05-20-2019, 10:52 AM | #1 |
Drives: 2014 Camaro 2Lt RS Join Date: May 2019
Buying a 14 2LT, Anything in I should look for?
I am buying a 2014 2LT V6 with RS and Color Hud and 36k miles today and is their anything I need to look for? I have test driven it and all seems fine. In the passenger seat I thought I felt a slight hesitation during low speed shifts but did not feel it while driving. Oil on the dipstick was between marks. Are these LFX engines oil users like the 5.3's? We started looking for Mustangs and each and every on had issues like bad vibration, driveline clunk, and fenders popping out. These were 15's and 16's in the 20k mile range. The Mustangs all seem to have had bad evap cores on the A/C. Thanks just checking if I should be aware or look for something.
05-20-2019, 11:35 AM | #2 |
Drives: 2014 2LT RS Summit White Join Date: Apr 2017
I have the same basic car and it’s been reliable overall. Mine does not use oil between changes. I added a throttle controller because the stock throttle response is pretty laggy and might be what you noticed in the passenger seat. I bought mine two years ago with 19k and have 41k on it now. I had one issue with the key getting stuck in the ignition which is a fairly common problem with 14s and 15s and is either the auto shifter or the key solenoid. Mine was fixed under warranty. Other than that it’s been a great car.
05-20-2019, 12:39 PM | #3 |
Fast Cars and Old Guitars
Drives: 2015 2SS RS (L99, baby!) Join Date: Apr 2012
The other two cylinders? Welcome to the club and yes, we tend to have 'spirited discussions' from time to time regarding the V6 v V8. You'll like either one.
“I don’t want to belong to any club that would have me as a member.” - Groucho Marx
05-20-2019, 12:42 PM | #4 |
Drives: 15 2lt RS Top Gun Camaro Join Date: Mar 2019
My 2015 2LT doesn't use any oil with 60k on it. Problems so far is key getting stuck in the ignition, that's about it. I have read about people having trouble with the blend door for the HVAC breaking which is a expensive repair 1200-2200 dollars.
The most annoying feature on the car is the auto grade braking feature. If you live where there are a lot of big hills coming down grades if you are on the brake too long the computer takes over and down shifts the transmission(if its automatic) uses the engine to brake the cars speed down. I HATE THIS FEATURE because after its activated it doesn't let go right away even after coming to a stop mine has held it in the lower gears. I have found a way to turn it off but its a pain if you need to do it all the time. For some strange reason GM chose not to include a switch to turn this off like in the pickup trucks where you can turn it off. To turn it off in our cars you must put it in manual shift mode then back into auto mode after the incline. My car runs very well and gets 25mpg local driving, hard to beat that with a car that looks handles and runs this good on regular fuel. It is a blast to drive and is quick as anything else on the road. Last edited by 152LTRockin; 05-20-2019 at 01:12 PM. |
05-20-2019, 01:29 PM | #5 |
Drives: 2011 2SS/RS M6 Join Date: Oct 2015
05-20-2019, 01:33 PM | #6 |
6k, I have the service records on the car 1owner. The only repair was heater blower motor and I repaired the key problem myself.
05-20-2019, 02:34 PM | #7 |
Ok thanks everyone, the car is for my son so v6 no v8. Haha but I told him if the keys are gone take my truck. Last fun car we had was an 85 vette before kids.
05-20-2019, 02:44 PM | #8 |
05-20-2019, 02:58 PM | #9 | |
Drives: 2010 2SS Coupe; 2011 2LT Vert Join Date: Dec 2018
2001 5.7 WS6 TA brand new consumed a full quart 2003 5.3 tahoe brand new consumed half a quart 2005 5.3 silverado brand new consummed half a quart 2004 5.3 suburban 150k miles consumed half a quart 2008 5.3 yukon 215k miles consumes almost a full quart (still have it) 2011 5.3 silverado 165k miles consumed more than half a quart 2005 5.3 swapped 65 c-10 over 200k miles consumed more than half a quart 2010 6.2 Camaro SS 130k miles consumes more than half a quart (current DD) I looked at mustangs for my son's first car too and found that they were all in pretty bad shape as well. Everything I looked at was in the 80k-100k mile range and it seemed like the camaros held up much better (maybe that was my GM bias subconsciously affecting my decision though)
2010 2SS/RS LS3 - K&N, GM Performance Axle Back, Hurst Shifter, TSP 1 7/8ths long tubes no cats, TSP Stage 2 "Bald Eagle" cam, GM 3.91, 466whp/429tq
05-20-2019, 04:18 PM | #10 |
my 2015 2LT is a great car,no major repairs at 44,000 miles.a lot of fun to drive.you only need the V8 if you are going to race it.
05-20-2019, 06:25 PM | #11 | |
All my LS1 cars used ALOT of oil, 1 qt every 300-1000 miles depending how long the oil was in it. !st 2500 miles wasn't bad but after that not good. I noticed when we changed oil in this v6 Camaro there was a strong fuel smell but it didn't look diluted. |
05-20-2019, 07:02 PM | #12 | |
Drives: 2012 ZL1 - #670 Join Date: Jun 2009
05-20-2019, 07:27 PM | #13 |
I haven’t noticed mine doing that either, although both my Honda and Toyota do have that feature and it takes a little getting used to. Maybe it’s part of a tune?
05-20-2019, 07:45 PM | #14 |
Well I don't know what to tell you but the neighbor has a 17 and it does the same thing. You have to be on a steep incline and on the brake above 40mph. From the little info I could find there is a level indicator someplace in the transmission. The trucks have it too but they have a switch to turn it off. Its called grade braking, I can't find too much about it but if you have a auto trans you have it. Its too reduce the temp of the front brake rotors going down long steep grades. Trust me like everything else I can't help I notice things other people don't. It was the 1st thing I noticed about the car because we live at the bottom of a long steep grade in a valley. Also noticed this car goes up that grade better than ANY of the LS1 cars we owned. sorry if that makes you boil but its true, same with the fuel mileage, I keep good records. Its been 24-25 every time over the past 6k miles and since I started putting premium in its gone up to 27.
