07-08-2016, 05:30 PM | #29 |
Drives: 2013 1SS 1LE Join Date: Jun 2016
Resurrecting this thread. Anyone else go with this cam? This sounds like exactly what I'm looking for. Howards is like 35 minutes from me. Maybe they will let me pick one up?
10-10-2017, 04:01 PM | #30 |
SS
great read also thinking this would be a good cam to help level the field with wifes 17 1le
CCW sp16a track set, BTR stage 3 cam and kooks longtubes with high flow catsLocks@7.5 degrees castor and radius arm inserts, Ride Tech 2coilovers JDP upper control arm bushings BMR lower knuckle bushing Bo White throttle body3.91 gears Spohn del-sphere toe link and trailing arms Prothane subframe bushings
10-10-2017, 04:45 PM | #31 | |
SS
10-11-2017, 11:49 AM | #32 |
Drives: 15 Camaro SS Join Date: Jul 2016
sub
10-29-2017, 09:26 PM | #33 |
Very nice jobl I've looked at bigger cams also, but don't want to give up low end torque. I bet the TC kicks on and off all the way into 3rd
10-30-2017, 08:50 AM | #34 |
Drives: 2015 Camaro 1SS L99 Join Date: Apr 2016
So this thread was brought back from the dead, but I will try anyways. Does anyone know if the OP was running this cam on the stock converter or did he install something like a 2800 or 3200 stall? I guess that question could also be, does anyone know if the GM performance cam hes referencing requires a stall?
10-30-2017, 09:17 AM | #35 |
'It's an experiment'
Drives: [COTW 2/09/15] '11 GPI LSA SC Z/LE Join Date: May 2014
1LE is an M6 (manual) so no automatic. You’d need a VVT version or, a DOD/VVT delete kit and a tune to remove VVT/DOD — Basically an LS3 conversation...
-Don
747 RWHP 794 RWTQ
"Horsepower sells cars, torque wins races." - Enzo Ferrari See My Build: http://www.camaro5.com/forums/showthread.php?t=385577 |
11-01-2017, 02:14 PM | #36 |
ALWAYS-N-BOOST
Nice -
2012 1LS M6 Black-Sold 2013 2LT M6 BluRay- Sold 2015 1SS 1LE M6 Black-Sold 2021 ZLE A10 Riverside Blue - Awaiting Arrival 01/10 |
10-01-2019, 09:20 PM | #37 | |
Drives: 2015_1le Join Date: Apr 2014
Good stuff! How's the motor holding up? I plan to get some work done at AGP in the spring, and I've got the '15 1le, stock right now... planning to do the same mods that you've done. |
10-07-2019, 03:18 PM | #38 | |
I upgraded the springs to the ones Howard's recommends as well as the trunion upgrade to the brass bushings. Both was done just for peace of mind not because there was anything wrong.
'14 1LE, Recaro, Cammed, Headers, Hi Flows, CAI, Tuned, 486 RWHP
https://www.youtube.com/watch?v=H57UfKCO0EY&feature=youtu.be |
10-07-2019, 07:34 PM | #39 |
GPI Sales Consultant
Ever get the car to the drag-strip. I would be interested in the ET and MPH you make with that setup.
GPI Max Package 2.0: Brodix BR7 heads/GPI porting, MAX3 cam, ST2116LSR, BSR Max Lift rockers, LS7 LSXR with 103mm TB, Vararam OTR, Mcleod RXT, G-Force/Strange 9" IRS setup with 4.63 gear. 551whp, 11.1@124mph.
Got a question about a GPI product? Feel free to shoot me a message! |
