TireRack
Old 04-05-2021, 10:48 PM   #15
Bo White
Bo White's Avatar
Drives: 2015 Summit White 2SS 1LE
I'm in the middle of putting these on finally. Going to the dyno Sunday and I'll see for myself.
Retired wanna be cylinder head porter
2015 2SS 1LE Clutch reservoir, Vararam DRX, ported TB, TSP 2" headers, MGW shifter
Totalled:
2010 1SS Wilkes Performance/Eagle 416 shortblock, TSP custom valvetrain, PRC 260 heads, Edelbrock Pro Flo 102, th400 swap, 8" PTC 5500 stall= 535/435 at the wheels tuned Gen 3 Performance and Dyno 10.97 @ 124 full weight in 3100 DA CamaroFest X
Bo White is offline   Reply With Quote
Old 04-13-2021, 03:27 AM   #16
Ashen L99
Ashen L99's Avatar
Drives: Ashen grey, 1SS, L99
Originally Posted by sinisterlsx510 View Post
Any benefit of going to a 2in header vs 1 7/8
On a stock LS3 with headers janetty racing picked up 10 more numbers with 2” over 1 7/8”. That seems to be the general consensus. And as always bo will show us his results because he’s an apples to apples kind of guy! Just like with the 416 vs bottom end with the same cam.
Roto-fab CAI, Nick Williams 102mm TB, LOD X1 V3 intake manifold, GMPP LS3 heads, Night Fury cam, TSP 2” long tubes, Corsa ZL-1 catback, Nitrous Outlet 102mm plate kit/150 shot, NGK BR7EF plugs with Taylor plug wires, DSX flex fuel kit, ZL-1 fuel pump and injectors, B&M deep trans pan, Yank 3400 converter, 3.45s with BMR Delrin bushings, mishimoto 169° Thermostat, GM ground effects, T-Rex upper grill, Z/28 Spoiler, Lolly pop Lime brake calipers, ZL1 10 spoke wheels, 12” subwoofer, and custom paint matched interior.
Ashen L99 is offline   Reply With Quote
Old 04-13-2021, 06:57 AM   #17
Bo White
Bo White's Avatar
Thanx for reminding me. I picked up zero until after peak power. In the overrev it was 8rwhp 2" vs 1 7/8"
Don't know about bottom end changes because my stall absorbs everything pretty much below 5500rpm.
Totalled:
Old 04-13-2021, 11:21 AM   #18
Clarkstar
Clarkstar's Avatar
Drives: 2013 1SS 1LE
Any pics of them installed? Any fitment issues?
2013 1le- Katech 416 short block, TSP custom grind cam, LOD intake, cnc heads by F.ED., Nick William's 102mm T.B., CORN fed, Pedders coilovers. Performance street alingnment by Justin at Lake Country Alignment and dyno tune by Late Model Throttle.
603 h.p. 495 ft lbs tq.
Clarkstar is offline   Reply With Quote
Old 04-13-2021, 10:56 PM   #19
Bo White
Bo White's Avatar
I just recently put BMR mounts on and had to loosen it up and shift the engine over a touch because they are slotted.
Totalled:
