05-05-2019, 08:36 PM | #1 |
Drives: 23 2SS 1LE Join Date: Feb 2019
Which wires do I splice into?
Hey guys. Got my 2019 3LT Coupe and I am trying to add an LOC, my only issue is.... which wires am I supposed to splice into? I want the front door speakers for bass. I thought it was correct plug, but the wires do not appear to be the same as the other posts that I have seen.
Is it supposed to be the two wires that are slightly thicker than the rest? I believe that would be the red/yellow and black/white from what I can see.
Instagram: RideWithDanger
Radiant Red 23' 2SS 1LE 1100: 11/14/22 | BUILT: 3/16/23 2000: 2/17/23 | 4200: 5/8/23 3000: 2/27/23 | 5000/6000: 5/15/23 Black on black 2019 3LT RS Camaro. 1100: 3/7/19 | 4200: 4/15/19 3100: 3/15/19 | 4800: 4/23/19 3400: 3/22/19 | 5000: 4/25/19 Built: 4/8/19 | Home: 4/26/19 |
05-08-2019, 12:00 PM | #2 |
Kind of found out myself. So thanks to Gblaue, I learned the on this connector, the Red/Yellow and Black/White are power and ground. The other 3 sets are for the front door speakers, and one of the rear shelf speakers.
So, after a quick look at the easy to see rear shelf speakers I found the driver side rear shelf speaker is connected to the same harness, and found the right rear shelf speaker connected to the next harness over. Which left the front door speakers remaining. As of right now I do not know which is which, but I have made a quick diagram for the far right harness on the Bose amp for the 2019 3LT. Colors: Blue/white | Yellow | Blue | Red/yellow Grn/black | Yell/blk | Blu/blk | Black/white What they do: Rear L Shelf Speaker + | Front door + | Front door + | Power Rear L Shelf Speaker - | Front door - | Front door - | Ground Also if your curious as to the passenger side rear shelf speaker, you can see the wires in the first picture as well. Those are the far right side wires to the next harness over. White/black is + and Green/purple is -
05-20-2019, 01:17 PM | #3 | |
Drives: Lexus IS350, GX470, Nightrod Sp Join Date: May 2019
Also are these the wires that I can tap into to add a LOC for adding a sub and amp? Thanks |
05-20-2019, 06:23 PM | #4 |
Yes that is correct. I tapped into Blue/BlueBlack for one side, and Yellow/YellowBlack for the other.
05-20-2019, 06:34 PM | #5 |
05-20-2019, 06:38 PM | #6 |
Drives: 2017 ZL1 Convertible A10 Join Date: Aug 2017
Good luck getting any kind of decent audio of these 2019's ... f&*%ing GM ...
'17 White ZL1 A10 Convertible - TM ported TB - RotoFab CAI - 2.3" griptech upper pulley - Kooks 1 7/8" Headers with High Flow Cats - Borla S-type Catback - Audio Overhaul - NavTV M650-GM - 20" BlackDiForza- Michelin Pilot Sport4S - Tuned at BRC Raceworks (606rwhp/675trq)
'14 CTS-V Coupe - ZL1 lid - Ported TB - Ported Snout - AirRad CAI - 8.66" lower - 2.55" upper- Greenbelt - SW Headers - SW Catback - Varimax Intercooler Pump - Track Attack Intercooler-Tuned at BRC Raceworks (551rwhp/516trq) '17 Maserati Levante- STOCK |
05-20-2019, 08:04 PM | #7 |
If your using an Lc2i you wont need one, but if your using a different LoC there is a fuse you can tap into but I am not sure which one it is.
05-20-2019, 08:06 PM | #8 | |
I just learn to enjoy the music and not every little detail so much. As long as I can turn it up a bit without distortion and feel some bass, im good.
