07-26-2018, 07:47 PM | #1 |
Drives: NFM 1SS Join Date: Jul 2018
Weird sound help
I took the Camaro for its 1st road trip yesterday and came back today. I noticed that from 62-69 MPH when I'm not on the gas (like when the cruise is set) there is a very loud noise coming from the car. It almost sounds like a semi is passing me. If I step on the gas the sound goes away or if I speed up it goes away.
I believe it to be an exhaust leak. My other thought was a tire, but that would seem odd because it's only from 62-69 MPH. What else could it be? |
07-26-2018, 09:58 PM | #2 |
Drives: 2018 HBM 2SS/1LE Join Date: Jun 2018
Any chance you have an auto tranny and NPP exhaust? If yes, any chance you pulled the fuse for the front valves? On C7 Vettes the car sounds like crap if the front valves are open in V4 mode.
2017 Admiral Blue Corvette Grand Sport Convertible
07-26-2018, 10:47 PM | #3 |
Yes it's an automatic. I bought the car used. I haven't pulled any fuses. I figured I didn't have NPP because there is no difference in exhaust note when I change driving modes.
07-26-2018, 10:58 PM | #4 |
Drives: Camaro 2SS & ZL1 Join Date: Mar 2018
General rule, Four pipes is NPP, two is not. Unless it has a different exhaust....
2017 Camaro 2SS A8 Bright Yellow NPP MRC
2023 Camaro ZL1 A10 Radiant Red |
07-26-2018, 11:44 PM | #5 | |
Drives: 2018 1SS 1LE, 2015 RAM Ecodiesel Join Date: Oct 2017
Doubt that is your noise though. Could be the differential too. Keep us posted if you figure out the noise. Can you pinpoint where the noise is? Is it a whine, a rumble, a squeal?
07-27-2018, 12:02 AM | #6 |
I only have 2 pipes, so must not be NPP. I also don't have a race setting. My settings make no difference in exhaust sound.
The sound is hard to describe. Like I first said it sounds like a semi is passing me heading in the same direction I am. I would say there is a little bit of rumble as there are some vibrations felt in the vehicle during this event as well. It's a 2017 1SS which I bought Certified Pre-owned, so it should be covered...whatever it is. I'll keep you updated after I get it into the dealer. |
07-27-2018, 12:13 AM | #7 | |
07-27-2018, 09:37 AM | #8 | |
When you hear the noise in cruise mode, does it go away if you accelerate? |
07-27-2018, 10:15 AM | #9 |
Drives: Camaro Join Date: Feb 2017
07-27-2018, 10:46 AM | #10 |
Drives: 16' 2SS, 06' Silverado SS Join Date: Jul 2017
im having this same issue but it happens when it shifts to 4th and at 45-50 mph and 70-75. sounds like rumble strips sometimes sometimes light vibrations and shaking. Im assuming it is the torque converter gone bad and you have the A8 Shudder.
taking mine in Monday. |
07-27-2018, 01:34 PM | #11 |
Drives: 2018 camaro ss Join Date: Jun 2018
You can narrow down the cause. Put your shifter in manual mode, progress through gears. Downshift once, or let your car downshift on its own. Until you go back in automatic mode AFM won't activate and you can replicate your driving conditions where you heard the noise/vibration before. If you still hear it, your problem isn't AFM related. If you don't, it's AFM related.
Before I got my AFM disabler I remember a nasty noise/vibration similar to what you're describing. It always seemed to happen RIGHT BEFORE the car would switch back to v8 from v4. Post-AFM disabler I haven't heard the noise. |
07-27-2018, 02:03 PM | #12 |
Drives: 2017 Camaro SS Join Date: May 2018
Any chance that what Op is hearing is from the sound tube under the dash.
07-27-2018, 03:52 PM | #13 | |
Drives: 6 on the Flo' Super Sport Join Date: Jan 2011
Sounds like it might be Automatic Trans shudder. Its a known issue with the 8 spd trans. |
07-27-2018, 04:54 PM | #14 |
