01-15-2018, 06:35 PM | #57 |
Retired from Car mfrs....
No idea of any change.
01-15-2018, 06:44 PM | #58 |
Don’t quote me on this as being good info, but in reading through a corvette forum (found it by searching about 8.6 firmware) it sounds like the latest revision is a resounding success, as well it won’t drain the battery and can be kept plugged in... pretty exciting news if all
is true. Last edited by Chutzpah; 01-15-2018 at 10:40 PM. |
01-15-2018, 06:52 PM | #59 | |
Drives: 16 2SS 6MT NPP MRC / 15 K1300S Join Date: Mar 2016
Rohana RFX-5 10/11, M/T 275/305, Eibachs, Hellwigs, Hurst SS, DMS LT4 SC 596HP/589TQ, DMS Low-side, Kooks 2LTs, MBRP Race, Rotofab, MMS CC |
01-15-2018, 06:53 PM | #60 |
18 ZL1 A10 Convertible
Drives: White ZL1 Convertible Join Date: Oct 2016
Mine cleared the CEL and turned off 4cyl mode it was awesome. No more light and or 4cyl mode!
2018 ZL1 Convertible A10 @ Kooks R&D. |
01-16-2018, 04:10 AM | #61 |
Drives: 2016 Camaro Convertible 2SS Join Date: Jan 2016
Okay, found the switch.
https://www.amazon.com/Tonsiki-Femal...y+afm+disabler I will order this through Amazon and the Disabler from Range to be sure I get the latest version (8.6). I will not be installing until spring...
2SS Convertible, MRC, NPP, A8, Garnet Red, Blk Bowties
GM CAI, Ported TB, Kooks Headers, E85 |
01-16-2018, 02:48 PM | #62 | |
I won't be able to wait for spring, so any weather above 40F and dry, I'm going to check it out. The good news is they think they've solved the nuisance issues. As well, they confirmed that version 8.6 will shut itself off when it see's the rpm go below a certain level (I believe 500RPM, I can't remember... Alzheimer's kicking in). I don't plan on buying a switch unless I have issues.... I'll follow up shortly with a review. |
01-20-2018, 03:23 AM | #63 | |
01-20-2018, 09:35 AM | #64 |
I ordered on Tuesday and got the Range on Thursday. They said on the phone this version won’t drain the battery. However, the box says to unplug, as it may drain the battery on some cars. I have to call them back on this....
I should be able to test it’s functionality tomorrow. |
01-20-2018, 09:52 AM | #65 |
That would be nice if you could leave it plugged in and it would shut off. Post your findings bud. Thanks
01-20-2018, 05:10 PM | #66 |
I was able to try out the newest Range AFM device.
01-20-2018, 06:03 PM | #67 |
Cool thanks for the update!
01-20-2018, 06:07 PM | #68 | |
01-22-2018, 08:52 PM | #69 |
Drives: 2016 SS Mosaic Black Join Date: Jul 2012
Overkill Auto Garage sells the Range stuff
01-26-2018, 12:13 AM | #70 |
Drives: 2017 Camaro 2SS Hyper Metallic Blue Join Date: Jul 2017
how do i know which version ill get? no where on anyones site does it mention firmware version. im about to bite but if i can save $20 from another vendor...hey 20 is 20.
