05-25-2019, 10:24 PM | #15 | |
HP tuners will read E content.
2018 ZL1-NFG-A10
New Iron L8T 9.32 147MPH |
05-26-2019, 06:59 AM | #16 | ||
First being to gain fuel system range then more air flow. Power Through Efficiency. I do not think I will mess with the stock blower so many have already gone that route and I believe the blower is just too small to achieve the air flow I am looking for. I will likely move to a larger blower which one is still up in the air right now. Power through Efficiency! Ted.
www.jannettyracing.com
05-26-2019, 08:07 AM | #17 | |
Drives: 2017 ZL1 Join Date: Jun 2018
Kooks full exhaust, Roto Fab, Whipple,Williams 103, Fore innovation, JRE cam and tuning
05-26-2019, 08:42 AM | #18 |
Today would be whipple and magnuson I have run both on my 2016 and done lots of builds with both very hard to choose one over the other so it becomes personal preference on looks.
I am looking forward to the TVS 2650 from Magnuson. Ted.
05-26-2019, 08:56 AM | #19 |
SABIO
What about a non E85 option? If a client does not have access to it, how would it change the numbers? 20hp less? 30hp less?
Or would you do something different for a non E85 build?
05-26-2019, 09:37 AM | #20 | |
About 50 RWHP less on 93 octane, most cars are making 620 RWHP on this package. Still with major gains in torque due to Throttle staying open, I talk about this quite often in my videos. Ted.
05-27-2019, 06:49 PM | #21 |
Drives: 17 ZL1 4300 03/16/2017 Join Date: Dec 2016
fuel used to cut the e85
Ted,
I am using 91 octane to cut my e85. How critical is the choice of fuel used to cut the e85. Am I leaving a ton on the table? Does the octane rating of the cutting fuel show up in your timing tables or does the ethanol content allow all the timing that is needed?
2017 ZL1 Coupe, MBM, A10, PDR, CF Hood Insert, ZL1 matts, 50th Anv. Indoor Cover
05-28-2019, 09:36 AM | #22 | |
2016 NFG 1SS A8
05-28-2019, 09:54 AM | #23 |
Not sure where you found that chart but its very cool to take a look at the differences. Thanks for posting that.
05-28-2019, 09:55 AM | #24 |
Excellent info!!!
2018 ZL1-NFG-A10
05-28-2019, 09:59 AM | #25 | |
So if you are cutting E-85 with higher octane fuel I belive you end up with a better fuel. Ted.
05-28-2019, 10:51 AM | #26 |
Ted and KingLT1,
Thanks for the good replies.
05-28-2019, 12:30 PM | #27 |
I believe the C85 VP is cut with MS109. That's about 450.00 for 55 gals.
05-28-2019, 12:36 PM | #28 |
SABIO
Way up here. No E85 unless you buy a barrel.
Choices are straight 91 with No Ethanol (Shell) or 94 with up to 10% ethanol (Sunoco) I would surmise both would be pretty much equal. Maybe the edge to the 94 with ethanol. I read somewhere that ethanol could lower the octane rating by 1 or 2 points? Would the 94 work for a 93 octane tune?
