01-04-2020, 01:31 PM | #15 |
Drives: 2017 1SS Hyper Blue Join Date: Apr 2017
You might want to consider your long term build goals. If you are considering supercharging in the future, this might be a good time to spend the money on forged internals. Just a thought.
01-04-2020, 08:19 PM | #16 |
you need a thread chaser or you could crack the block torquing the bolts down. M12 x 1.75 https://arp-bolts.com/kits/arpkit-de...?RecordID=3804 then use long q tips https://www.amazon.com/Cotton-Applic.../dp/B00JG1RLPQ and acetone. and thread depth is 2.28" i use the razor blade backwards as in the blade is pointing in the opposite direction as im moving it. that way it cant dig into the solf aluminum. yes use top quality blades. the surfaces have to be clean. for that scratch id be pulling the motor and taking it to a machine shop. rings have broken on stock motors.
01-04-2020, 11:03 PM | #17 | |
Drives: 17 2SS, 8L90, Cam, Heads, E85 Join Date: Dec 2016
01-04-2020, 11:07 PM | #18 |
no you want a chaser. just do a search for arp 912-0008. you will find it cheaper. https://www.summitracing.com/parts/a...hoC5qsQAvD_BwE
01-05-2020, 08:34 AM | #19 |
Drives: Hyper Blue 2016 2SS 6M Join Date: Sep 2017
A crude but fairly effective test can be done by pouring the same volume of solvent into the suspect cylinder and a couple more "good" ones. If the land or ring is broken, the fluid will leak down much quicker in the bad hole. I used that method successfully on several DD, beater cars when working at my cousin's garage back in the day.
Baby Blue
01-05-2020, 09:32 AM | #20 | |
The service manual dosent say to use anything on the head bolt threads, it actually dosent say anything about cleaning the block and head surface for the re-installing the head either haha Also, when I took off my fuel lines I took off everything in one piece including the pump. I did this to avoid having to unscrew the one time use fuel fittings in the middle. However, I read after that you are supposed to loosen the fuel pump bolts just a little on each side. The injectors tips also scrapped a little on the heads when I was pulling the whole assembly out. Has anyone ever had their pump mess up or injectors mess up from not pulling it the way you are supposed to? Last edited by cmitchell17; 01-05-2020 at 09:51 AM. |
01-05-2020, 10:18 AM | #21 |
Dumb Ass Deluxe
Drives: A Tricked Out Mountain Bike Join Date: Jun 2019
Like King said... the surfaces need to be C-L-E-A-N... As in "eat off it clean".
Wipe it down with acetone and change sections of the rag to get the oil, etc. off when it is scraped clean. There are a lot of things the manual won't spell out, but need to be done if you want it to live trouble free. |
01-05-2020, 10:28 AM | #22 | |
2016 NFG 1SS A8
01-05-2020, 11:00 AM | #23 | |
01-05-2020, 12:13 PM | #24 | |
Baby Blue
01-05-2020, 08:08 PM | #25 |
I am assuming the new stock head bolts (or which ever ones TSP provides) will come with some type of locking compound on the threads. I'm also assuming you are supposed to lubricate (using oil or maybe WD-40) under the flange on the bolt in order to achieve the correct torque spec? I don't see this listed but I know the torque value is highly dependent on the friction on both the threads and the flange/washer surface.
Thanks again for everyone's help |
01-05-2020, 09:32 PM | #26 |
the stock head bolts will have thread locker on them. they go in dry. do not oil them.
01-06-2020, 06:14 PM | #27 | |
Also out of curiosity why would they make the one random hex head different and only on one side of the motor? |
01-07-2020, 12:09 AM | #28 |
it says in there 3 passes. 1 for bolt 3 1 for bolt 4
