Old 09-04-2018, 05:57 PM   #29
TRZ06
TRZ06's Avatar
Drives: 22' Porsche PDK GT4
Originally Posted by Provoste View Post
Yes: better turn in, more grip. Excellent straight line stablity with 0 to -.08mm toe OUT up front. No, it doesn't follow road camber any worse than -2. Not twitchy.
Cool, thanks.
When I get my ZL1 1LE solid rear cradle bushing put on next week, I am going with the track alignment, even though I only drive on the street.
I do a fair amount of canyon carving and on/off ramps, and with only 2K miles on the car, I can already feel a little drop off in front end grip compared to when new because the outer edges are wearing faster that the inner edge.
I want that grip back and the tires to wear more evenly, however I don't want it darting all over the freeway.
Current:
Previous:
09' C6 Z06
08' E90 M3
06' 335i (KW V2 Coilovers)
03' C5 Z06
Old 05-11-2019, 06:39 AM   #30
y2khardtop
Drives: Corvette, Cayman, Silverado
can anyone confirm the size of this bolt...10mm or 12mm ? I'd like to get a grinding burr close to the correct size. I've looked up the bolt and nuts, but GM doesn't show the actual sizes.
Thanks
y2khardtop is offline   Reply With Quote
Old 05-11-2019, 07:06 AM   #31
Norm Peterson
corner barstool sitter
Norm Peterson's Avatar
Drives: 08 Mustang GT, 19 WRX
What's the wrench size?
Link to a table that cross-references wrench size to nominal fastener size
Norm
Old 05-12-2019, 11:47 AM   #32
y2khardtop
I don't have a car to measure, I'm assisting a friend soon. I'll probably just get a 10mm burr.
Old 05-13-2019, 03:23 AM   #33
wnta1ss
Drives: 2017 Camaro 1SS
Thanks
The strut bolts are a lot bigger than that. The nut was 24mm wrench and the bolt head might have been 22mm wrench? For reference, caliper bolts are 14mm thread and 18mm wrench.
Bring a BFH to knock the bolts out, the splines fit snug in there.
Old 07-04-2019, 11:55 AM   #34
oneplustwo
Drives: 2018 Torch Red SS 1LE with Whipple
Hey folks - how does the bolt for the strut come out? The nuts came off fine but I wasn’t able to get the bolt out. Didn’t want to just pound it out for fear of messing up the threads. I see the BFH comment above but is that really it? No problem messing up the threads?
oneplustwo is offline   Reply With Quote
Old 07-04-2019, 12:01 PM   #35
travislambert
travislambert's Avatar
Drives: '17 ZL1
Yeah, the bolts have splines to prevent them from turning. There's probably a way to press them out, but the BFH works just fine. I don't recall any thread damage on my bolts.
2023 Camaro SS 1LE A10
2023 Camaro ZL1 1LE M6
2017 Camaro ZL1 M6
2016 Camaro SS M6 w/LT4 (Sold)
travislambert is offline   Reply With Quote
Old 07-04-2019, 12:32 PM   #36
Norm Peterson
Maybe thread a nut down on the bolt threads but not so far that the bolt sticks through it. The idea here is to prevent peening over the ends of the bolts or screwing up the threads if you miss.
Norm
Old 07-04-2019, 07:18 PM   #37
oneplustwo
I'm at -2.0 at the moment and have pretty severe outside wear (About 4 track days at Sonoma within 5000 miles total). I've read others have had good experience at about -2.9. Seems about right to me based on the wear pattern plus the fact that I get some understeer in the slower corners. Any counter arguments?
Old 09-30-2019, 03:58 PM   #38
Chevy1LE
Chevy1LE's Avatar
Drives: 2019 Camaro SS 1LE
Thanks for posting this. Excellent Easy Mod for folks who track. Will improve bite and save rubber.
Had been killing the outside edges maxed out.
Very happy with these alignment numbers.
Chevy1LE is offline   Reply With Quote
Old 01-23-2020, 05:17 PM   #39
carguy55
carguy55's Avatar
Drives: 2018 1SS 1LE
Working this mod now. This BFH from Wally World worked great getting those bolts out.
carguy55 is online now   Reply With Quote
Old 01-23-2020, 09:47 PM   #40
Provoste
Provoste's Avatar
Drives: E46 S54 race car, 964C2
Exactly. Camber plates are completely unnecessary if you ask me. 32k miles on my car now and my car feels like new still (with 10k+ track miles, many with slicks), did this mod @ sub 5k miles, no issue whatsoever. GM knocked it out of the park with our cars.
Provoste is offline   Reply With Quote
Old 01-27-2020, 04:40 PM   #41
carguy55
carguy55's Avatar
I calculated you need to enlarge the slot about .03" to get 0.4 more degrees of camber? How much did you guys remove. I'm thinking .05" to be safe.
Old 01-27-2020, 09:36 PM   #42
Move_Over
Drives: ISO ss 1le
I did about 2mm to get -3.1 before camber plates. Only reason i got camber plates was to run 18” wheels with a reasonable (5mm) spacer. For those who run 19 and 20” this is great, i had to do both.
Move_Over is offline   Reply With Quote
