dave@hennessey
Old 03-27-2020, 05:16 AM   #1
Bo White
Bo White's Avatar
Drives: 2015 Summit White 2SS 1LE
Sold my mid runner FAST intake manifold
Decided to round out my radical build for a more radical manifold. I've been doing an intake manifold swap while my car was in the body shop.
Edelbrock Pro Flo XT LS3
I think it's a first for a 5th Gen. Clears the stock hood! Passenger wiper modded to clear. Just cut as shown and bend it up and then extend it back to the original length to get the sweep right. Testing I've seen has been on par with the Holley High Ram.
Dyno results? 19rwhp gain and another 300rpm of rev.
Bo White is offline   Reply With Quote
Old 03-27-2020, 05:23 AM   #2
Bo White
Bo White's Avatar
Dyno pull
https://youtu.be/HktDAomZYak
Old 03-27-2020, 05:24 AM   #3
Bo White
Bo White's Avatar
Passenger wiper works great
https://youtu.be/kepn9polUug
Old 03-27-2020, 06:00 AM   #4
Clarkstar
Clarkstar's Avatar
Drives: 2013 1SS 1LE
Awesome sauce!!!
2013 1le- Katech 416 short block, TSP custom grind cam, LOD intake, cnc heads by F.ED., Nick William's 102mm T.B., CORN fed, Pedders coilovers. Performance street alingnment by Justin at Lake Country Alignment and dyno tune by Late Model Throttle.
603 h.p. 495 ft lbs tq.
Clarkstar is offline   Reply With Quote
Old 03-27-2020, 08:21 AM   #5
xc_SS/RS
Drives: 2010 Camaro SS/RS
I’ve been wondering if this would fit! That’s dope
2010 2SS/RS
Z/28 intake, NW, FAST 102, speed engineering LT's, some exhaust, ATI -10% pulley, GM flex fuel injectors, DSX flex fuel sensor, MGW shifter, HP Tuners, some suspension work, stickers and a little weight loss. 12.63 @113.53
xc_SS/RS is offline   Reply With Quote
Old 03-30-2020, 01:18 PM   #6
STALKER
STALKER's Avatar
Drives: 2023 Camaro ZL1 1LE
Wow. Good gains. First I'm hearing of this intake.
2014 Camaro SS Spring Edition LSX440ci
LSX Block, MAST 305 Black Labels, Exceldyne Valves, Diamond Pistons, Callies Crank & Rods, Cam Motion Cam, Johnson 2116LSR Lifters, Comp XDA Pushrods, Jesel Rockers, Mamo MSD, NW 102, Roto-Fab CAI, FAST 65# Injectors, ZL1 Fuel Pump, Kooks 2" Headers, Corsa Sport 3" Catback, Z28 Shifter, ZR1 Clutch, Katech LW Flywheel, 1LE 3.91 Diff, LPW Diff Cover, BMR - 1.4" Springs, LCA's, Trailing Arms, Toe Rods, Sway Bars, End Links, Diff Bushings, and Tunnel Brace, Z28/1LE Strut Tower Brace, Improved Racing Oil Cooler
2023 Camaro ZL1 / 1LE
Stock
STALKER is offline   Reply With Quote
Old 11-20-2020, 12:34 AM   #7
YOLO Z/28
YOLO Z/28
YOLO Z/28's Avatar
Drives: 2014 Z/28
Based on your experience, do you think the intake would fit with a half-inch spacer between the cylinder head and intake flange?
2014 Red Hot Z/28, CTF car #39/69. HCI, Supercharged, boltons.
2006 SRM GTO, exhaust, VMR V701 wheels (SOLD)
2002 Bright Red Trans Am WS6: HCI, exhaust, tune, Konis, UMI sways, LCAs, Track bar, STB, 2" boxed steel SFCs (SOLD)
YOLO Z/28 is offline   Reply With Quote
Old 11-20-2020, 03:19 AM   #8
Bo White
Bo White's Avatar
It would be a tight fit but probably
Old 11-20-2020, 10:27 AM   #9
YOLO Z/28
YOLO Z/28
YOLO Z/28's Avatar
Drives: 2014 Z/28
Thanks for the response. Ive been looking for an intake that would clear the stock hood and help power up top without breaking the bank. But mines an LS7 car so id have to use billet adapters.
Old 11-23-2021, 10:32 AM   #10
eLeSthree
Drives: 2011 Camaro SS 6sp
Hey Bo, do you have any pics of the port work done to fit the 102mm TB?
I just ordered this manifold and nw103mm tb, and I'm just curious how much material needs to be removed. Thanks
2011 Camaro SS---SOLD
TMS Dart 427 FED M311s, ESS Tuning G4 Blower, DSX Triple FP Assembly, DSX FF, FIC1300, Mcleod RXT 1200HD, Edlebrock Pro Flo XT
1158whp 1017wtq.
2010 CTS-V A6 - "Stock" SOLD
630whp 658wtq
2024 F-150 RCSB 5.0 4x4
waiting for tunes...
eLeSthree is offline   Reply With Quote
Old 11-26-2021, 12:32 PM   #11
Bo White
Bo White's Avatar
Yeah I got a pic. Before and after.
Retired wanna be cylinder head porter
2015 2SS 1LE Clutch reservoir, Vararam DRX, ported TB, TSP 2" headers, MGW shifter
Totalled:
2010 1SS Wilkes Performance/Eagle 416 shortblock, TSP custom valvetrain, PRC 260 heads, Edelbrock Pro Flo 102, th400 swap, 8" PTC 5500 stall= 535/435 at the wheels tuned Gen 3 Performance and Dyno 10.97 @ 124 full weight in 3100 DA CamaroFest X
Old 11-26-2021, 01:48 PM   #12
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
Very clean looking Bo!! Nice job sir!!
1JEWLDSSRS is offline   Reply With Quote
Old 12-06-2021, 10:25 AM   #13
eLeSthree
Thanks Bo, I'll give this a try tonight. It probably wont look as pretty as yours though, lol.
1158whp 1017wtq.
630whp 658wtq
Old 12-06-2021, 04:40 PM   #14
eLeSthree
Not bad for a rookie using a drill and some amazon bits.
1158whp 1017wtq.
630whp 658wtq
