01-09-2021, 03:52 PM | #1 |
Drives: 2013 2ss Join Date: Aug 2014
First differential and manual transmission service
2013 2SS, LS3, 6 speed manual
These are the lubricants I came up with. These are correct, right? And should I drain the old oil when the oil is hot or cold? |
01-09-2021, 07:02 PM | #2 |
Sporting Foole
Drives: 2010 Camaro SS Join Date: Sep 2019
Curious about the synchromax, just put Redline D4 in my trans. It doesn’t seem to be any better or worse than it was?
I’m going to service my diff soon. |
01-10-2021, 06:49 AM | #3 |
Drives: 2011 Camaro 2SS LS3 Whipple Join Date: May 2019
Yes those will work. I used redline d4, it helped a little with cold shift chatter. Rear i used the GM stuff. You may still want to add a little lsd additive to the rear if needed. Warm is as l is always best, will flow out easier.
Whipple 2.9 CAI ID1050x injectors ZL1 Pump JRE FPCM JMS Voltage booster JRE Rough Idle blower cam BTR .660 springs CHE trunnion kit 1 7/8 Speed Engineering Borla Atak JRE scoop 1.5" lowering springs BMR trailing arms and toe links Cradle inserts 704WHP 603WTQ 93 octane
01-10-2021, 08:14 AM | #4 |
Drives: 2014 2SS RS, 6 sp man Join Date: Feb 2016
Its been a few years since i changed mine but i though the Manual trans used ATF not syncro mesh with is heavier
01-10-2021, 11:24 AM | #5 |
On the synchromax is says that it is for manual transmissions that require atf.
01-10-2021, 11:26 AM | #6 |
Which brings me to my next question...
I don't fully understand the idea of a manual transmission using atf. Why doesn't it use gear oil? |
01-10-2021, 01:57 PM | #7 |
Drives: 2010 2SS/RS Inferno Orange Join Date: Mar 2013
The manual transmission was designed to use lighter weight ATF instead of gear oil. Using Redline D4 may help smooth out your shifts. It worked pretty well in my first LS3 Camaro.
U.S. Army Retired |
01-10-2021, 04:40 PM | #8 |
So, i drained out both diff and trans fluid.
Trans fluid looked as I would have hoped. Red and healthy looking. The proper quantity came out, so no leaks. Diff fluid looked a little sparkly (metal in there) and there was a little build up on the magnetic tip of the drain plug. Is this normal? I am tempted to do some kind of a flush. Fill up diff with 5w30 motor oil, spin the wheels by hand, then drain. Repeat a couple times. Good idea? |
01-10-2021, 08:12 PM | #9 | |
01-10-2021, 08:52 PM | #10 |
Finished up.
I bought 2 quarts of royal purple maxgear for this project. I used 1 quart to flush, 1 quart to fill. The flushed maxgear had some metal in it, so I consider it worthwhile. However, i would not continue to flush with more maxgear. |
01-11-2021, 05:38 PM | #11 |
01-28-2021, 11:27 PM | #12 |
Drives: 2014 2SS/RS Join Date: Jan 2018
I've been running both for a while. Really love the syncromax. Smoothed out the shifts pretty good
Sent from my SM-N986U using Tapatalk
2014 2SS/RS LS3/M6
01-29-2021, 05:19 AM | #13 |
Drives: 2012 Camaro SS Join Date: Dec 2019
Like stated some metal in the rear is normal wear and good as long as there is no chunks of metal. Personally when I “flush” my rear I do the change and drive it for 500 miles then change it again. It only takes a quart and is easy to change with ramps. The only hard part is getting in the ratchet to remove the fill plug with aftermarket exhaust.
2012 Camaro 2SS/RS - CSP Custom Cam 232/240 .615/.615 113 +3, Texas speed CNC heads, FTI billet triple disc converter, K&N cai, Katech ported TB, GPI Ported/rod modded manifold, Texas speed 1 7/8 headers, HFC, Flowmaster 2 chambers with x pipe, Mishimoto CC, MSD wires, Roto fab washer relocation, tru cool 40k trans cooler, apex scoop, Pedders extreme coil overs and much more!!
01-29-2021, 08:09 AM | #14 |
Drives: 2014 camaro SS Join Date: Jan 2019
it might remove some debris but I doubt much as it is not a solvent.
motor oil and any other liquid including water "IS" a solvent. what it can dissolve depends on what it is made of. |
