06-18-2021, 01:07 AM | #1 |
Chief Bief
Drives: Nightfall Gray Camaro 1SS Join Date: Dec 2015
Wiring harness/fusebox help
Below are pictures showing my fusebox and harness in the trunk of my car. my weather stripping failed and the standing water in the trunk got to my fusebox. I now have the wiring harness connectors and fusebox to replace. I am asking if there is anyone that can assist me getting the part numbers for said parts since I'm underway and cannot go to a dealership for this. any help would be appreciated.
2016 NFG 1SS M6 JLT Intake, LT2 Manifold, LT5 TB, CSP 2" headers, AWE Catback Exhaust, Apex ARC-8 Wheels. 426whp/434wtq |
06-18-2021, 09:09 AM | #2 |
Drives: 2019 SS Join Date: Nov 2019
The thread below should give you a start. The two larger green and blue connectors are part numbers 13594678 and 13594679. You'll need a terminal release tool to de-pin the connector. The official tool for this style connector is J-38125-11A, although you may be able to find a suitable alternative.
When swapping connectors, take pictures before hand and use a connector end-view diagram to keep track. I would also recommend swapping each wire over to the new connector, one at a time, as this reduces the chance of installing it in the wrong place. https://www.camaro6.com/forums/showthread.php?t=592896 |
06-22-2021, 07:09 AM | #3 |
Chief Bief
Bro, thank you very much. This is plenty. Shame that people have to deal with this.
07-13-2021, 10:39 PM | #4 |
Drives: Camaro rs Join Date: Jul 2021
Quick question when that happened to you were you able to turn the car on ? Or nothing else worked ? Because this just happened to me and my car it’s completely dead, I wasn’t even able to unlock it with the remote... I don’t know much about it and I just found out that my rear fuse box wire harness burned out do to water damage....
04-02-2022, 09:39 AM | #5 |
Drives: Chevrolet Camaro 2SS Join Date: Aug 2020
Continue
Hey! Sorry I’m having the same issue! Already bought the 2 connectors and the fuse box, but I can’t find the tool stated above J-38125-11A can y’all put a link for it if possible or what alternatives work? I found a couple but not sure which would actually work for our connectors
Thread Tools | |
