Old 05-08-2018, 03:18 PM   #15
1CEBITN
Drives: 2017 Camaro SS Vert w/2SS
Any idea how wide that spare tire is with the cover on it? If it's only 4" then it may fit laying flat under the top when it's down in the trunk. You might have to use some velcro tape to stick it to the floor of the trunk so it doesn't slide around and knock down the trunk divider though. I've been thinking about the same thing, the fix a flat kits don't give me a whole lot of confidence since the last couple of flats I've had have been gashes on the sidewall from pot holes. I wouldn't trust those things to stay in the hole at highway speeds either. Also wouldn't want to have to sit around for 3 days waiting for a tire to show up somewhere on a road trip. AAA and the fix a flat kits will still require you to wait around for a new tire, those aren't a permanent solution like an actual spare tire.
1CEBITN is offline   Reply With Quote
Old 05-09-2018, 06:57 AM   #16
wildchevy
wildchevy's Avatar
Drives: 2018 Hyper Blue 2SS convertible
I put one in my 14 when I owned it and it raised the cover about 2 inches higher than without the spare in place. Not sure if it will be the same on the 6th gen
2018 HBM 2SS CONVERTIBLE A8
wildchevy is offline   Reply With Quote
Old 05-09-2018, 10:50 AM   #17
MANNAXMAN
MANNAXMAN's Avatar
There's just over 8" of space below the top when it's down. See my post here (linked video in post is no longer available).
1996 Camaro Z28 with T-Tops (Sold 10.22.16)
1986 Camaro IROC-Z with T-Tops (Sold)
1961 Volkswagen Beetle with Sliding Ragtop Sunroof (2009-Present)
1964 Volkswagen Beetle with aftermarket Sliding Ragtop Sunroof (Sold)
Follow me on Instagram - @gen6_2ss_vert
MANNAXMAN is offline   Reply With Quote
Old 06-05-2018, 08:11 PM   #18
Drsagacity
Drsagacity's Avatar
Ok. I am not sure when it was delivered, but leaving this morning, a different box in the garage caught my attention. When I got home, pulled it out and checked the trunk...beautiful...the full modern spare kit fits under the top without touching.
I had to unhook the bottom buttons of the divider, but the top went down with no problems. Now I need to figure out a way to hold the spare kit in place so that It doesn’t slide around. Best thing...top up or top down, I have a spare now. I will get some pictures tomorrow. I tried taking one in the garage, but it was too dark...
776whp/745wtq (12psi)
2018 Corvette Z06 vert- Black
To be tuned by JRE Racing
TBD performance
Old 06-13-2018, 08:08 AM   #19
Ricco
Ricco's Avatar
Drives: 2018 ZL1 Vert A10
Where are the pics??
Seriously, thats awesome.. Does it also fit behind the divider? So can you put it in the trunk and still put the divider up or does it need the 'divider mod'?
2018 ZL1 Vert - 854Whp / 791Wtq
2016 BRZ
2013 X5D
2005 STI
2001 2.5 RS
Previous cars in chronological order
2016 GT350, 2014 MEV Rocket, 2013 Nissan Qashqai + 2, 1.6L Diesel, 2010 Nissan Note 1.5L Diesel, 2012 Dodge Ram 2500 6.7L Cummins, 2009 Subaru Impreza STI, 2005 Dodge Ram 1500, 2004 Mini Cooper S, 1997 Subaru Impreza Catalunya special Edition, 1992 Daihatsu Charade GTti, 1978 Mk1 Ford Fiesta
Ricco is offline   Reply With Quote
Old 06-13-2018, 08:40 AM   #20
Drsagacity
Drsagacity's Avatar
Sorry. I left on a mini vacation and didn’t take the vert. Won’t be back until the weekend for pictures..
As of now, I clip the top two buttons for the divider and unbutton the two on the floor. I slid the wheel to the back seat and just let the divider hang down. No need for a divider mod..just let it hang.
TBD performance
Old 06-15-2018, 08:07 PM   #21
danbrew
Drives: 18 2SS A8
So, what do you use for a jack? How you gonna change that tire in when you’re 100 miles from nowhere?
danbrew is offline   Reply With Quote
Old 06-15-2018, 08:15 PM   #22
Vtor_ZL1
Who Needs to KNOW?
Vtor_ZL1's Avatar
Drives: 18 ZLE
Find a jack/spare setup from Cadillax CTS w 18" spare.
https://www.ebay.com/itm/CADILLAC-CT...8/123188795456
If you can find local boneyard w such a car, I bet you can get entire trunk kit for el-cheapo.
ing for grip.
http://www.motorsportsne.com/
Old 06-15-2018, 09:09 PM   #23
Drsagacity
Drsagacity's Avatar
It’s in the modern spare tire kit. Comes with everything you need.
TBD performance
Old 07-24-2018, 09:19 AM   #24
PNYKLR2
PNYKLR2's Avatar
Drives: 2017 Camaro 1SS Convertible
$20 and your done. If this tire kit can't get you back on the road then you should be calling for a tow anyways. Most of you should have insurance that provides coverage for this type of stuff already on your policy.
17' Camaro 1SS Vert - Plastidip for 50 Hp gain.
PNYKLR2 is offline   Reply With Quote
Old 07-29-2018, 01:46 PM   #25
Drsagacity
Drsagacity's Avatar
Geese, sorry. I completely forgot about this thread. I bought the modern spare kit that comes with the jack and everything you need. They also confirmed it will work on front or rear with no spacers for the SS.
I am taking my car into the shop this week and will probably try the spare on both front and rear just to verify.
TBD performance
Old 09-02-2018, 02:53 PM   #26
JoeGSr
Drives: 2017 LS Convertible
Bigger than I expected it to be. There is still a good 2-3 inches between it and the top when down.
JoeGSr is offline   Reply With Quote
Old 09-02-2018, 03:47 PM   #27
Drsagacity
Drsagacity's Avatar
I have the spare case with the jack and everything. Same deal, it has 2-3 inches between wheel and top when down.
TBD performance
Old 09-02-2018, 03:49 PM   #28
Cchief
Cchief's Avatar
Drives: 2017 Fifty 2SS Convertible
I went with non run flats and bought a ResQ 71-063-021 Pro+ Tire Repair Air Compressor it for $59.95 on Amazon.
Anyone interested in the run flats, let me know. I am keeping the Fifty wheels but will sell the OEM tires with 250 miles on them.
2017 2SS 50th anniv. vert.
2017 Jeep Laredo Altitude
2018 MB GLE350
Cchief is offline   Reply With Quote
