Old 07-12-2017, 05:07 PM   #1
dabomb4ever
Drives: 2017 Camaro SS 1LE
driveway angle feels like bottoming out
New 2017 SS 1LE owner here, and I had a question regarding suspension travel. My driveway is at a decent slope from the street and to ensure I don't scrape the front splitter, I take it slow and at a 45 degree angle to ensure both tires don't end up in the curb dip. I don't think that it would scrape unless I hit it straight on at 5mph with a passenger in the car, but better to be safe than sorry. Ive noticed that as I am partially on the road and partially on the driveway, I have an unusual feeling in traction that it almost feels like the car is bottoming out on the frame, or that the suspension travel is maxed out and the car is on two wheels (left front/right rear) . As I release the clutch in first to crawl entirely onto the driveway, there is a small margin between the rear tires slipping and killing the engine. My previous car is an M3, so I am used to having a lower car with less suspension travel, but Ive never encountered this type of feeling in a cars suspension before. Is this typical for this car with the 1LE suspension? My driveway isn't that extreme, I have also encountered this on typical driveways as well.
Thanks for the feedback.
-Nick
dabomb4ever is offline   Reply With Quote
Old 07-12-2017, 06:17 PM   #2
seanblurr
seanblurr's Avatar
Drives: ZL1 1LE
Are you feeling the car teeter on three wheels? My inside rear wheel goes into the air as I enter my driveway too.
seanblurr is offline   Reply With Quote
Old 07-12-2017, 06:46 PM   #3
rootus
Drives: 2018 HBM SS 1LE
Sounds normal to me. At least, I get exactly the same effect going up inclined driveways with my STI. There's a moment when I'm pretty sure it lifts a wheel or nearly so, and you're basically balancing all the weight on two wheels. Stiff chassis and not a lot of suspension droop will do that.
rootus is offline   Reply With Quote
Old 07-12-2017, 07:59 PM   #4
devnull
Scientific negotiator
devnull's Avatar
Drives: 2019 Grand Sport
Mine does the exact same thing Nick. I was sure I was scraping the splitter, but it was just the traction/engine dump. After 5 lowered vettes I thought this one would be easy, but it freaked me out a bit in the beginning!
GREAT CAR!
2019 Grand Sport M7
2018 ZL1 1LE 6MT
2017 SS 1LE 6MT
Matthew 25:40
ΜΟΛΩΝ ΛΑβΕ
devnull is offline   Reply With Quote
Old 07-12-2017, 08:19 PM   #5
Allez
Allez's Avatar
Just have someone watch you while you're doing this.
Easy enough to do.
Allez is offline   Reply With Quote
Old 07-12-2017, 09:02 PM   #6
formoutofchaos
Drives: Camaro 2017 1LE
I used to bricks squares for garden and a long cut piece of wood and no scraping ugly but works
formoutofchaos is offline   Reply With Quote
Old 07-12-2017, 09:29 PM   #7
lownslowss
PaPa Smurf
lownslowss's Avatar
Drives: 2022 SS 1LE
One of my rear wheels comes up, spin it every time
2022 Rapid Blue SS 1LE
lownslowss is offline   Reply With Quote
Old 07-12-2017, 09:29 PM   #8
RXtacy
RXtacy's Avatar
Drives: 93 RX-7, 17 SS 1LE, 04 RX-8
I've also had the three 3 wheeling experience. Like others have said, a result of stiff chassis and little suspension travel.
RXtacy is offline   Reply With Quote
Old 07-12-2017, 10:29 PM   #9
Trackpack
Trackpack's Avatar
Drives: 1LE
Yes, same here on a moderate driveway. Works great on track though!
Trackpack is offline   Reply With Quote
Old 07-13-2017, 07:22 AM   #10
DFW1LE
DFW1LE's Avatar
I had to have the front part of my driveway re-poured to stop the scrapping. This car is very stiff, so you will get wheel coming off the ground when coming in at an angle. I used a 2x8 for a while but got tired of putting it down and taking it up when going in and out of the driveway, and it would also move around some if you don't hit it just right.
Old 07-13-2017, 08:38 AM   #11
mjk3888
"M1SS1LE"
mjk3888's Avatar
Drives: 2017 SS 1LE
This car is very VERY rigid!!! It's very easy to pick up 1 of the rear wheels when articulating. That's what your feeling.
Old 07-13-2017, 10:59 AM   #12
Yendor
Yendor's Avatar
Drives: 2017 Camaro 1SS 1LE Hyper Blue
Anyone try something like this? My driveway isn't steep, but I've still scraped and have to be very careful going up it.
http://www.newpaloaltohouse.com/2013...on-thumbs.html
Yendor is offline   Reply With Quote
Old 07-13-2017, 11:25 AM   #13
dotfiles
@SS_1LE
Drives: 2017 SS 1LE
I three wheel going into my driveway as well. My solution has been to use a more shallow angle and keep a small bit of momentum (1-2mph) so that the car never stops. If the car stops, one wheel will spin as I start moving again and the eLSD will engage.
I believe these cars have a higher tendency to three wheel than others because both the chassis (alpha platform FTW) and the sway-bars are very stiff, not allowing much articulation to happen.
17' Camaro SS 1LE | PDR | Summit White
Borla S-Type Axleback | Mishimoto Catch Can | LED Sidemarkers | ZL1addons DRGs | Michelin MPS4S
dotfiles is offline   Reply With Quote
Old 07-13-2017, 11:28 AM   #14
RatedR
Drives: 2017 Camaro SS 1LE Summit White
As everyone else has said, i have felt it too. I think some of the odd feelings may be the e-diff trying to deal with one wheel lifting.
RatedR is offline   Reply With Quote
