Old 11-19-2022, 12:31 PM   #1
SOCAL.M6.ZLE
Having FUN in the SUN...
SOCAL.M6.ZLE's Avatar
Drives: 2022 M6 ZL1 1LE
RED SPARK PLUG WIRE BOOTS ???
Hey guys... So if you have been following my build, you saw that I decided it was important for my valve covers and spark plug wire boots to match!
In doing so, i purchased a set of 2,500F boots from trusty old AMAZON and after 3-4 data log sessions, they are turning black and im worried they are going to melt and catch fire... thoughts?
Also, anyone found a brand that wont turn black?
Or do i need to put vanity aside and get some proper titanium versions from Katech or others?
2022 M6 ZLE: Katech CNC Ported Blower + Ported Heads + 103mm TB + Oil Pump + C5R Chain + Valve Covers + Coil Relocation
TSP VVT and DoD Delete Covers + LME Chain Guide + DSX Billet Lid + ATI Damper + 9.17" Lower + 2.4" Upper + MM Wild CC
Coated ARH + AWE Touring + Magnaflow Center X + E85 + MSD Coils + Banks iDash + JMS Booster + Synergy Fender Tank
ALL the RED Rear End BMR Goodies + JRE Terminator Cam Package + Remote Tuning and Moral Support from TED @ JRE
BMR Motor Mounts + DMS Front HX + FIC 30's + APEX SM.10's + 305/345 R888R's = 770rwhp 785rwtq @E50 13.5psi
Old 11-19-2022, 03:14 PM   #2
AZIROC
Drives: '86 IROC-Z '18 ZL1
Out of curiosity.... coated or uncoated headers?
Old 11-19-2022, 05:00 PM   #3
SOCAL.M6.ZLE
Coated...
Old 11-19-2022, 06:07 PM   #4
SHE'Z 18
SHE'Z 18's Avatar
Drives: 18 ZL1 - M6
Following this thread. I’m in the beginning stages of my build. BTW, where did you get your coils/wires from? Looks perfect
SHE'Z 18 is offline   Reply With Quote
Old 11-19-2022, 06:14 PM   #5
SOCAL.M6.ZLE
Thank you, I like them also (minus the burnt boots) I got the coil relocation kit and cables from Katech, and the MSD coils off Amazon. My build thread is here, if you want to see more...
https://www.camaro6.com/forums/showthread.php?t=609588
Old 11-19-2022, 06:36 PM   #6
20Bluezl1
I used the MSG wires and the heat burned right through one wire. Yes my headers are coated with Swaintech which is one of the best and the wires where not touching the headers. I switched to Granatelli wires with boots and they are great.
https://granatellimotorsports.com/i-...1811htblb.html
Old 11-19-2022, 07:02 PM   #7
SOCAL.M6.ZLE
Thank you
Old 11-19-2022, 07:16 PM   #8
Joshinator99
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
Another vote for Granatelli wires here. They’re very nice and work mint.
Old 11-19-2022, 07:37 PM   #9
SHE'Z 18
SHE'Z 18's Avatar
Drives: 18 ZL1 - M6
Are you guys using wire protectors in addition to the Granatelli wires? Or, are those wires rated for extremely high temps? Thanks
Old 11-19-2022, 08:36 PM   #10
Joshinator99
The top of line ones come with the additional fire sleeves. Not cheap but I’ve been running them for a year and a half with zero issues.
https://granatellimotorsports.com/i-...%7Cyear%3D2017
Old 11-20-2022, 07:02 AM   #11
Smokin19
Drives: 19' ZL1 A10, w/pdr
I switched to Granatelli wires with my build because of the zero resistance they provide. Not running any boots and don't feel I need them. My headers are not coated either.
BTR Stg II cam w/ 38% fuel lobe, ARH 2" headers into 3" w/cats, AWE Touring, Kong X port, Weapon X triple ht exchangers, NW 103, Rotofab big gulp, DSX lowside, TCM tune, BMR Lockout, Mustang dyno 720 rwhp, 634 rwtq on 93 pump.
Smokin19 is offline   Reply With Quote
Old 11-22-2022, 07:49 PM   #12
45LongColt
45LongColt's Avatar
Drives: 2018 Zl1 Camaro
I have the DEI Protect-a-boots from Phastek and no issues so far with scorching through.
45LongColt is offline   Reply With Quote
Old 11-22-2022, 08:41 PM   #13
JSH
JSH's Avatar
Drives: '20 ZLE
To each his own. I view mine as a tool that's all about function and will never see a car show, but I keep the exterior nice.
'20 ZL1 1LE A10,
OEM short block, LME heads/valve train, E2650.
100+ octanes, no eth, no meth, no N2O.
2/23 - 1031/1004 wheel.
4/23 - 1.41/9.61/145 at DA 7000 ft. (only made five passes).
2/24 - LME 390, E2650, FBO, 100 oct.; 1116hp/ 1063tq; 109 oct. dyno next.
Old 11-22-2022, 09:49 PM   #14
20Bluezl1
I hear you My car is definitely not a show car it's a track car bearly drive on the street but I want the best I could afford that works flawlessly.
