04-05-2021, 09:48 PM | #1 |
Drives: 2016 camaro 3.6 Join Date: Mar 2021
Is this bad, misfire cylinder?
My 2016 camaro v6 has been feeling not normal while driving, so I plug in the obd scanner and saw this. Not sure what it means screen's hoots will be posted below. Anybody can please explain? Thanks
04-06-2021, 03:34 PM | #2 |
Drives: 2017 1LT Camaro Join Date: Jun 2019
Your code reader looks like it is running tests as oppose to providing you with specific errors. Looks to me like your cylinders are passing the test. I could be wrong.
But yes. Driving on a misfiring cylinder can cause you to spend much more money if you don't get it fixed asap. My cylinder 2 is misfiring and the car is driving and idling very rough. It's not just a slight change in driving. It is an absolute noticeable affect to the car. The dealership just called me and said the fuel injector for that specific cylinder has gone bad. They're in the process of fixing now. |
04-06-2021, 07:04 PM | #3 |
How should I proceed with this ? Thanks for your response
04-06-2021, 07:45 PM | #4 |
Long hauler
If you have a CEL then try to read the codes instead of the diagnostics like before. If there's no CEL then there shouldn't be an issue. Maybe something in the suspension is slightly loose?
04-06-2021, 08:40 PM | #5 |
Drives: 2016 2SS Convertible Join Date: May 2012
04-10-2021, 02:20 PM | #6 |
At the moment it is at 55,000 roughly, I've taken it to the dealer for service but all they say is nothing is wrong and just because I say there is doesn't mean they have to do anything.
Thread Tools | |
