08-12-2021, 12:29 PM | #1 |
Rayvan
Drives: 2018 1SS1LE, Silver Ice Metallic Join Date: Dec 2018
Front SS wheel Fitment, on SS 1LE.
Does anyone know, will a 20" *front* wheel from a 1SS or 2SS would fit both the front, *and the rear* of a SS 1LE?
Back story: Recently I had to abandon my car because of a rear flat. Big screw sticking out. Red flashing warning came on, and I had just a minute to find a safe spot. Tire lost pressure fast. It sucked. I refuse to use the can-of-goo that the car came with. Seems like it would make a mess of the wheel. If it was in a really bad spot, I would have towed it. Instead, I Uberred home, grabbed my floor-jack, a jack stand and a few tools, threw them in my truck, and drove back. I removed the flat rear, left it on a jack-stand, and left to have the tire fixed, all the while worried about my abandoned car. This all took about six hours, total. I was lucky nothing happened while it was left there, but it got me thinking about a spare just to have around so I can just get the car home if it happens again. |
08-12-2021, 12:31 PM | #2 |
not sure but my buddy had this he tried to sell me one and i said pass lol
https://modernspare.com/product/2016...including-zl1/
08-12-2021, 12:52 PM | #3 |
Shadow Gray '19 ZLE M6
I don't have an answer for your wheel fitment question, but it is probably worth keeping a tire plug kit in your car (e.g. https://www.amazon.com/Slime-1034-T-.../dp/B000ET525K). Wouldn't be right for every situation, but it sounds like it would've saved you with the situation you faced.
PPF | Paint Correction | ZL1 Addons Rock Guards | ZL1 Addons Lift Pads | ZL1 Addons Feather Lite Tow Hook | JWM Smoked Sidemarkers | Wildhammer Smoked Rear Reflectors | JWM License Plate LEDs | RotoFab CAI | ADM IC Reservoir v2 | BC Forged RZ05 | SPL Toe Arms | BW Brake Deflectors | CMS Roll Bar | Schroth Profi II ASM Harnesses . Sold: '99 Trans Am (bolt-ons & cam) | '00 WS6 (bolt-ons, heads, cam, 12 bolt) | '05 CTS-V (bolt-ons, short throw) | '10 SS/RS M6 (short throw, CAI, coilovers, LTs, catback, JRE tune) | '01 WS6 YouTube |
08-12-2021, 12:53 PM | #4 | |
Rayvan
I was thinking of buying someones curb-rashed 20" SS front wheel for cheap, then just putting a cheap 245 tire on it. Don't know if it would fit the back of the 1LE though. Anyone know? |
08-12-2021, 01:02 PM | #5 | |
Rayvan
I wouldn't trust a plug in these tires at the track (or the goo). The guy I had fix it uses Good-Year's specifications to fix the tire correctly so I don't lose my speed-rating. I was thinking of buying someones curb-rashed 20" SS front wheel for cheap, then just putting a cheap 245 tire on it. Don't know if it would fit the back of the 1LE though. Anyone know? |
08-12-2021, 01:04 PM | #6 |
thats the hard part with a staggered setup may fit front but not rear on my old car i ended up buying a square setup and had a spare/wheel tire i just kept in my trunk lol you could do that but it would be $$
08-12-2021, 02:07 PM | #7 |
Rayvan, I just bought a set of used LT1 wheels last week (basically SS fronts for the front and rear on the LT1). It is my understanding that they will fit.
My logic is this: The LT1 trim cars use the SS front wheels on the front and back(20x8.5 +25mm) The LT1 and SS cars will fit the front 6 piston Brembo kit from GM which is standard on the SS 1LE cars. I can't think of a reason that the wheel/tire combo wont fit. Someone please correct me if I am wrong. I will confirm this when temps start to drop here in Indiana and I wont be able to run my SC3 tires. BK |
08-12-2021, 02:28 PM | #8 | |
Rayvan
I know the LT1 cars use different rear brakes than the SS/SS 1LE cars do, but if they use four SS fronts, I think I'm in bidness! Thanks for the insight! |
08-12-2021, 02:45 PM | #9 |
Rayvan
Anyone have any curb-rashed front SS, or LT1 wheels for sale?
