05-19-2019, 08:55 PM | #1 |
Drives: 19 SS soon Join Date: Aug 2018
What are the best jack pads?
I have the ZL1 Addons magnet adapter and its slipping around a lot and I can't use any permanently attached things to the pinch welds due to illegal for autocross.
What other options have you guys found? |
05-19-2019, 09:16 PM | #2 |
Who Needs to KNOW?
I've been using this for while:
https://www.amazon.com/gp/product/B0162BSK0M Having magnets in there would be handy. It's sturdy, stable and "soft" edge so no damage.
ing for grip.
05-19-2019, 09:16 PM | #3 |
I have the zl1 add-ons magnetic unit and their companion plastic base which adapts to a jack pad. While they do slip a bit, they don't move under load. I imagine a little bit of silicone could be used to add some grip so they don't shift around as much before they are under pressure.
05-19-2019, 09:18 PM | #4 | |
05-19-2019, 09:19 PM | #5 | |
05-19-2019, 09:21 PM | #6 | |
05-20-2019, 07:58 AM | #7 |
Drives: 2018 Garnet Red 2SS Conv M6 Join Date: Apr 2008
Can someone point me to a thread that discusses this in detail. In particular, why are the convertibles different? How is that handled?
05-20-2019, 08:52 AM | #8 |
Drives: 20 1LE 2SS M6 Rally Green Join Date: Mar 2014
"the trouble with our liberal friends is not that they're ignorant; it's just that they know so much that isn't so.” Ronald Reagan - |
05-20-2019, 09:32 AM | #9 |
Drives: 2017 2SS M6 FIFTY @51fifft Join Date: May 2017
Get the ones from zl1's that stay on the car. I have them and they work great. Plus if you have to take the car in and they use a 4 pt lift you can tell them to use the jack points.
https://wildhammermotorsports.com/16...gaAk-SEALw_wcB
05-20-2019, 09:44 PM | #10 |
Drives: '18 Hotwheels 2SS Join Date: Jun 2018
If you have problems with slipping go to Dicks Sporting Goods and buy a couple of Hockey pucks. They are almost the perfect size. Put them on the jack and away you go.
05-21-2019, 12:57 AM | #11 | |
Drives: 2SS Hyper Blue Join Date: Jun 2018
Jacking thing w/pucks for lifting and then the pads for stands.
2018 Hyper Blue 2SS - SOLD
05-21-2019, 06:06 AM | #12 |
I jack with these (two jacks) and set it down on slotted pucks on the stands. Bring the front up evenly from both sides, then the rear from the pumpkin
