06-13-2022, 12:34 PM | #1 |
Drives: 2019 Camaro SS Join Date: Jun 2022
Cam phaser lockout?
Looking at some of the upgrade packages offered by various tuners, I see many of the cam or cam+heads builds include (require?) a cam phaser lockout.
Call me crazy but I thought one of the keys to the amazing low-end driveability AND high-RPM power at the same time of the 6.2L LT1 was the variable cam phasing on the stock motor? Why would you want to do away with this? I get that a radical cam might be too difficult to accommodate, but I'm seeing this lockout on mild (<100hp gain) NA build packages. Clearly not all-out race stuff...so why the lockout? This feels like going backwards in technology just because it's the easy choice. My last ride ('96 Camaro SS) had a big, lumpy aftermarket cam and made great top-end power. It also idled poorly which made daily driving in traffic annoying. I'm hoping there are options where this can be avoided with today's technology? These guys (https://www.texas-speed.com/p-4312-t...-camshaft.aspx) seem to have done it. |
06-13-2022, 05:48 PM | #2 | |
06-13-2022, 08:03 PM | #3 | |
Drives: 22 2SS 1LE Join Date: Mar 2022
OP, sorry I do not have a good answer to your question, I've been wondering the same thing. The link you posted mentions the constantly changing piston to valve clearances as the main challenge, which makes sense with more duration AND lift with an aftermarket cam. |
06-13-2022, 08:38 PM | #4 |
Dumb Ass Deluxe
Drives: A Tricked Out Mountain Bike Join Date: Jun 2019
It has to do with VTP clearance.
Higher lift and longer duration mean that, at the extremes of VVT, there can be contact.
06-13-2022, 09:32 PM | #5 | |
06-13-2022, 10:04 PM | #6 |
Drives: 19 Chevrolet Camaro 2SS 1LE Shock Join Date: Apr 2020
I don't mod my cars, but I do remember reading about VVT on LT1.
Aren't there limiters that can limit how much the cam can phase if the lift and valve/piston kissing ends up being an issue? Supposedly, stock ECU isn't even using up the physical phasing limit of the VVT system. I do recall there is an HP limit on when VVT will fall apart since the phasing is supported by oil pressure. Basically, the actual cam and the sprocket/timing gear are kept apart and regulated by oil pressure, so at high HP, the force on the gear will be greater than what the oil pressure can provide which will cause issues.
Current:
2019 Chevrolet Camaro 2SS 1LE M6 Shock GM Performance Intake and that's it, because driver mods before car mods Past: 2009 Mazda RX-8 GT M6 Velocity Red Mica (Sold) 2015 Chevrolet Corvette Z51 2LT M7 Velocity Yellow Tintcoat (Flood totaled) |
06-14-2022, 01:59 PM | #7 | |
06-14-2022, 08:23 PM | #8 | |
Having FUN in the SUN...
Drives: 2022 M6 ZL1 1LE Join Date: Jan 2022
I dont think anyone is comparing CAI/LT to a cam...as a phase.1 step. I can only speak for LT4's but it looks like most guys are starting with bolt ons... getting use to the power bump... then a cam makes sense for the lumpy idle, HP gain and 38% fuel lobe, which gives your high side another 100rwhp +/- or headroom for more boost, or E. As for the VVT phaser lockout... i will be doing the Katech VVT delete and using the LS3 sproket.. see below.
2022 M6 ZLE: Katech CNC Ported Blower + Ported Heads + 103mm TB + Oil Pump + C5R Chain + Valve Covers + Coil Relocation
TSP VVT and DoD Delete Covers + LME Chain Guide + DSX Billet Lid + ATI Damper + 9.17" Lower + 2.4" Upper + MM Wild CC Coated ARH + AWE Touring + Magnaflow Center X + E85 + MSD Coils + Banks iDash + JMS Booster + Synergy Fender Tank ALL the RED Rear End BMR Goodies + JRE Terminator Cam Package + Remote Tuning and Moral Support from TED @ JRE BMR Motor Mounts + DMS Front HX + FIC 30's + APEX SM.10's + 305/345 R888R's = 770rwhp 785rwtq @E50 13.5psi |
06-14-2022, 09:02 PM | #9 | |
06-15-2022, 01:11 AM | #10 |
Drives: 2018 Camaro SS 1LE Join Date: Jul 2018
I understood it to be about spring pressures. High spring rates (due to the upgraded camshaft) will result in the phaser no longer working as designed.
Cam Motion recommended mine to be locked out as well...not an overly large camshaft either.
06-16-2022, 09:42 AM | #11 |
Drives: 2019 ZL1 1LE Join Date: Jun 2022
When I did the cam in the Denali, I ordered the kit from TSP. It came with a complete lockout and I believe an 8 degree swing. I put in the 8 degree cuz it was only a stage 2 cam. The first time I sent the ECM out for tuning they tuned out the VVT completely. It was a total pig off the line. Sent it back and told them I had the limiter in it and not the lockout, so he retuned accordingly. It was a nite and day difference. I’m a big believer in keeping the VVT if you possibly can.
06-16-2022, 05:32 PM | #12 |
Drives: 2019 Camaro 1LE Shock Candy Join Date: Mar 2016
You mainly use a phaser lockout in a high horsepower builds and especially with high cylinder pressure that require you to prevent the VVT retarding your timing.
VVT will change the cylinder's ability to build pressure, camshaft timing is then retarded, the intake valve will close later usually sometime during the compression stroke. This will cause a drop in cranking compression and that hurts low-rpm power. There is obviously pros and cons about either limiting your VVT timing swing or totally locking it out. It really depends on your builds. My first build with the Lt1 Gen 5 engine I used a phaser limiter and this build it was recommended by my builder to lock it out.
103 Katech TB, KATECH Custom Heads, DSX In-line fuel TSP Headers, Spec P Super Twin Clutch, TSP EL C7 CAM Diamond Piston & Manley Rods, Roto Fab Big Gulp BTR Push Rods,LS7 Lifters, ARP, FI Chiller, Kirkey Seats SJM Line Lock, Hurst Pistol Grip. 747/739 RWHP street tune - 821/794 RWHP track tune 101 octane. 2014 Mini Cooper countryman S All4 M6 daily driver |
