02-12-2016, 11:25 AM | #29 | ||
Speed Freak
Drives: 2013 ZL1 Camaro, 2016 Camaro SS Join Date: Jun 2013
I agree with Ted and think the 1:1 (6th gear) is the best way to dyno the car. If it takes longer to make the pull it is probably going to be more accurate than trying to quickly zip through the pull in a lower gear. My '16 SS made 395 on its first pull, I'm used to a modified ZL1 so I was a little shocked at how small that number seemed to me....To me it just shows how good the chassis and suspension are that allow this car to feel this fast with so little horsepower....and it tells me this thing is going to be a terror when it gets a power bump.
2016 SS -AGP twin Borg Warner 7163 EFR's, LT4 mechanical pump, LT4 injectors, Walbro 255 low side, Castrol SRF. 734whp/759 tq
2013 ZL1 -ADM - 427 LSX 6 bolt, O-ringed block built by LME. Twin PT6466 turbos. RPM custom manual trans, RPS Quad carbon clutch, 9" Hendrix rear diff & axles. ADM/squash fuel system, Ron Davis radiator, Spal fans, AGP air to air, turbo plumbing. LPE oil cooler, rear bushing upgrade, roll bar...etc. rwhp 1400+... 212.5mph, best Texas mile to date. |
02-12-2016, 12:09 PM | #30 | |
Past: '99 SS Camaro A4, '73 Camaro 383 A3 "Voices in your head are not considered insider information." 3800 Status - 6/16/16 (Built!) 6000 status - 6/29/16 (Delivered!) |
02-12-2016, 12:34 PM | #31 | |
Speed Freak
02-12-2016, 12:41 PM | #32 | |
From the very definition of the word:
and quick: moving fast or doing something in a short time If you are quick then you are fast, if you are fast then you take less time.
02-13-2016, 10:38 AM | #33 |
Super is right, It could be a quicker et and a faster mph. The A8 is quicker and faster then the M6 in all testing so far and it makes no difference what the dyno shows as the M6 will put down more power on the dyno because the A8 will lose more hp/torque through the torque converter and tranny then the M6 will.
02-21-2016, 10:04 PM | #34 |
Lethal Camaro
Drives: 16 2SS, 71 Std, Suburban RTS Join Date: Jun 2013
What speeds are you hitting? In 5th we were seeing speed close to the tire rating and stopped the pull.
02-21-2016, 10:12 PM | #35 | |
Drives: SS 6 speed of course Join Date: Jan 2016
your are confusing faster with quicker. Bone stock the M6 should be slightly faster, the A8 is much quicker mainly due to the ability to hook, the M6 uses 1st gear to something like 53 MPH, if is a dicey bog vs blow the tire away. I error on the side of slight bog and slip the clutch. After 150 or so 0 to 60 trials I feel I'm in fighting form for the inevitable street fight. All the time I'll be thinking it is better to bog slightly.
02-21-2016, 10:16 PM | #36 | |
http://www.hotrod.com/features/1512-...ed-1500-miles/ and the m6 is faster, the A8 is quicker.
02-21-2016, 10:23 PM | #37 | ||
: moving or able to move quickly : happening quickly : taking a short amount of time : operating quickly and quick: moving fast or doing something in a short time If you are quick then you are fast, if you are fast then you take less time. Don't try to argue with a dictionary. And last time I checked, launching was the most critical part of a drag race. So yes the A8 is the quicker car because it is faster in the 1/4 thanks to gearing.
02-21-2016, 10:31 PM | #38 | |
02-21-2016, 10:35 PM | #39 | |
Past: '99 SS Camaro A4, '73 Camaro 383 A3 "Voices in your head are not considered insider information." 3800 Status - 6/16/16 (Built!) 6000 status - 6/29/16 (Delivered!) Last edited by SuperSound; 02-22-2016 at 12:04 AM. |
02-22-2016, 12:12 PM | #40 |
Logic eludes you. Both do have a time component. Faster has to do with rate of travel, in this case measured in MPH. The car with higher MPH is said to be faster. Quicker means that one car accomplished a task in a shorter time span this is measured only in time and is know as ET when we are dealing with a quarter mile. They are independent of each other. A quicker car wins a timed race is not always the faster car.
02-22-2016, 12:24 PM | #41 | |
From: http://english.stackexchange.com/que...ker-and-faster The definition of the two words makes them synonymous in virtually all cases. However, they do have slightly different connotations that lead to preference in usage. I generally think of something as "fast" if it can achieve a high speed. I think of something as "quick" if it responds rapidly to input.This generally leads to preference of one word over the other in context; "fast" is used in context of speed, while "quick" is used in context of time. So, you would travel fast to get somewhere quickly. POWNED dude
02-22-2016, 02:28 PM | #42 | |
Mickey Thompson should have called their tires MPH Streets, because no one wins a drag race because of ET? Ask a 5 year old who is faster in a race, the guy who crosses the finish line first or the guy who's legs are moving the most at the finish line. The USPS describe Priority mail as "fast domestic service". You going to argue with them that they aren't using the correct usage of the word? (or the other hundreds of delivery services that use "fast" in their descriptions). Jeremy Clarkson always asked if you want to know how "fast" a car is around their track and time is the only measurement. (And so does everyone in terms of track times, i.e. the Camaro SS 1LE is faster around VIR than a Mustang GT PP) Which professional or amateur racing has a competition for most MPH in the 1/4 mile? No one cares what your MPH is! You didn't beat the guy to finish line, you lost! By your logic a guy could have 2 second RT, spin for the first 300 feet and be the "faster" car. Yes, that's why there are only two real type of drag racing, heads up and bracket. Both have nothing to do with MPH. For land speed records they use speed over a measured distance and guess how you calculate speed? By time over a measured distance! (Miles Per Hour) So a car that is the fastest in MPH covered the distance in a shorter time than the slower car, which means it is quicker by your own definition! Bottom line your own post proves you are wrong. If the words are synonyms they can be used interchangeably. There is no if and or but to that. You can try to create your "own definition" (like some internet manual transmission fanboy) to try muddy the fact that the auto is the faster car in the 1/4...period. And btw, the A8 has posted the highest MPH of any results so far at 118mph
