07-10-2023, 12:24 PM | #1 |
QTP cutouts problem - Help
After going WOT with the cutouts closed I noticed a slight leak on both sides. I tried closing them with the fob and nothing, no sound at all even the over wind sound if you hold the close button too long. They worked fine when I last used them a month ago. The fob battery is brand new. I didn’t try opening them for concern that they wouldn’t close at all.
They were installed 9yrs ago by QTP when they were in NJ and the only problem I had is one motor had to be replaced about 5yrs ago. Any thoughts on what the problem could be? Thanks |
07-10-2023, 02:07 PM | #2 |
The slide/gate probably needs lubing
Orange Krush II
07-10-2023, 04:26 PM | #3 |
I was thinking of that but it would require them to be open which I’m reluctant to try as they may not close even a little. If they did open by using the fob but then didn’t close I guess I could try to force them shut by pressing on the butterfly with something heavy like the tip of a crow bar?
Thoughts |
07-11-2023, 03:20 PM | #4 | |
07-11-2023, 07:38 PM | #5 |
Drives: 2010 Turbo LS3 Join Date: Dec 2009
Those wires are easy to melt too, so look for where the insulation might have melted and be grounding. If you have the controller, it will be showing an error if it's grounding. I replaced the twist locks on mine for two wire plugs and used silicone over fiberglass sleeving to prevent melting.
2011 Vert - 416/w 230/236 .612/.602 115lsa, 1LE suspension w/32mm rear bar. Z28 diff. ZL1 brakes. Last edited by CamaroCracka; 07-12-2023 at 11:42 AM. |
07-12-2023, 04:53 AM | #6 |
All good info in the above replies. Thanks guys much appreciated! I’m thinking it’s more an electrical than mechanical issue as it happened all at once to both sides AND that there is no motor noise on either side when I press the close button. I really don’t know what to do as like I said QTP installed them when they were near me in NJ so I don’t know what to look for besides not having a way to lift the car to get under it and I don’t know where I could take it for someone else to look at. On the positive side the leak isn’t too loud so it sounds pretty good and there isn’t any noticeable smell.
07-12-2023, 11:21 AM | #7 |
Good luck my friend!! Hope you get it figured out.
07-12-2023, 09:58 PM | #8 |
07-13-2023, 08:50 AM | #9 | |
https://quicktimeperformance.com/i-3...c-cutouts.html
07-14-2023, 07:01 AM | #10 | |
07-14-2023, 09:39 AM | #11 |
Yes sir, I'm here to help, if and when I can!!
07-14-2023, 03:04 PM | #12 |
Good News …I decided to try and open them and they both opened with the fob and closed to their slight leak position but they still didn’t make the overwind noise when you hold the close button too long hmmm. So the problem must be a piece of carbon got thrown in both of them when I went WOT with them closed causing them to not quite close completely but enough to stop their motor’s from overwinding.
First chance I get I’ve got just enough room to crawl under each side without needing to jack the car to be able to to spray them with PB Blaster and scrap them with a small metal bristle brush. I’ll post an update when I do. |
07-14-2023, 03:43 PM | #13 | |
Drives: 2010 2SS LS3 and 1978 STROKER 383 Join Date: Feb 2018
You will always hear a small leak. I have a brand new set and I always hear the leaking.
My life is a constant struggle with Camaro.
K&N CAI, Stainless Power longtubes, high flow cats, modified Ragazzon High Performance axle back, Soler Performance ported throttle body, Soler Performance throttle controller, RAM clutch adjuster, modified LS7 clutch kit, Tick Performance billet bearing support, Tick Performance remote bleeder, separate clutch reservoir, BMR trailing arms, BMR toe rods, Pedders Suspension cradle bushing inserts, Control Arm Bushings, Strut tower brace, oil catch can, Hurst T-handle shifter, 20mm wheel spacers, DBA brakes, QTP Cutouts, Dynosteve tune. |
07-15-2023, 01:14 PM | #14 | |
