08-24-2021, 08:07 AM | #1 |
Drives: 2014 2SS/RS 6SP Ashen Grey Join Date: Aug 2021
Emblem/Badge options need ideas
Hi All, Ashen Grey 14 2SS,
I was thinking of changing the front gold bow tie to a Black SS That fits into the same spot. The rear Gold Bow Tie I see they make Black or Matte Black overlays how do they fit/look and hold up? Which is the better of the colors? I am assuming Matte is a little flatter but I can't tell by the pictures. As far as the chrome looking Camaro on the fenders what are some good options there? Black SS? Camaro in Black? 6.2 in Black? Any help and links would be appreciated. Thank you
GM 3.91/TrueTrac OEM ZL1 Rims, Brakes & Side Skirts.ACST4 Splitter/Deflectors NPP M2W,GM Short Throw,Remote Clutch reservoir
GPI Ported Rod Mod,BO White PTB,CAI/JRE Scoop, Moroso Catch Can GC Aluminum DS Stainless Works Ceramic LTH/HiFlo Cats SCT X4 Dynosteve, Hotckis 1" Springs & Chassis Max Brace BMR Adjustable Swaybars,Trailing Arms, Adjustable Toe Rod, LCA & Z28 UCA Bushings Hendrix Solid Cradle Bushings Pedders Radius Rod Inserts Strut tower brace Hero Smoked Tail and 3rd Brake Light, Diode Dynamic SL1 Fog Lights AeroForce Dual gauge/Autometer pillar mount. Last edited by Joe.G; 08-26-2021 at 07:41 AM. |
08-25-2021, 06:10 PM | #2 |
The front, if you like it would do the Black SS, on the rear bowtie I have seen both matte and gloss ones. If your color is Ashen Grey, never heard of "Aspen" Grey, I think the gloss would look better, just would "accent" the rear panel better.On the fender badges, personally I like the "naked" look, but if you really want them there, go for the gloss black, would look pretty cool.. The "naked" fender look.. Nice and clean..
08-26-2021, 04:04 AM | #3 |
Drives: 2012 Chevrolet Camaro l99 Join Date: Aug 2020
I like the naked look as well
DSS FX Forged Pistons, Eagle ESP L19 Forged Rods, ARP Head and Main Studs, TSP PRC 260 CNC Ported Heads milled .030, Cometic .040 Head Gaskets, GPI SS3 VVT Camshaft, GM Performance Racing Lifters, CHE Trunnions , Molly Pushrods, Melling 10355HV Oil Pump, Cold Air Inductions CAI, Fast LSXR Intake Manifold, Nick Williams 103 TB, TSP 1 7/8" Longtubes with 3" TSP Exhaust, ZL1 Fuel Pump, Mishimoto Radiator, Mishimoto Oil Cooler, Tru Cool 40k Tranny Cooler, 3600 Circle D Converter, Fluid Dynamics Balancer
Build Thread https://www.camaro5.com/forums/showthread.php?t=609817 |
08-26-2021, 05:55 AM | #4 |
Drives: 2010 2SS/RS Inferno Orange Join Date: Mar 2013
I picked up a bowtie delete off eBay and then ordered this SS badge from Emblem Pros. It's made for the Heritage Grill, but I was able to drill two small holes in the bowtie delete for the studs on the back of the SS badge. Easy mod and you can choose your color.
U.S. Army Retired |
08-26-2021, 07:40 AM | #5 |
Any leads on a Decent rear Bowtie? I think I am going to leave the Fender ones off.
Ashen Grey is what I meant. Any tips on removing the fender decals?
GPI Ported Rod Mod,BO White PTB,CAI/JRE Scoop, Moroso Catch Can GC Aluminum DS Stainless Works Ceramic LTH/HiFlo Cats SCT X4 Dynosteve, Hotckis 1" Springs & Chassis Max Brace BMR Adjustable Swaybars,Trailing Arms, Adjustable Toe Rod, LCA & Z28 UCA Bushings Hendrix Solid Cradle Bushings Pedders Radius Rod Inserts Strut tower brace Hero Smoked Tail and 3rd Brake Light, Diode Dynamic SL1 Fog Lights AeroForce Dual gauge/Autometer pillar mount. |
08-26-2021, 02:54 PM | #6 |
On the rear bowtie, I painted mine myself with gloss black and clear coated it. Not hard to do, just tape it off, little sanding, primer then paint it. As for removing the fender lettering, they are metal, I used "Goo Gone" sprayed behind them and this fishing line, or dental floss works too. Let the Goo Gone soak in a bit to soften the adhesive, then use the fishing line/floss which ever and put it behind the letters and use an up and down sawing motion th remove them. Very easy. Then more Goo Gone on the adhesive and you can rub it off with your thumb. It will be sore when you get all done, but it will look great!! Here is a pic of my rear bowtie..
08-26-2021, 03:03 PM | #7 |
I even painted the SS lettering black..
08-27-2021, 09:07 AM | #8 |
Are the Red SS badges available in Black? I have seen some cheap knock offs but I am looking for a nice look and fit. I think I may leave emblems off the fenders, Black SS to replace the front gold bow tie and I am guessing a black/chrome rear bow tie.
I was thinking a Black SS to replace the rear bow tie but that may be to much with the other SS Back there, Unless I remove the little Red SS.
08-27-2021, 10:34 AM | #9 |
I made my own flow tie for up front. I think it gives a clean look to front. ZL1 grille, badge and lot of time. I removed the rear bow tie, IMO cleaner look with only SS badges. For the fenders I have the 2016+ Camaro badge.
08-27-2021, 04:09 PM | #10 |
Anyone have pictures of the back with the Bowtie removed? I am having a hard time find a Black Bowtie of decent quality.
08-27-2021, 04:44 PM | #11 |
It don’t come easy.
You can also do the rear bowtie with self adhesive vinyl. You can pick up the vinyl at any craft store. Mine is done with matte.
08-28-2021, 08:40 AM | #12 |
Hard to tell by yours, but on mine there is a recessed outline between the chrome and the gold ( the recess is gold ) looks like it would be a pain to get it in there. I would like to find a factory black one as I plan on having the car a while , My other Z28 I have had since 1995.I may leave it off but would like to see a picture.
08-28-2021, 05:55 PM | #13 | |
Drives: 2010 Camaro 2SS Join Date: Sep 2015
https://www.ebay.com/itm/38347919423...wAAOSwYghefG~B https://www.ebay.com/itm/17469255578...Cclp%3A2334524 https://www.ebay.com/itm/26502199148...IAAOSwleJgCUDS https://www.ebay.com/itm/25442867895...kAAOSw4pJd1iob https://www.ebay.com/itm/28351049746...EAAOSwxotc~BoH |
08-29-2021, 08:02 AM | #14 |
davesnever, Yes I saw those, I am looking for a good quality or OEM Black Bow Tie. I would like one the same size as factory one.
