Old 01-14-2020, 11:02 AM   #15
Rayvan
Rayvan
Drives: 2018 1SS1LE, Silver Ice Metallic
I can get a 4.6, w/traction cont. on, but I've probably got a bit better traction than you.
Rayvan is offline   Reply With Quote
Old 01-14-2020, 12:26 PM   #16
ThirdGenNut
ThirdGenNut's Avatar
Drives: 2020 LT1
Originally Posted by Umbriel View Post
Does the LT1 not have the timers in them? I would use those before an OBD2 timer, those things are not accurate.
It does have the 0-62 timer but its a major pain in the ass to operate.
I have only got it to work in doubletap mode.
ThirdGenNut is offline   Reply With Quote
Old 01-14-2020, 02:48 PM   #17
Bohanan23
Drives: 2016 Camaro 2SS A8
I feel like this is a troll post. they run 1/8 mile's in 7-8's.. A newb could 0-60 in the 4's
Bohanan23 is offline   Reply With Quote
Old 01-15-2020, 08:59 AM   #18
RobbyBeefcake87
RobbyBeefcake87's Avatar
Drives: 2018 Camaro SS 1LE
I was messing around the other day trying to beat my best times and accidentally left TC on in touring mode and got a 4.3 0 to 60 run in my m6 ss, not my best but better than my usual. This 6.9 is hard to believe, I know I have 305s vs your 245s but still
2000 Miata - aventi storm wheels, roll bar.
2019 Mustang GT pp1 - svt pp2 wheels, mbrp cat back, sync 3 upgrade, p1x procharger + stg2 intercooler.
2018 Colorado zr2 - zr2 sport bar, showcase spare tire.
2018 Camaro SS 1LE - GM cai, black bowties, suede knee bolsters, 1le plate frame, black fuel door, dark tails + 3rd brake light, euro side markers + led's, GM all weather floor mats, velossatech big mouth, GM strut brace.
2017 Corvette Grandsport (sold) - untouched.
2006 GTO (sold) - iat relocation, air box mod, monero side marker lights.
RobbyBeefcake87 is offline   Reply With Quote
Old 01-15-2020, 09:03 AM   #19
RobbyBeefcake87
This.
Old 01-15-2020, 09:05 AM   #20
RobbyBeefcake87
The car timer is hard to operate? Maybe they're different but it's quite easy on the ss, set it and when you're ready hit start then go when all set.
Old 01-15-2020, 10:05 AM   #21
lgarrison34
lgarrison34's Avatar
Drives: 2017 SS 1LE HBM, 2010 SS FBO/Cam
chirpin gears and pullin brodies gets em every time.
Classic Joe Dirt
lgarrison34 is offline   Reply With Quote
Old 01-15-2020, 03:43 PM   #22
ThirdGenNut
Drives: 2020 LT1
Going to pull the car out tonight and try to find a road to test the timer.
Old 01-15-2020, 03:52 PM   #23
lgarrison34
Turn traction control off, rev it up to ~2,700 RPM and feather the clutch.
Old 01-15-2020, 04:34 PM   #24
ThirdGenNut
Drives: 2020 LT1
Okay just ran a 4.8 using the dash timer. Smokey launch with TC on. Every asshole in my neighborhood was in their front yard. At least 4 fat women waddled into the street to shake their fingers at me.
Old 01-15-2020, 04:38 PM   #25
ThirdGenNut
Drives: 2020 LT1
I found the timer works best if you drive around with "reset" highlighted.
Then just hit select when the opportunity comes up.
Old 01-15-2020, 05:12 PM   #26
Umbriel
Drives: 2016 Camaro SS
That sounds more like the way it should be.
Sent from my SM-G955U using Tapatalk
Umbriel is offline   Reply With Quote
Old 01-16-2020, 07:12 AM   #27
Fraxum
Fraxum's Avatar
Phew, I was ready to cancel my LT1 Order.
OP Take your LT1 to a track and see what you can do. The lighter car should make up for a little less traction. But if the GM bog is there in the 2020s there is that to try to overcome. Chevy says the right clutch modulation can minimize the effect, but I never found it. :(
Old 01-16-2020, 07:14 AM   #28
Fraxum
Fraxum's Avatar
Dude! Find a deserted road. Or at least prep your street. And don't ever mess with big momma.
