View Poll Results: Who has experienced an oil pump failure? | |||
2016 or earlier | 20 | 13.79% | |
2017 | 53 | 36.55% | |
2018 | 67 | 46.21% | |
2019 | 2 | 1.38% | |
2020 | 2 | 1.38% | |
2021 | 1 | 0.69% | |
Voters: 145. You may not vote on this poll |
Thread Tools |
04-15-2021, 01:35 PM | #715 |
Drives: Camaro ZL1 Join Date: Apr 2019
Curious as to why am Oil cooler would be needed? I take it there's no way of flushing it if there's debris?
Made in the USA. Refined in Great Britain - insta: zl1uk
Velossa intake, Rotofab, Mamo TB, Custom ported NX Lid & Jokerz Full tilt ported LT4 charger, 3 port CoolingMist Meth injection - ATI 15% lower pulley, E2X CC, TSP ceramic coated longtubes, de-cat and Borla 60608 to NPP box, JRE tune, BMR rear control & trailing arms, lock-out kit, lowering springs and front strut brace, Custom carbon trim interior, Xpel ultimate front PPF and Prestige window tint with Chameleon Windscreen tint...ever evolving... |
04-15-2021, 01:57 PM | #716 | |
Drives: 2018 Hyper Blue ZL1 1LE Join Date: Dec 2018
You can flush it, but results are uncertain. |
04-15-2021, 02:03 PM | #717 | |
Former GM Technician
Drives: 2018 ZL1 A10, 06 Silverado Duramax Join Date: Sep 2009
I attached the oil flow diagram.
2018 Camaro ZL1 A10
Rotofab Big Gulp, Nick Williams 103, Magnuson 2650, 9.17" (14%) lower, 90mm upper, Vengeance Racing Heads (LME) Cam Package (Cammotion Stage 1), Johnson Lifters, JMS Voltage Booster, Lingenfelter high flow check valve, BBK shorty headers, Custom 2.75" down pipes, Gesi Gen2 high flow cats, MM catch can 791whp, 772ft-lbs SAE Just added 30% XDI Injectors, LPE big bore hpfp, Flex fuel. Elite tuning, results coming soon. 2006 Silverado Duramax Diesel MPI Compound Turbo 40% over Injectors Efi Live DSP5 Tuning Follow me on Instagram: Swisstyphoon1980 |
04-15-2021, 03:02 PM | #718 | |
Drives: Track prepped 2018 Camaro ZL1 (a10) Join Date: Aug 2013
The service manager at my dealership is a friend of mine so I trusted his explanation.
2018 ZL1; Mag 2650 and 2 inch LT Headers , every SPL suspension upgrade, MCS 2 way coilovers, sway bars, square SC3R 325's all the way around, and multiple brake cooling upgrades
04-15-2021, 04:23 PM | #719 | |
Doesn't the pressure bypass valve allow oil flow to bypass the filter when the car is very cold at startup in the morning? In this case if the pump is already crumbling inside metal particles from a failed pump could get past the filter. For what it's worth, I would ask the service manager to show you the filter and have them cut it open or let you take it somewhere to do that. It may be too late, wouldn't surprise me if the dealer already disposed of it or withheld for GM. |
04-15-2021, 04:27 PM | #720 | |
Yeah not a bad idea!
04-15-2021, 05:01 PM | #721 |
Drives: 2019 ZL1 Riverside Join Date: Apr 2020
It's not just the oil pump itself. Running the engine on load with low oil pressure will almost inevitably cause some damage, I would want a compression/leakdown check. Furthermore I would never consider buying a used car with a reported oil pump failure. Kind of like buying a car with an accident on carfax
04-16-2021, 12:39 PM | #722 | |
Drives: 2019 ZL1 1LE Join Date: Feb 2017
There's no need to get a Katech pump, that's just throwing away money and probably voiding your powertrain warranty. GM worked with Melling to revise the pump design and the issue has been resolved.
Old: 2017 SS 1LE
Old: 2017 ZL1 Current: 2019 ZL1 1LE |
04-16-2021, 01:04 PM | #723 | |
You can sell the Katech to someone who is doing significant mods. Last edited by SFV1LE; 04-16-2021 at 04:20 PM. |
04-16-2021, 02:59 PM | #724 |
Drives: 2018 ZLE Join Date: Feb 2018
04-16-2021, 03:59 PM | #725 | |
Drives: 2015 Camaro ZL1 Join Date: Oct 2020
As far as I can tell the "new design" isn't any stronger. I'm going to make a video at some point in the next week or 2 showing why these pumps fail. |
04-16-2021, 07:22 PM | #726 |
Drives: ´18 ZL1 A10 Red Hot 😍 Join Date: Jan 2016
Can someone tell us the latest GM oil pump P/N?
Thank you.
First ZL1 in Spain (Madrid)! Red Hot, A10, PDR, carbon fiber hood & grounds effects...
04-16-2021, 08:18 PM | #727 |
Drives: 18 ZL1-1LE, 10 JKU Join Date: Jul 2018
Let me preface this with “i got this number off facebook”...but it was a newer version than what i had, saw a few others using it, so i went with it.
https://sdparts.com/i-24139868-genui...sump-only.html |
04-16-2021, 08:53 PM | #728 | |
Thank you!
