05-01-2019, 08:54 AM | #1 |
Drives: camaro SS V8 45th 2012 Join Date: Jul 2016
how to run wire between motor/interior
hi all
i want to add Siren behind bumper, but i need to run a cable between the engine compartment and the passenger compartment didn't find this in this forum... did someone already dit it ? where is it possible to run the cable ? thanks |
05-01-2019, 09:14 AM | #2 |
Drives: 2016 Camaro SS Join Date: Jan 2019
I've never looked at this on the Camaro, but the hole in the firewall where the engine wiring harness is fed through has always been my go-to spot to feed wiring into the cabin.
2016 Gloss Black Camaro 1SS, A8, MRC, 6-Piston BBK
Whipple, LT4 fueling, AlkyControl, Kooks, Borla, Roto Fab, Mightymouse, aFe, Apex, C7 Carbon, etc... |
05-01-2019, 10:13 AM | #3 |
Drives: 18 ZL1 A10 Join Date: Nov 2008
Right under the master cylinder you will see a harness with a pretty big attached rubber grommet. make a hole in the grommet part and done. you will see the wire come out inside under dash by your left foot.
ZL1::J-E-T-S JETS JETS JETS |
05-01-2019, 10:18 AM | #4 |
Go to 11:30 in video
https://youtu.be/8RUidSZT6ns
05-30-2019, 02:58 AM | #5 |
delete the sund tube and go through there
08-19-2023, 11:42 AM | #6 |
Drives: 2019 Camaro SS Riverside Blue Join Date: Sep 2020
Ran across this old thread, but I have ran several wires, gauge wires, etc. through the sound tube at the firewall. Kept the small tube attached to the firewall that sticks out maybe 1.5 inches, deleted all the rest. Perfect access point to the cabin.
