08-26-2020, 12:51 AM | #15 | |
Drives: 2014 1le 1SS CRMT Join Date: Apr 2014
From the same place I only know this cause when i looked at the Ebay link you provided It says already delivered And i only paid $225 or something close to that for all 4 Great deal |
08-26-2020, 06:07 PM | #16 |
Drives: Camaro Join Date: Jun 2020
I bought these for the front https://www.ebay.com/itm/Wheel-Hub-B...72.m2749.l2649 but I still can't find the rears for a auto v6. No one seems to list any difference between manual v6 and auto that I can find.
08-30-2020, 09:36 PM | #17 |
Its hard trying to find a clear answer but it looks like these SKF BR930555 only fit Z28 and ZL! with perf package. So I bought 2 9lb paper weights.
08-31-2020, 07:28 AM | #18 |
I'm pretty sure that the fit of all the hubs are the same. Some of them are maybe(?) stronger than others but the Z/28-ZL1 should be the strongest.
08-31-2020, 11:15 AM | #19 |
I'll try them and see if they fit.
09-01-2020, 03:23 PM | #20 |
Both bearing were bad right out of the box. They are SKF brand but they both turn terribly rough. No way you could use them.
09-01-2020, 03:55 PM | #21 |
Mine are skf brand and seem for be fine
Finger crossed |
09-01-2020, 08:02 PM | #22 |
Unfortunately looking around the net I found others that experienced the same thing. I believe that is why these are dirt cheap.
09-01-2020, 08:49 PM | #23 |
Weil i installed them in the front and waiting on my rear differential to be fixed
Then ill do them in the rear And if i do find a problem Ill switch them out spring time Because I don’t drive her in the winter |
09-02-2020, 11:47 AM | #24 | |
Drives: 2010 Turbo LS3 Join Date: Dec 2009
I run the SKF BR930555 bearings in my SS, and they are physically interchangeable, but the SKF BR930555 bearing has a visibly thicker flange. Not sure if they can be used in a V6 auto.
2011 Vert - 416/w 230/236 .612/.602 115lsa, 1LE suspension w/32mm rear bar. Z28 diff. ZL1 brakes. Last edited by CamaroCracka; 09-02-2020 at 12:29 PM. |
09-02-2020, 07:16 PM | #25 |
Yep both HITCH to a stop when trying to rotate them. Both are marked SKF in the casting. I tried rotating them by hand for a bit and they did smooth out some but you can feel they are not smooth like they should be. When I change pads I'll check them out size wise.
03-21-2023, 12:00 AM | #26 | |
Drives: 2010 Camaro SS Join Date: Sep 2020
All bearing are stiff at first. They smooth out after. SKF bearings are suppose to be top notch. I bet there better than an over heated Oem bearing that's very stiff to turn. Amy updates on these SKF hubs?? |
04-21-2023, 03:05 PM | #27 | |
Any updates on these hubs. There are ton of the hub, they look just like z28 hubs AC Declo brand??? |
Tags |
help me, hub, suspension, wheels |
