#267 |
![]() ![]() Drives: 2016 Camaro SS Join Date: Sep 2018
#268 |
![]() ![]() ![]() ![]() Drives: 2017 Camaro 2SS A8 Join Date: Aug 2018
2017 Chevy Camaro 2SS A8 Whipple 8.00/3.25, Mast Motorsports Black Label LT1 heads, CamMotion custom blower cam, Katech VVT & AFM delete covers, Rotofab Big Gulp, Katech 103mm TB, DW400 in tank pump w/JMS, Johnson 2110R lifters, GPI forged pistons & rods, LT4 HP fueling, AWE Touring CB, GForce 3.5” DS, GForce Outlaw axles, 2” ceramic coated Dynatech headers, MM Wild CC, LPE check valve, everything BMR makes, OEM 1LE wheels (street), Forgestar D5 bead locks (track)
2019 Toyota Sequoia Limited 4WD (daily driver) 2018 Alfa Romeo Giulia Ti Sport Q4 (hers) |
#269 | |
#270 | |
Old badass
Drives: 14 Sierra, 16 Sierra, 16 BMW X6 Join Date: Mar 2020
#271 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2016 1SS NFG A8 Join Date: Aug 2017
LT4 heads are for sure better then LT1. They are rotocast aluminum which is stronger and also have stronger titanium intake valves. I also believe they seem to have less core shift issues but I will admit I haven't really seen a lot of info posted about using them as a upgrade for LT1 cars. Part of that could be due to the different intake bolt pattern.
2016 NGM 1SS A8
Options-[2SS Leather/NPP] Perf. mods-[Whipple 2.9/LT4-LPE-JMS Fueling/LT5 TB/Rotofab Big Gulp/Flex Fuel/CA ORP/FM NPP Axle back] |
#272 |
![]() Drives: Turbo 6.2 Join Date: Feb 2019
Katech called letting me know they have to add additional options to my purchase like valve seals and valve reconditioning which is:
-Wire wheel valves -Polish valve stems -Measure valve guides -Machine valve face The katech head job is now up to $650. I received the motion race works catch can, valve cover breathers and oil scavenge pump. I tore down and cleaned the VR1100 to a short block. This thing looks beautiful. I keep looking at this VR1000 cam and telling myself to sell it to someone with a procharger and buy a custom turbo cam. When cleaning the oil pan, I found something interesting about my oil return set up. I'll get some pics when I get back in the garage to help explain it.
2016 Turbo Camaro - 808hp/856tq
2018 LTZ Z71 Redline Silverado - 381hp/420tq Last edited by Choda; 12-06-2020 at 11:29 AM. |
#273 |
Turbo oil return into the pan update.
https://youtu.be/XMCfDv2KFtI Found it, its for a ctsv pcv system. I wonder how its hooked up from the factory. Almost like constant drain for a catch can https://www.gmpartsdirect.com/oem-pa...-tube-12670602
2018 LTZ Z71 Redline Silverado - 381hp/420tq Last edited by Choda; 12-07-2020 at 08:52 AM. |
#274 |
Old badass
Posted on TSP now.
DISCLAIMER: There is a known issue with factory GM LT cylinder head castings causing the factory valve seats to fall out. A valve seat failure will result in a damaged head and possibly a catastrophic, irreparable engine failure. It is common enough to warrant discretion when using factory GM LT cylinder head castings. Texas Speed and Performance assumes no liability in regards to this issue since it is a factory defect. Due to this, we highly recommend purchasing a set of our aftermarket LTx cylinder heads. |
#275 | |
#276 |
![]() ![]() ![]() ![]() ![]() Drives: 17 SS a8 Join Date: Feb 2010
And then you have some broken exhaust valves like I had that took out my motor. I am hoping the 5.3 heads do not have the same issues. If I was doing an lt I would either do a set of stock lt4 heads or some aftermarket heads.
760 rwhp at 11psi, 6.48@113 1/8th mile, stock motor
1096 rwhp at 22psi, 5.94@122 1/8th(18psi), 9.19@155 1/4(20psi), drop in rods and pistons Twins build http://www.camaro6.com/forums/showthread.php?t=465472 |
#277 | |
Sent from my SM-N986U using Tapatalk |
#278 | |
#279 |
I believe Katech can drill them to accept a LT1 intake manifold.
2016 NGM 1SS A8
#280 |
Thread Tools | |
