08-25-2018, 10:36 PM | #1 |
Drives: '11 SGM 1LT/RS, '02 SOM Firehawk Join Date: Jan 2014
V6 Ice/Snow mode?
My 2011 RS got totalled at the beginning of the month. I'm going to be buying a 2LT 1LE as a replacement. I'd love to get the V8, but it would have to be the 2SS, and I just can't swing the cost. Anyway, I test drove a V6 Camaro with an auto at my local dealer first. Then I test drove a 2SS 1LE and a 2LT 1LT back-to-back at another dealer. I noticed something very strange.
The 2SS 1LE and the non-1LE V6 Camaros have an Ice/Snow Mode setting, but the V6 1LE did not. Why not? If the V8 has it on the 1LE, why not the V6?
Yippee38
08-26-2018, 10:52 AM | #2 |
Drives: 2017 Summit White V6 1LE Join Date: May 2018
I didn't know the non 1LE V6 have a snow/ice mode. I can tell you my V61LE doesn't. Interesting. Gonna keep an eye on this thread. Thanks for posting this.
08-27-2018, 12:25 AM | #3 |
It's weird. Isn't it?
Yippee38
08-27-2018, 12:45 AM | #4 |
Drives: 2024 ZL1 M6, 1969 Cessna Skylane Join Date: Jun 2018
My 2LT has it. With the M6 I'm not really sure what it does. I assume it alters how the traction control operates.
08-27-2018, 11:02 AM | #5 |
Drives: 2LT/1LE, HPCRX, F250(tow vehicle) Join Date: May 2016
My 2LT 1LE does not have it.
2017 2LS 1LE
'I feel that life is measured in achievement, not in years alone' Bruce McLaren |
08-27-2018, 03:59 PM | #6 |
08-27-2018, 08:05 PM | #7 |
Drives: '17 Camaro 2SS & '99 Camaro Z28 Join Date: Feb 2014
My 1LT non 1LE V6 had snow / ice mode.
My non 1LE 2SS has it as well. It is kind of odd that it is in the SS and not in the V6... I can come up with a theory fairly easily but I can't confirm any truth to it. My theory is that those purchasing the 1LE model (both V6 and V8) were purely enthusiasts enticed on using the car as intended on a track, sure daily driving would be in the mix as well, but it isn't an intended beater. That stated, I believe the 1LE V6 came out after the 1LE SS. The SS likely had the software and hardware available to keep Snow / Ice Mode probably to a decree derived from the SS. The V6 on the other hand may have underwent a different process and the same hardware / software is not avai -- forget it... I don't know. |
08-27-2018, 08:38 PM | #8 |
Drives: 08 Tiburon GS, 2018 Camaro 2.0T Join Date: Sep 2017
Ice snow mode will make the gas pedal almost unresponsive. Full throttle is same as only giving 1/3 of gas in normal mode. As if you were starting from a lower gear. It helps you not slip.
I won't use my Camaro during winter so no need for that mode.
2018 Camaro LS | 6 spd | 2.0L turbo | Nightfall Grey | RS package | Technology Package.
--------------------- Order WDGHKX 1100 - 5/08/2018 | 3800 - 6/18/2018 2000 - 5/09/2018 | 4200 - 6/21/2018 3000 - 5/28/2018 | 5000 - 6/27/2018 6000 - 6/29/2018 |
