05-24-2018, 10:14 AM | #1 |
Drives: 2013 2SS M6 Join Date: Mar 2018
Does this data log look okay/normal?
After putting a CAI on my car, I took it back to the shop that installed the cam to get the tune looked at and make sure the intake didn't throw anything off.
Later I was curious and decided to data log a short WOT pull and some general driving. I'm no tuner and certainly not an expert on what I'm looking at and what it means, but I found a couple things that seem odd to me. First is the graph of RPM (blue) vs. timing (orange). It's adding 45 degrees of timing at some points. Is that normal? I thought timing was generally in the +/- 20 degrees range. Then it fluctuates between +12 and +35 degrees at the slightest change in throttle when cruising. Then I looked at the Short Term Fuel trims and they're all over the place. +/- 10%. I would expect the 2 banks to be similar, but they're not very close at all. Like I said, I really have no idea what the data I'm looking at should/should not look like. The car is cammed, so that could account for the fuel trims being all over the place.
2013 2SS M6 - Custom cam w/ miscellaneous valvetrain upgrades, ported heads, longtubes, CAI, CTS-VR lifters, Forza NPP exhaust controller - 500hp/460tq
05-24-2018, 12:58 PM | #2 |
Drives: 2012 2SS/RS, 1968 SS Join Date: Feb 2012
What are you using for these graphs? It's hard to say if the car has a knock and the knock is pulling timing on you. Also the car could be commanding a certain timing, while also allowing modifiers, but this chart isn't looking for the modifiers.
+/- 10% is fine, it's not ideal but the car is at least trying to make it up for the changes. I do prefer to see +/- 5% though. Especially when it comes to leaning out. But it looks like when you give it gas it richens, instead of leaning.
LS3 Crate Engine Swap | CSP Custom Cam 232/240 .615/.615 113 +3 | Stainless Power LT Headers | Z28 Intake | Borla S-Type Exhaust | FTI Triple-Disc Billet 3200 Stall
2012 Camaro 2SS/RS | 1968 Camaro SS | 2020 Cadillac CT5 Premium Luxury | 2021 Spark LS |
05-24-2018, 01:25 PM | #3 | |
06-22-2018, 02:28 PM | #4 |
Drives: 2010 IBM SS/RS/Stick Join Date: Jul 2010
You're timing is not solely based on rpm. Actually I think you will see less of a correlation between RPM and timing nowadays than what you would traditionally expect. However there will be a strong correlation between timing and manifold vacuum(throttle position). Your data infers that you let off the gas between shifts and it looks like you take advantage of engine braking when you slow down. Some inputs that play a role are intake air temp, coolant temp, rpm , and manifold vacuum. Not sure what else. As far as your STFT, they work with your O2 sensors and the two will look very similar, all over the place. It is kind of like a self-checking diagnostic tool in the ecm. It is more of a concern when they stay positive (or negative) for long periods of time. This will be an indicator that something isn't right whether it be a faulty O2 sensor, faulty fuel delivery, or whatever.
06-22-2018, 03:45 PM | #5 |
Drives: 2010 Camaro SS/RS Join Date: Mar 2014
did you retune for the intake and what was on the car before that part? if you switched from the stock intake to the CAI you'll want to get it retuned for sure with the aftermarket cam installed
2010 2SS/RS
Z/28 intake, NW, FAST 102, speed engineering LT's, some exhaust, ATI -10% pulley, GM flex fuel injectors, DSX flex fuel sensor, MGW shifter, HP Tuners, some suspension work, stickers and a little weight loss. 12.63 @113.53 |
Tags |
data log, fuel trim, timing, tune |
