entire assembly. Also, this direct replacement part restores proper oil pressure to prevent engine damage." - Screens engine oil before the oil pressure sensor Reduce Repair Cost - Replace the failed filter instead of the entire assembly - See more at: - See more at: http://www.dormanproducts.com/itemde....Hh1bvSeW.dpuf Anyone ever replace this ??
'14 1LE, Recaro, Cammed, Headers, Hi Flows, CAI, Tuned, 486 RWHP
https://www.youtube.com/watch?v=H57UfKCO0EY&feature=youtu.be |
06-06-2016, 11:50 AM | #2 |
Drives: ‘13 1LE Join Date: Jul 2013
Nice find!...I didn't know this part existed either, subscribed.
06-06-2016, 12:15 PM | #3 |
The BBOMG fill-in husband
Drives: 2015 2SS/RS 1LE AKA V1LE Join Date: Aug 2010
UPSTATE C5 MEMBER
06-06-2016, 12:17 PM | #4 |
By the way, I noticed my dorman brake/clutch reservoir cap is leaking just like factory, had it on there for about 8 months now, wtf?
UPSTATE C5 MEMBER
06-06-2016, 02:42 PM | #5 |
Drives: '15 SS 1LE, '69 Z28 drag car Join Date: Dec 2009
That's the valve lifter filter. Sits under the oil pressure sensor. Filters oil before going to the AFM valley manifold.
If an engine's AFM is acting screwy or setting codes, the service manual has you check and replace that filter. Has nothing to do with anything else. If you want to protect your pump and pressure relief valve from debris.... use a magnetic drain plug, a filter mag, change oil/filter often, cross fingers. That screen is protecting the AFM system and lifters from getting debris in them. |
06-06-2016, 07:23 PM | #6 | |
06-06-2016, 07:26 PM | #7 | |
Drives: 2012 M6 Camaro SS (RIP) Join Date: Nov 2014
I'm pretty anal about my oil changes, but it does appear to be a luck of the draw thing. 55K miles of smiles and acounting |
06-07-2016, 12:06 AM | #8 |
thats a replacement oil pressure sensor filter. It comes stock under the oil pressure sensor. The stock one can be cleaned. if you loose oil pressure on the gauge but not the engine sometimes its this filter clogged. All you have to do it clean it with soap and water. brake clean might damage the plastic.
06-07-2016, 11:14 PM | #9 | |
Master ASE, GM, LSX Tech.
Drives: 2010 Camaro SS Join Date: Oct 2012
This filter never came on the LS3. This filter came from GM on the 2007-2011 5.3L LC9, LMG, LH6, LY5 Engines, also on the 6.0L L76.
2010 2SSRS A6, Custom Pat G. Cam, WCCH Cylinder Heads, Kooks Headers/Exhaust, BTR Valvetrain, Fluidampr 25% UDP, All Engine ARP bolts, Flex-a-lite radiator/Trans cooler, Yank converter, PFADT Suspension, ADM Race Intake/Scoop, Torq tow hook, CFD auto shifter, Dynojet AFR gauge, Aeroforce scan gauge, Brake Performance rotors/pads
Prothane bushings, ZL1 wheels, spoiler, Z/28 wickerbill, 1LE Aero/Suspension Package, Anderson Composites COPO Carbon Fiber Hood, LED lighting, Elite Catch Can, Improved Racing oil pan baffle, crank scraper, windage tray 480 RWHP 452 RWTQ + Nitrous Express 150 Shot |
06-14-2016, 01:00 AM | #10 |
06-14-2016, 08:11 AM | #11 |
i'd consider it misinformation if the OP stated it as a fact, but instead the OP was merely asking a question.
2011 Camaro 2SS/RS, Circle D 3200, ADM Transmission Cooler, BTR Valvetrain, Cam Motion .621 .595 228/244 113+4, ARH 1 7/8 full exhaust, Cold Air Inductions, Katech C5R TC, Melling HV, BTR SLR lifters, Trunion Upgrade, LS2 Dampner, LS9 head gaskets, Bo White PTB, MM can, GFX, Subs, B&M Deep transmission pan,
Holley fuel rail, Proform valve covers, relocated coil packs |
06-14-2016, 02:10 PM | #12 |
[QUOTE=LSX Camaro;9138309]More Misinformation spread by the ignorant.
QUOTE] Really ?? I would hardly say I was "spreading misinformation" Simply asking if anyone had heard of this filter before. It was a GM Master Tech that had mentioned it to me, dont know the guy personally but I would say he is even more misinformed than me if he works there. I think you would be better off venting your distain his way. So sorry to waste your time with my ignorance. I guess if we were all GM Master Techs we wouldnt need this forum, or maybe we would hmmmmm
06-14-2016, 02:20 PM | #13 | |
Drives: 2015 SW 1SS/RS 1LE Join Date: Mar 2015
http://www.gmpartsgiant.com/parts/gm...-12585328.html
“The Eagles and the Captain and Tennille ruled the airwaves, and we were the answer to it.” - Joey Ramone
06-14-2016, 02:32 PM | #14 |
that doesnt say LS3 or L99. I bet its for the L99. the op has a LS3
