12-16-2018, 09:53 PM | #29 | |
Drives: 2017 Camaro 1SS M6 Join Date: Apr 2015
2017 Camaro 1SS, M6, Hurst shifter, Hyper Blue, NPP, Gray Split Spoke Wheels
Best 1/4 Mile: 12.24 @ 115.9 mph |
12-17-2018, 07:53 AM | #30 |
Drives: ISO ss 1le Join Date: May 2018
The hub pilot is 11mm, which does bury it however most 10-12mm spacers have a hub built in. I use Apex spacers as well, with a hub ring adapter and it lines everything up just fine for the wheels to be bolted on.
12-17-2018, 08:45 AM | #31 |
Drives: 2018 1SS 1LE Join Date: May 2018
Does nobody make a spacer with the correct inside and outside hub diameter so that only the spacer would be required? It would be reasonably easy to make on a lathe. It seems there would be a market for such a part based on this discussion.
12-17-2018, 09:23 AM | #32 |
Doesn't seem so. I know Apex has some camaro stuff in the works, studs, spacers etc... but not currently.
12-17-2018, 10:03 AM | #33 |
Do you have a link or pictures to what you use (ie. Apex spacers with a hub ring adapter)?
12-17-2018, 10:18 AM | #34 | |
(4) Hub Centric Rings 72.6mm (Wheel) to 66.9mm (Hub) Hubcentric 66.9 to 72.6 https://rover.ebay.com/rover/0/0/0?m...2F222382407905 Studs .5 in (or 12.7mm) longer than stock ARP Wheel Stud 100-7736 https://rover.ebay.com/rover/0/0/0?m...2F332768489495 Spacers (mine actually are 12mm for the 18” wheel but the 5mm for 19” provides plenty of hub space remaining) https://www.apexraceparts.com/apex-1...r-kit-933.html |
12-17-2018, 11:48 AM | #35 | |
http://www.motorsport-tech.com/4DCGI/switchmodel Is 12mm too thick to run just a hub & wheelcentric spacer and longer studs?
12-17-2018, 12:07 PM | #36 | |
12-17-2018, 02:18 PM | #37 | ||
Drives: 93 RX-7, 17 SS 1LE, 04 RX-8 Join Date: May 2017
They do, I got mine from Motorsport Tech. http://www.motorsport-tech.com/ Quote:
I run 12 mm with longer studs you need it for 18s to clear the strut. |
02-04-2019, 10:46 PM | #38 |
Drives: 2018 Camaro SS 1LE Join Date: Jan 2019
what offset are these wheels?
02-06-2019, 12:08 AM | #39 |
Drives: 2020 2SS 1LE Join Date: Nov 2016
