06-23-2021, 01:12 PM | #1 |
Drives: 2013 Camaro 1LE Join Date: Jul 2012
Selling an Essex/AP Racing Radi-Cal Big Brake Kit - 9668/372mm kit
Since this is a BBK for track use I thought I would cross post this here incase anyone is looking for an awesome road course brake set up.
My kit is specifically for a 5th gen BUT the calipers and caliper mounting brackets are the same part numbers for a 6th gen so it could be mounted on a 6th gen as well. The 372mm rotor rings are the same for any kit using 372mm rotors. The only two parts that would be different for a 6th gen are the rotor hats and the brake lines. So you would just need to order a set of brand new rotor assemblies from Essex (or any Essex dealer) for a 6th gen Camaro so you would get the correct rotor hats with it, and you would need to order a set of 6th gen brake lines. So you could get the basic kit and I am willing to discuss removing some of the extra parts I've include to reduce the selling cost for a 6th gen owner since the extra rotor hats would not do them any good. The rear brake pads I have are the same fitment for ZL1 and ZL1 1LE cars, but for some reason GM decided to put different rear calipers on the SS model cars. So the rear pads I have will not fit SS or SS 1LE cars. Full ad with pics can be seen here: https://www.camaro5.com/forums/showthread.php?t=593484 I sold my car in February and do not need this brake kit anymore. It doesn't fit the replacement vehicle I purchased.
