03-05-2020, 03:28 PM | #1 |
Drives: Zl1 Camaro Join Date: Nov 2019
Injector Timing
Trying to build my understanding of tuning injector timing but hitting a snag. I'm looking for the stock cam specs for a 2013 ZL1. Cam PN#12623064
Specifically what is the advertised intake/exhaust duration on this cam? Also what is the intake center-line? Any and all help is appreciated. |
03-11-2020, 12:04 PM | #2 |
Drives: 2010 1SS LS3 Join Date: Aug 2019
I wouldn’t look too much into the stock injection timing, GM does a good job there. Look at it when you install a new cam and supporting mods. Remember, if you change injection timing, your fueling will be off and you will need to retune.
2010 CGM 1SS
408/4L80E/ZL1 ESS G4 |
03-11-2020, 01:17 PM | #3 | |
Captain Gingerbeard
Drives: 2012 IOM RS/SS 6MT Join Date: Feb 2013
Injector timing is much more a thing when you're talking about a direct-injected engine. Our port injection is usually just fine from factory.
Custom ordered 2012 6MT RS/SS on 11/25/2011. Picked up 01/31/12.
Pedders Coilovers, BMR trailing arms and toe-links, Prothane solid poly subframe bushings, JDP Motorsports rear upper control arm bushings, Texas Speed long-tube headers with 2" primaries, modified fully 3" Magnaflow competition catback. CAI cold-air intake. DBA rotors, Hawk pads. Quote:
03-11-2020, 03:02 PM | #4 |
fo'shizZL1
Drives: 2017 ZL1 Join Date: Aug 2017
You can definitely use it to get rid of raw gas smell at idle with a cam. I can vouch for that one personally.
There are mixed opinions, some with data and some without, regarding injector timing throughout the rev range. There are many good threads over on the hpt forum on the topic. Most end up delaying timing. Max EOIT is usually suggested at no closer than 30-45 degrees prior to EVC event.
2017 ZL1 M6 Black | Maggie 2650 // 103TB // Big Gulp
Past Rides- 2014 ZL1 M6 Red Hot | Tons of mods 2004 CTS-V M6 Silver | Many mods 1995 Corvette M6 Torch Red | A few more mods 1992 Camaro M5 White | A few mods |
03-11-2020, 03:54 PM | #5 |
Served USN - Atomic Chimp
Drives: 13 Camaro LSX434 TT M6, 21 ZLE A10 Join Date: Jul 2012
I've messed around with the EOIT on my LS3 with BTR Stg 3 turbo cam and thought I had it pretty good. Now, I've tried with the LSX and a custom grind (probably stg 3-ish) and I'm not sure what kind of advantage/disadvantage I've received. I don't have smelly gas exhaust. My mileage sucks (not sure if that's me, the 427cid, the cam or the EOIT settings). I've played with some Excel spreadsheet calculators (they're in Greek) and tried to dial in the timings. I'm not sure if I did any good or made things worse. I might should resort back to stock settings to compare...
In excess of 1,000WHP LSX434 | AGP 65/65 TT | BTR Equalizer Intake | Trickflow 245cc cathedral | BTR custom cam | Cortex EBC | n2mb WOT | ID-1700x | Brisk GR12S | RPM Lv 7 TR6060 | AGP's Triple 525LPH Fore Fuel | Monster LT1-S Triple | 4.11 DSS Proform 9", CF driveshaft, 1400hp axles | Hurst Line Lock | MGW Retro Short Throw w/old skool Hurst T-handle | ADM solid subframe mounts | Prothane Motor Mounts | Revshift Poly Trans insert | Moreno camber/caster plates |
03-11-2020, 08:46 PM | #6 |
I used the calculators and I think it is dead nuts on. No cats, no smell, revs faster, easier to dial in -1 to-2% trims. I bet it’s much harder on a large cube engine. I did find using the temp table along with the boundary and zero out the rpm did the trick. The spreadsheet is a work of art! I would love to see how those complicated calculations are made.
2010 CGM 1SS
03-12-2020, 02:04 PM | #7 |
Thanks guys for all the helpful info. Found a couple good threads on the hptuner forums that helped me make more since of it.
