Old 08-10-2018, 08:08 AM   #29
Ricco
Ricco's Avatar
Drives: 2018 ZL1 Vert A10
Ok. I need some help on this one Ricco. Today when I went to pick the car up, they said that the headers connect to the race pipes, but from the race pipes back, it doesn't seal correctly. I am assuming that is because I need the midpipe or something?
I need to figure out what we are supposed to do to connect from the LT's back given the additional support under the vert.
Which offroad pipes did you get? They have some that are 3" all the way to connect to an aftermarket mid or they have some that neck down to 2.75" so they connect to the stock mid pipe.
If you have the former, then you either need to exchange them for the latter or get an aftermarket 3" mid pipe. I have the Kooks 3" midpipe and it fits the vert no probs.
2018 ZL1 Vert - 854Whp / 791Wtq
2016 BRZ
2013 X5D
2005 STI
2001 2.5 RS
Previous cars in chronological order
2016 GT350, 2014 MEV Rocket, 2013 Nissan Qashqai + 2, 1.6L Diesel, 2010 Nissan Note 1.5L Diesel, 2012 Dodge Ram 2500 6.7L Cummins, 2009 Subaru Impreza STI, 2005 Dodge Ram 1500, 2004 Mini Cooper S, 1997 Subaru Impreza Catalunya special Edition, 1992 Daihatsu Charade GTti, 1978 Mk1 Ford Fiesta
Ricco is offline   Reply With Quote
Old 08-10-2018, 08:13 AM   #30
Yellow6thGen
18 ZL1 A10 Convertible
Yellow6thGen's Avatar
Drives: White ZL1 Convertible
No problems either with my 16SS or my ZL1 Convertibles.. Heck I’m over 800hp on the ZL1 now and with the Kooks LT, 1000hp CATs and 3” midpies to the stock NPP the sound is amazing I mean from quiet on stealth to sweet race car sounds at WOT...
2018 ZL1 Convertible A10 @ Kooks R&D.
Yellow6thGen is offline   Reply With Quote
Old 08-10-2018, 08:24 AM   #31
Drsagacity
Drsagacity's Avatar
Ok. So, I should have the 3in race pipes which connect to the aftermarket mid. I assume I have the latter because they knew I was connecting to a stock mid...but I am hoping they sent the wrong version and then I just need to get the Kooks mid pipe.
776whp/745wtq (12psi)
2018 Corvette Z06 vert- Black
To be tuned by JRE Racing
TBD performance
Old 08-10-2018, 08:28 AM   #32
Ricco
Ricco's Avatar
Ok. So, I should have the 3in race pipes which connect to the aftermarket mid. I assume I have the latter because it is currently connected to the stock mid.
I wish I had taken some pictures under the car.
I'm going to guess you have the full 3" connection pipes since you said they dont fit to the stock mid and are leaking. I assume your installer just slid the stock mid inside the 3" connection pipe which is why it won't seal.
I'm just guessing though but it seems plausible.
2016 BRZ
2013 X5D
2005 STI
2001 2.5 RS
Old 08-10-2018, 08:30 AM   #33
Ricco
Ricco's Avatar
800whp vert? Please post your details in this thread
Highest HP Vert
2016 BRZ
2013 X5D
2005 STI
2001 2.5 RS
Old 08-10-2018, 03:35 PM   #34
Drsagacity
Drsagacity's Avatar
Highest HP Vert
I was thinking the same thing.
TBD performance
Old 08-10-2018, 03:36 PM   #35
Drsagacity
Drsagacity's Avatar
That was my guess and hope too. That way the answer is simple, get the 3in midpipe.
TBD performance
Old 08-10-2018, 07:52 PM   #36
Ricco
Ricco's Avatar
Have they got it taken care of yet?
2016 BRZ
2013 X5D
2005 STI
2001 2.5 RS
Old 08-12-2018, 08:29 PM   #37
Drsagacity
Drsagacity's Avatar
I have had some other issues I am working on in the short-term. Plus my mechanic is out of the country on vacation so I have to wait until he gets back, or until I can get the car on a lift. I tried putting my camera on a box and sliding it around under the car...but let's just say it wasn't the best quality...so I am not sure if it would be useful.
One thing I can tell you...the car is much louder on startup and much meaner on idle. However, when cruising, because Ted has the RPM's in a different range, the car is much quieter cruising around...AWESOME!
TBD performance
Old 08-12-2018, 09:02 PM   #38
ChadFarr
Instagram: @SSAVAGEVERT
ChadFarr's Avatar
Drives: 2016 SS M6 Vert
I’ve got TSP and Corsa. I’ve had the headers for about a year now. No issues with it being a convertible.
2.9L Whipple | Compstar Rods, Diamond Pistons & GPI Cam | Mantic Triple Disc | Corsa Performance Exhaust | DSX Aux Pump | LT4 Fuel System | BMR Lowering Springs | ZL1 OEM Conversion | 360 Customs Built | And More!
Click & Follow My Build
ChadFarr is offline   Reply With Quote
Old 08-12-2018, 10:14 PM   #39
Drsagacity
Drsagacity's Avatar
I believe the issue comes after the header...getting into the mid pipe and beyond. Several of the vendors don’t offer full exhaust (headers back to mufflers) for the vert. Just didn’t know where the issue was.
I sure would have preferred to keep the headers and included the aftermarket mid pipe...just didn’t know that was an option.
I do have the high flow cats too. They are sitting in my trunk. I believe they are the same size as the race pipes so it’s an easy switch.
TBD performance
Old 08-12-2018, 10:17 PM   #40
ChadFarr
ChadFarr's Avatar
Regardless of Coupe or Convertible, most of the companies do not offer a Catback exhaust for the 6th gen Bc the factory midpipe actually flows pretty well. I am using the TSP off-road cats with factory mid-pipes.
Old 08-12-2018, 10:37 PM   #41
Ricco
Ricco's Avatar
That’s what I wanted to end up with, the ability to swap in the high flow cats if I wanted. My installer said that my midpipe connected straight to my headers though, no connection pipes needed so idk if Kooks sent me a different part or what. I see no mention of it on their site anymore.
2016 BRZ
2013 X5D
2005 STI
2001 2.5 RS
Old 08-12-2018, 10:38 PM   #42
ChadFarr
ChadFarr's Avatar
Kooks has a flange that their cats and mid-pipe connect too. TSP bolts together with clamps.
