12-15-2018, 02:07 PM | #29 |
Drives: 2017 2.0 Camaro LT Join Date: Aug 2018
E brake failure
Hi,
My e brake actually failed today, was literally driving when I got an alert on dash that my electronic e brake needed maintanance, I stop and tried to use e brake and nothing car kept moving forward, I drive a manual trans so I was scared as I was at work and couldn’t park car anywhere. After a few restarts car alert went off and enrage worked again, should I be concerned? Thinking about taking to dealer but I have a lot of aftermarket engine parts but nothing on brakes |
12-15-2018, 02:46 PM | #30 | ||
Drives: Chevy Blazer Join Date: Sep 2009
I run around in track mode with all the nannies off. Though, since 2007 or so, GM has actually had pretty good ABS systems... Good enough I don't pull the fuse anymore, lol. Quote:
If you have no brake system mods, they should still warranty the park brake. Sent from my SM-G930W8 using Tapatalk |
12-15-2018, 03:38 PM | #31 |
Drives: Red hot ZL1 A10 2017 Join Date: Nov 2016
Cost me a rear bumper.
I don’t want the car to park on the trans. So my method: In D or R I stop the car with the std brake, Then I engage the e-brake, Then when set, I release the foot, The car move a little bit in D or R to set on the e-brake, Then I put the trans in P. The car is on e-brake not pausing on the trans P. (It saves the trans not engaged) Except this F.. e-brake is related to trans. Because if you now put D or R and you accelerate, the e-brake will automatically disengage and the car will run D or R! Stupid! E-brake is supposed to be e-brake whatever and not disengaging if not disengaged. My story: Was backing in my garage, Put my e-brake, Thought I came back to P as usual, but was still in R.... My friend visiting me was looking at the car from the kitchen door, I made a big acceleration (still thinking in P) to make the engine loud, The 650 hp of the Z went straight in the wall !!!!! Big loud sound, not the one I expected.... So the related E-brake to the trans (software/hardware...????) Is damned stupid Prefered it completely separated. |
12-15-2018, 05:31 PM | #32 |
Drives: 2017 2 SS vert Join Date: Jul 2018
I like the e brake like the one on my Benz, it is easy as I have a bad left hip
My. wife and I use our parking brakes on all our cars My dad had his car putted at a mall and took out the trans years ago in the 50 s Brake first then put in park thats what we do all the time |
12-15-2018, 07:31 PM | #33 |
The ebrake is fine with me it’s just what do I do if it fails kind of thing, definitely don’t want it to roll back or forth hitting a wall or worse another car. Anyone know of another way to stop car moving with manual transmission if ebrake fails? Just in case it happens again to me
12-15-2018, 08:08 PM | #34 | |
Drives: 2018 Camaro 1SS 1LE Join Date: Sep 2018
On a slight incline having it in gear is enough it won't move. |
12-15-2018, 10:29 PM | #35 |
Drives: 2012 Porsche 911 Turbo S Join Date: Jan 2017
It works fine .
IG: 2fast2nick
-- Current -- 2012 Porsche Turbo S - PDK - Basalt Black Metallic -- Past -- 2017 Camaro ZL1 Coupe - Red Hot - A10, PDR - HRE P101 2015 Mustang GT PP - Whipple Supercharger |
12-15-2018, 11:32 PM | #36 |
Drives: 2017 Super Sport Cam. Join Date: Feb 2018
Doesn't matter to me one way or the other.
12-16-2018, 12:39 AM | #37 |
Drives: 2018 1SS 1LE & 1973 Datsun 240Z Join Date: Sep 2015
I don't miss the hand brake at all. I grew up driving RWD cars in the snow. If I wanted the car to rotate more, I just stepped on the gas. I only ever needed a hand brake to get FWD cars to rotate.
That said, I do wish there was a light built into the toggle that would come on and stay on to verify it was engaged. That, or just have the toggle latch in an obvious UP position to make it clear that it's on. Then pull again to release. I do check the dash light, but sometimes I forget when I'm in a hurry, and I have to waste time turning the ignition back on to double check. |
12-16-2018, 01:14 AM | #38 |
Drives: 2019 2LT 2.0T M6 Riverside Blue Join Date: Jan 2018
I like the functionality, I just hate where the button is and how it works. You have to awkwardly pull you hand back to touch it, and then it just doesn't seem intuitive to pull back on it to set it.
I think it would work much better as a normal button positioned more forward in the cabin where you can see it. And "push" to activate, "push again" to deactivate with a visual indicator on the button to indicate whether it is engaged or not. |
12-16-2018, 05:30 AM | #39 | |
Drives: 2017 Camaro SS Join Date: Nov 2018
I have no issues with the E Brake. In fact, I prefer it to using a pedal or lever. Welcome to the 21st century.
Kevin
Luceo Non Uro |
12-16-2018, 06:52 AM | #40 | |
Drives: '19 2SS M6. Join Date: Aug 2018
Pull up to set, push down to release. Seems intuitive to me. Or forget it and start driving off and it releases automatically.
2019 2SS, Shadow gray, 6mt, NPP, Magneride, Bose.
12-16-2018, 08:30 AM | #41 |
Agreed, I have no problems operating the thing either. A small "engaged" status LED would be very nice, though. Say, something similar to the steering wheel heating on/off button.
12-16-2018, 09:29 AM | #42 | |
Drives: 2017 2SS A8, 2018 Macan GTS Join Date: Sep 2017
