Old 07-18-2020, 01:07 PM   #15
overdriv
overdriv's Avatar
Drives: 1969 Chevelle SS 2019 2SS Camaro
Originally Posted by olblue75 View Post
When you say tow bar are you referring to the tow hook??
Yes, the one that threads into the front of the camaro.
In my case, I'm using a ZL1addons tow bar/hook. The one that comes with the car is larger in diameter and no threads in the end, just a loop of round stock.
overdriv is offline   Reply With Quote
Old 07-28-2020, 05:22 PM   #16
funked1
funked1's Avatar
Drives: '23 Hyundai Kona N, '24 VW GTI
Originally Posted by overdriv View Post
Well since no one seems interested, I thought I'd report anyway on how I got the ZL1Addons license plate holder/tow clevis rod to fit into the grille without leaving a large hole in the grille. The size of this hole is big enough to allow rocks, birds, etc get past the grille into the area of the AC condenser radiator, etc.
The results from my modified grille take out leaves the grille intact, closes up the hole that would otherwise left open if the grille takeout were left out.
I like leaving the rod in without the license plate holder because I live in a state that requires all vehicles to sport a front license plate. I like the front of the Camaro without a front plate.
So if I get stopped for no front plate, I may be able to avoid a ticket if I can just go to the trunk and put it on.
The last picture is of the grille takeout installed with the tow rod installed. I have a black cap screw to put in it to protect the threads, not shown, but I think I'll look for some push pins that would could be just pried out with a screwdriver.
Anyway, here are some pictures.
Thanks for posting that!
funked1 is offline   Reply With Quote
Old 03-11-2021, 09:53 AM   #17
Dabjbr
Drives: 2020 SS 1LE
Tracked my car for the first time. Surprised how large the cover is!
I like your approach and plan to copy it. Can I ask specifically what ZL1 tow hook you used and can you confirm the hook (not license plate holder) fits without making contact with the bumper?
Thanks in advance and great post!
Dabjbr is offline   Reply With Quote
Old 03-11-2021, 06:29 PM   #18
overdriv
overdriv's Avatar
This is what I have;
https://zl1addons.com/collections/ca...=8748090196031
Not sure what you mean by "not making contact with bumper", but you will have to modify the grille take out for it to fit with the tow bar installed.
Old 03-11-2021, 06:51 PM   #19
kropscamaro16
kropscamaro16's Avatar
Drives: 2016 1ss camaro
i have same one license plate on streets tow hook on track
Old 04-25-2021, 11:04 PM   #20
Dabjbr
Drives: 2020 SS 1LE
Did the mod this weekend. Thanks OP!
Couldn’t find my dremel so used a hacksaw on the sides and then razor blade on the front edge with a little heat. Lastly, used a curved file to match the curvature of the bar. Came out clean.
I’ll probably just leave the tow hook on permanently.
