Old 12-10-2018, 04:10 AM   #1
mcbuff52
Drives: 2010 Camaro 2SS/RS A6
2010 2SS L99 trans cooler
Any suggestions for a trans cooler that works well on my Camaro?
mcbuff52 is offline   Reply With Quote
Old 12-10-2018, 05:56 AM   #2
Chris49066SS
Chris49066SS's Avatar
Drives: 2010 SS L99
Yes, the ADM cooler works very well. I have one, and my trans temp never gets above 180. You can get them at LSA Conversions website
Previous PB:11.079 @ 122.99mph.. New setup time: TBD
The 11.079 pass: https://youtu.be/pz27Zq54t_E
Build thread - www.camaro5.com/forums/showthread.php?t=555371
Chris49066SS is offline   Reply With Quote
Old 12-10-2018, 07:51 PM   #3
jergarr
jergarr's Avatar
Drives: 11' RJT 2SS/RS L99
I've got the adm one as well for almost a year now with no issues. Keeps the trans from getting above 180°.
GPI VVT3 Cam
Circle D 3800 Single Disc Stall
1LE 3.91s
Stainless Power Headers w/cats
Fluidampr 25% UDP
Cold Air Inductions Intake
Bo White Ported Throttle Body
ADM Trans Cooler
Some BMR Goodies
jergarr is offline   Reply With Quote
Old 12-10-2018, 09:08 PM   #4
hammdo
'It's an experiment'
hammdo's Avatar
Drives: [COTW 2/09/15] '11 GPI LSA SC Z/LE
I had the ADM, upgraded the cooler to the biggest one out there:
https://www.camaro5.com/forums/showp...postcount=1702
https://www.camaro5.com/forums/showp...postcount=1709
Mine is a combo now!
-Don
747 RWHP 794 RWTQ
"Horsepower sells cars, torque wins races." - Enzo Ferrari
See My Build: http://www.camaro5.com/forums/showthread.php?t=385577
hammdo is offline   Reply With Quote
Old 12-10-2018, 10:17 PM   #5
myold88
myold88's Avatar
Drives: SUMMIT WHITE 2SS/RS CAMARO
My 10 SS trans runs at a constant 190. Never much above. Why a trans cooler? I don't
remember of one L99 transmission failure here on Camaro5. Like they say, if it ain't
broke don't fix it... Just sayin.
myold88 is offline   Reply With Quote
Old 12-10-2018, 11:25 PM   #6
StingrayblueSS
StingrayblueSS's Avatar
Drives: 2013 Camaro SS
Do you race your car? Just sayin...
StingrayblueSS is offline   Reply With Quote
Old 12-10-2018, 11:52 PM   #7
hammdo
hammdo's Avatar
I road race mine — heat is the enemy...
Thus a trans cooler...
-Don
747 RWHP 794 RWTQ
Old 12-11-2018, 06:05 AM   #8
Chris49066SS
Drives: 2010 SS L99
I have a 4K converter. Lots of slip=lots of heat
Old 12-11-2018, 06:13 PM   #9
Rock-It Man
376 cubic inches of fun
Rock-It Man's Avatar
Drives: 2023 Camaro ZL1 A10
The L99 A6 comes with a trans cooler.
I have made multiple 1/4 mile passes at street night with no cool down period and the trans temp has stayed steady.
If it ain't broke, don't fix it.
Old 12-11-2018, 06:35 PM   #10
SSEssence
Instagram: Sangstah
SSEssence's Avatar
Drives: 2019 Camaro 1LE
how involved is the ADM trans cooler install?
2019 SS 1LE - "CaSSandra" 2014 SS - "AleSSandra - Sold" 94 Z28 - Sold
Follow the build https://www.camaro6.com/forums/showthread.php?t=612717
SSEssence is offline   Reply With Quote
Old 12-11-2018, 06:47 PM   #11
Chris49066SS
Drives: 2010 SS L99
Stock, you're fine. Its only for when you are running a torque converter with higher stall speeds because they produce more heat due to slippage. Heat is one of the big enemies of transmissions. When you're cammed past a Stage 2, you generally need to run a higher stall converter. All depends on the application. I ran a stock converter on a stock engine too.
Old 12-11-2018, 08:17 PM   #12
Bandit63
Bandit63's Avatar
Drives: 2011 Camaro SS
I installed the ADM cooler when I put in a 3200 stall
MRR M228 Wheels, Circle D 3200 Stall, 3.91 Gear, Texas Speed VVT 3.2 Cam, CHE Rocker Arm Bushings, Texas Speed Headers, No Cats
Bandit63 is offline   Reply With Quote
Old 12-11-2018, 08:31 PM   #13
Roader
Drives: Camaro
Trucool 40k kept me right at or below 180 in Texas with a 4K stall
Roader is offline   Reply With Quote
Old 12-12-2018, 06:03 AM   #14
Chris49066SS
Drives: 2010 SS L99
www.camaro5.com/forums/showthread.php?t=94233
Heres a pretty decent thread for trans coolers.
