dave@hennessey
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Engine | Drivetrain | Powertrain Technical Discussions > V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6)
Old 09-17-2016, 11:11 PM   #1
Bo White
Bo White's Avatar
Drives: 2015 Summit White 2SS 1LE
halfway through my th400 swap
I've got the catback, heatshield, driveshaft, tr6060, clutch and clutch hydraulic lines removed. Used the grease pack method to remove the pilot bearing.
I'll get the TCI flexplate, th400 and stall installed tomorrow and mount the B&M cooler and Pro Ratchet shifter. I'll measure for my driveshaft and cooler lines. So far the only issue I've ran into is the GForce driveshaft adaptor has the wrong bolts for the hub on the diff. Sent 12x1.75 bolts, needs 12x1.5
Retired wanna be cylinder head porter
2015 2SS 1LE Clutch reservoir, Vararam DRX, ported TB, TSP 2" headers, MGW shifter
Totalled:
2010 1SS Wilkes Performance/Eagle 416 shortblock, TSP custom valvetrain, PRC 260 heads, Edelbrock Pro Flo 102, th400 swap, 8" PTC 5500 stall= 535/435 at the wheels tuned Gen 3 Performance and Dyno 10.97 @ 124 full weight in 3100 DA CamaroFest X
Bo White is offline   Reply With Quote
Old 09-17-2016, 11:19 PM   #2
WVracer
WVracer's Avatar
Drives: '11 2SS/RS LS3 M6 (Sold)
Looks Good! Who built your TH400?
2011 IOM 2SS/RS LS3 M6- Injen CAI, TSP 1 7/8” headers, PTB, Hurst short throw, Corsa catback exhaust, 20" TSW Nurburgrings, BMR lower control arms, BMR tunnel brace, Hotchkis lowering springs. 3660lbs. Tuned by me (sold)
2010 RJT 1SS/RS LS3 M6- CAI, TSP 2” headers, TSP F-35 cam, PTB, Hurst short throw, Dronemaster catback, BMR lowering springs, Kirkey seats, 20”/18” Weld Belmonts, 3550lbs.
WVracer is offline   Reply With Quote
Old 09-17-2016, 11:33 PM   #3
Bo White
Bo White's Avatar
Brian Prince
Totalled:
Old 09-18-2016, 01:13 AM   #4
JD_Alaska
JD_Alaska's Avatar
Drives: 2013 Camaro SS Coupe L99
Looking great!!! I want to do this ��
JD_Alaska is offline   Reply With Quote
Old 09-18-2016, 09:51 AM   #5
frankwjr
frankwjr's Avatar
Drives: 2010 SS 2SS M6
Enjoy the t-400...I rebuilt one myself about 20yrs ago in the basement...full manual reverse valve body with stepped up pressure...put it in a '74 Olds Cutlass!!! with 9in, detroit locker and 3.55...broke the rear lose every shift...should be absolutely awesome in your car and next to bullet proof...wats ur converter set to stall at?
2010 SS 2SS M6 - Tune by RDP dynoSteve!(Woot) - Daily Driver - 150K! - All work by me...
frankwjr is offline   Reply With Quote
Old 09-18-2016, 10:21 AM   #6
Bo White
Bo White's Avatar
3500ish with 4.10s
Totalled:
Old 09-18-2016, 12:58 PM   #7
Bo White
Bo White's Avatar
5"x9" aluminum plate will mount my shifter and cover the hole in the floorboard.
Totalled:
Old 09-18-2016, 05:40 PM   #8
Bo White
Bo White's Avatar
Starter has to come off to bolt the stall to the flexplate.
Have to modify the xmember.
Totalled:
Old 09-18-2016, 10:50 PM   #9
Bo White
Bo White's Avatar
Weight reduction.....
Totalled:
Old 12-20-2017, 10:41 AM   #10
RaiderSS
RaiderSS's Avatar
Drives: 2010 Camaro SS2 DeadBLK
How did you get the shifter cable to not interfere with the traction control button sitting flush?
RaiderSS is offline   Reply With Quote
Old 12-28-2017, 08:01 AM   #11
Bo White
Bo White's Avatar
I didnt on mine but I did on my buddys build. Its a mix of centering up the cable between the button and lighter and trimming. His turned out great.
Totalled:
Old 12-31-2017, 08:57 PM   #12
RaiderSS
RaiderSS's Avatar
I have the stealth ratchet on my 4L80 swap and had to relocate the traction control button... I then disassembled another traction control selector module and just used the top portion to close the hole.
Old 12-31-2017, 11:35 PM   #13
Bo White
Bo White's Avatar
Once its centered right and some trimming done it fits. You just have to stick with it.
Totalled:
Old 01-09-2018, 12:13 PM   #14
hillshooter
Drives: 2015 Camaro SS commemorative
is this project done? Does your speedo work? if so what did you do to make it work?
2015 Camaro SS, LS3 Stroker, PRC heads,CUSTOM CAM. AGP 68/68 with custom Hot and Cold side. Fore triple pumps, Holley terminator X. BMR drag suspension with carlyle brake kit. 15" ET drags and 17" skinnies. ZL1 3.73 gears , aluminum driveshaft. TH400 with circle D converter.
hillshooter is offline   Reply With Quote
