Old 06-02-2018, 04:37 PM   #15
Drumbc
Drumbc's Avatar
Drives: 2016 v6 Camaro
Originally Posted by jingaling View Post
Just curious... What kind of gains can be expected with that setup on 91? I don't think I've seen that posted up yet. And have dyno sheets been posted up for the e85? Thanks for all the work you guys are putting in for these cars
I actually am planning to dyno my car on 91/93 Here soon...... e85 has been well fun I would say, will at overkill has been amazing with all his help and tuning expertise...... still working out bugs on e85 and my car has been on it for 2-3 months, it made 310whp yes but I honestly think it would make around 320whp now.....
Drumbc is offline   Reply With Quote
Old 06-02-2018, 05:12 PM   #16
jingaling
Drives: 2016 Camaro 1LT V6 MT
Thumbs up
Nice... I can't wait to see what you post up.
jingaling is offline   Reply With Quote
Old 06-05-2018, 09:55 AM   #17
mano_camaro
IYAOYAS
mano_camaro's Avatar
Drives: 22 1LE 2SS M6 Riverside Blue
Those are pretty good numbers. I have been tempted to get the overkill tune, because if i needed, the ECU can be put to stock right?
i'm just concerned about wait time other members have experienced like waiting 2 months to receive the handheld unit by mail, and any needed updates that can take long to get as well. The price for the overkill tune and a local dynoshop tune is exactly the same at $575.
mano_camaro is offline   Reply With Quote
Old 06-05-2018, 01:39 PM   #18
Dustya
Drives: Overkill Supercharged 2016 CamaroV6
This is true... but Will is a one man show and he is one of the only ones that knows our ECU inside and out. Alos most local dyno's are going to charge to retune.. and $575 seems way underprice considering our cars take $200 in HP tuners credits alone. My local tuner and dyno shop have over 30 hours of tuning on my car and we are still learning.. I was just lucky enough to find someone that is letting me learn with them.
If your looking for a basic tune with the mods you have you might be fine at your local shop but expect to drop some more $$ should you want to retune again with a different mod later.
Also with Overkill you are getting the handheld device which is nice for data logging and clearing codes if you need too.
Not trying to sway you just trying to show you the cons..
Hyperhawk - 2016 Camaro 2LT RS - First LGX in the 12's and 11's Current record holder 11.0@125
Follow me on Instagram https://www.instagram.com/hyperhawkcamaro/
Youtube https://www.youtube.com/channel/UCHR...-ilSpV3gMQnTuA
Supercharged with Overkill Superchargers http://www.v6superchargers.com
Dustya is offline   Reply With Quote
Old 06-05-2018, 10:09 PM   #19
mano_camaro
IYAOYAS
Dustya, Thanks for the reply, i will keep that in mind. you are right, future retunes at the dynoshop would be $125.
Old 06-06-2018, 01:03 AM   #20
BlueVelvetCamaro
Drives: 2016 Camaro SS
Doesn't Gen5DIY have a harness for converting to E85?
BlueVelvetCamaro is offline   Reply With Quote
Old 06-06-2018, 02:10 AM   #21
GhostEye07
GhostEye07's Avatar
Drives: '16 Camaro 2LT RS
E85 Sensor doesn't work on the V6 and I4 ECU. You can do E85 you just can't do FlexFuel or have a sensor read the Ethanol Content
2016 Camaro 2LT RS E85 V6
Build Thread | My Instagram
GhostEye07 is offline   Reply With Quote
Old 06-06-2018, 02:27 PM   #22
BlueVelvetCamaro
Well dang that sucks
Old 06-07-2018, 07:24 AM   #23
Dustya
It definitely does especially when you spend hours and hours testing each pin on the ECU .... because you are determined its going to work.. pretty stupid GM coded in the option to turn disable and enable flex fuel in the software but not allow a pinout for it.
Old 03-28-2021, 01:02 AM   #24
Jamesborg
Drives: 2016 v6 rs camero
Decided to wake this back up I have a Supercharged v6 Camaro and I need to run e85 for the power 91 ain’t cutting it any kits out there yet?
Jamesborg is offline   Reply With Quote
Old 03-29-2021, 03:27 PM   #25
Bumbleboy92
Long hauler
Bumbleboy92's Avatar
Drives: 2022 Camaro 2SS 1LE
Only option is Overkill on full E85 no flex fuel I believe
2022 2SS 1LE - Cold Air Inductions Elite Carbon CAI
2016 1LT v6
- Totaled
Happiness: Infinite
Old 04-01-2021, 05:31 PM   #26
Street Lethal
Tech Anarchist
Street Lethal's Avatar
Drives: GM F-Body's
O2 sensors work in Lambda, the gas and E85 scales are equivalent, just a different reading which is calibrated based on their respected air/fuel ratios. Meaning, just fill it with E85 and go. If a tuner claims he is "tuning" you for E85, all he is doing is recalibrating what your ECU defines as being a stoich reading. But without the tuning, then 14.7 AFR is 9.76 AFR in Lambda. There is more than enough O2 correction for any deviance, but as mentioned, the scales are equivalent.
- Rob
2016 Camaro: 3.6 w/72mm Turbo, Stalled A8, Tuned By Me...
Street Lethal is offline   Reply With Quote
Old 04-02-2021, 05:19 AM   #27
Sinister6
Drives: 2016 LT
- Rob
So run e85 without tune and it'll be fine got it
Sinister6 is offline   Reply With Quote
Old 04-02-2021, 10:34 AM   #28
Street Lethal
Tech Anarchist
Drives: GM F-Body's
Heh, gotta love one hit wonders who hide behind sarcasm. What does Lambda read when running E85 in a gasoline scaled ECU, any idea? Me honestly thinks you don't have anything...
- Rob
