Vararam
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Technical Camaro Topics > Camaro Issues / Problems | Warranty Discussions | TSB and Recalls
Old 07-07-2013, 02:06 PM   #1
Bigshoe
Drives: 2010 Camaro SS
2010 Camaro SS starts but dies
Bought rolled over 2010 Camaro SS. going to make street rod out of it.
Have had car running several times but now it starts then dies immediately.
Car has boral exhaust without cats. but has place for cats and ar eplugged in.
Not sure but think it has some sort of a ECM flash for it to run.
New battery good ECM voltage 14.
Have to clear P1516 and P2119 on code reader for it to start.
Fuel pressure 58 psi.
Spent several hours yesterday on internet with chevrolet answer expert and he finally said the ECM needed to be changed.
Does anyone have what all of the "live data readings" should be.
Or can someone help me with the start - die problem
Bigshoe is offline   Reply With Quote
Old 07-07-2013, 02:13 PM   #2
The Stig
knows 2 facts about ducks
The Stig's Avatar
Drives: ...and they're both wrong
The ECM may need to be flashed back to stock.
How long does the engine idle before dying?
Click to view my build thread
The Stig is offline   Reply With Quote
Old 07-07-2013, 02:36 PM   #3
429
Drives: 2010 camaro ss
VATS. Reprogram your key module
429 is offline   Reply With Quote
Old 07-07-2013, 02:49 PM   #4
rozay
rozay's Avatar
Drives: camaro 2LS LFX A6
Try leaving your key on the on position for 2 hours and then turn off then insert ket and turn it on and see if itll fix it. I did this with my vw gti and it worked
Niche 20x10.5, BMR 1.25 springs, GFX splitter,1LE Diffuser w/ 3.5 quad tips
rozay is offline   Reply With Quote
Old 07-07-2013, 06:54 PM   #5
Chevrolet Customer Svc
Chevrolet Customer Svc's Avatar
Drives: GM Vehicles
Bigshoe,
Sincere apologies to hear about your car starting and dying. Let me know if you'd like an official diagnosis at your local dealer. I can help orchestrate and oversee the visit on your behalf, otherwise keep us updated on if the concern gets fixed.
Sincerely,
William R.
Chevrolet Customer Care
For information on the GM Privacy Statement, please visit http://www.gm.com/privacy-statement.html
Chevrolet Customer Svc is offline   Reply With Quote
Old 07-19-2013, 08:00 AM   #6
Bigshoe
Immediately after if fires
Old 07-19-2013, 08:01 AM   #7
Bigshoe
I tried the 2 hour but didn't help
Thanks
Old 07-19-2013, 08:03 AM   #8
Bigshoe
Running without cats so don't really want to go back to stock.
Iy has ran with this set up
Thanks for the help
Old 07-19-2013, 08:05 AM   #9
Bigshoe
Originally Posted by Chevrolet Customer Svc View Post
Bigshoe,
Sincerely,
William R.
Thanks William,
This not really a Chevy issue it is me trying to make a hot rod out of a rolled over Camaro SS.
Old 04-04-2019, 10:43 PM   #10
RaiderSS
RaiderSS's Avatar
Drives: 2010 Camaro SS2 DeadBLK
What was the fix for your issue?
RaiderSS is offline   Reply With Quote
Old 04-04-2019, 11:26 PM   #11
Blueovalman
Blueovalman's Avatar
Drives: 2012 V6 Camaro 2010 Camaro SS
Question
Ditto how did you fix this issue??
Mr. Clean
Blueovalman is offline   Reply With Quote
