View Poll Results: What brand of transmission and resr end fluid for your 1LE | |||
Redline | 24 | 36.92% | |
Royal Purple | 12 | 18.46% | |
MTL | 2 | 3.08% | |
OEM | 14 | 21.54% | |
Something else | 13 | 20.00% | |
Voters: 65. You may not vote on this poll |
Thread Tools |
02-27-2015, 01:24 PM | #15 | |
Drives: '16 C7 Z51 Join Date: May 2012
With -140 oil, diff might also run a little bit hotter ironically due to diff being more operational during the whole session (and having more friction during operation), but I am honestly not sure what would be the impact on overall temps. The thicker oil might also help take heat away from the clutches. That diff cooler kit (from Z/28) comes to mind as an excellent companion : )
'16 Corvette C7 Z51 1LT (Build Thread)
'14 AGM 1SS 1LE [COTW 11/17/14] (Build Thread) (SOLD) '13 Mazda MX-5 Club (Build Thread) '17 RAM 1500 Crew Cab 4x4 Night Edition '15 Nissan Rogue S AWD |
02-27-2015, 01:34 PM | #16 | |
Drives: 14 1LE Join Date: Mar 2013
LMS Engineering
02-27-2015, 08:00 PM | #17 | |
Drives: 2011 Boxster Spyder (best car ever) Join Date: Aug 2014
02-27-2015, 08:57 PM | #18 |
I've been happy with Motul RBF600. If I run into issues, instead of switching to SRF, I'd try to upgrade the brakes and cooling first, since fluid is not the only component badly impacted by very high temps in the brake system.
02-27-2015, 09:14 PM | #19 |
I boiled the motul too.......putting cooling ducts and castrol in this weekend. Interesting enough X25, I have decided I like the 4 piston setup with aggressive carbotech's over the 6 piston zl1( with eagle f1's on the car) setup. They do generate a lot more heat though...
02-27-2015, 09:19 PM | #20 |
Drives: ‘13 1LE Join Date: Jul 2013
I accidentally voted MTL slip of the finger really, , so please subtract 1 from it, because I really wanted to vote Redline, thinking MTL was an other brand or something, (mind you, I do plan on using a lil' Redline MTL in my tranny), but then I was like wait! He really did mean "Redline" MTL, but then realized who in their right mind would use Redline MTL in their diff ???
Sledge and I disqualify this pole!!! |
02-27-2015, 09:24 PM | #21 | |
This ride never sees winter or rain for that matter, and when its driven, it's driven hard, so it almost makes no sense at all, for me to be using 100% D4. |
02-27-2015, 09:45 PM | #22 |
Master ASE, GM, LSX Tech.
Drives: 2010 Camaro SS Join Date: Oct 2012
Redline makes a fantastic product. I have been using it for over 20 years in various vehicles/boats with great success. I would recommend that you switch to their 5W40 motor oil. Servicing all the fluids will ensure a long life for your Camaro.
2010 2SSRS A6, Custom Pat G. Cam, WCCH Cylinder Heads, Kooks Headers/Exhaust, BTR Valvetrain, Fluidampr 25% UDP, All Engine ARP bolts, Flex-a-lite radiator/Trans cooler, Yank converter, PFADT Suspension, ADM Race Intake/Scoop, Torq tow hook, CFD auto shifter, Dynojet AFR gauge, Aeroforce scan gauge, Brake Performance rotors/pads
Prothane bushings, ZL1 wheels, spoiler, Z/28 wickerbill, 1LE Aero/Suspension Package, Anderson Composites COPO Carbon Fiber Hood, LED lighting, Elite Catch Can, Improved Racing oil pan baffle, crank scraper, windage tray 480 RWHP 452 RWTQ + Nitrous Express 150 Shot |
02-28-2015, 11:39 AM | #23 |
Drives: 2014 Camaro Red Hot 1LE NPP Recaro Join Date: Jun 2014
When I purchased my TKO Tremec's for projects I alway used GM Syncromesh from the dealer, it ain't cheap, but I never had the knotchy feelings other people always felt.
For the rear I have always used the royal purple |
02-28-2015, 11:46 AM | #24 |
Drives: bicycle Join Date: Jun 2014
02-28-2015, 01:50 PM | #25 | |
Drives: 2013 Camaro 1LE Join Date: Jul 2012
I would think that the 6 piston set up with the same carbotech pads would be even more aggressive than the 4 piston set up due to the increased pad size.
02-28-2015, 02:11 PM | #26 |
02-28-2015, 02:41 PM | #27 | |
However regarding engine, I'm actually more comfortable using Amsoil's group lV type of engine oil, as opposed to Redline's Group V for my type of driving and use, and I emphasize the latter. However, if I was going all out racing on a road course, with TT mod, just basically ALL OUT, then I would instantly switch over to a Redline Race series for the event. The Group V race formulated package makes perfect sense to me here. |
03-01-2015, 02:23 AM | #28 |
Drives: One of the baddest handling Gen 5s Join Date: Feb 2011
TREMEC TECH TOLD ME TO USE MOBIL ! ATF FLUID. THEY TESTED THESE TRANSMISSIONS WITH THIS AND RECOMMENDED IT.
