08-13-2018, 02:37 PM | #1 |
Probably tired right now
Drives: 1Lap1LE | EV6 FE | 18 F150 Join Date: Sep 2010
What Nitrous controller are you running for your plate setup?
...and why?
-Seven
'17 SS 1LE - 1LAP 1LE (Now with more 427!) '18 F150 Platinum Powerstroke diesel '22 Kia EV6 First Edition '18 RS3 (1 of 2) Cumulus Blue '24 911 T (ordered) Formers... '19 RS5 Sportback Sonoma Green | '07 Cayman S 6MT | '16 Audi S3 Prestige Viper Green (APR Stage 3+) | '19 Mustang Shelby GT350R | '17 SS 1LE MBM 575whp all-motor |
08-13-2018, 03:21 PM | #2 |
Drives: Camaro 17 SS Join Date: Jan 2017
I use holley dominated now. But I used the NX window switch because it is fast accurate and reliable. Lots of window switches but with the addition of features comes the chance for that feature to fall.
08-13-2018, 04:31 PM | #3 | |
I'd like a switch panel for arming/warmer/remote opener I don't think I'd need much else, would basically be for 1/4 and the occasional roll race.
-Seven
08-13-2018, 04:41 PM | #4 |
Drives: 17 SS a8 Join Date: Feb 2010
I am using the one built into the megasquirt, it would probably only be worth considering if you have other bigger plans down the road.
it includes window switch, wot switch, boost builder(spray until xx boost is reached), 2 stage, progressive, wet or dry(only dry if you have port injection), bottler heater control and pressure monitoring.
best et 5.83@121 with the 5.3 http://www.camaro6.com/forums/showthread.php?t=465472 |
08-14-2018, 08:44 AM | #5 |
Drives: 2017 Camaro SS 2SS Join Date: Jun 2017
I'm using the Nitrous outlet winmax controller. Read a ton of reviews on it and their customer support was on point. Its also capable of doing multiple stages, which I liked.
08-14-2018, 09:44 AM | #6 |
Then keep it as simple as possible. The NX switch has full and accurate control. And I agree that having the opener and whatnot on a panel will ensure reliability, which is the main downfall of nitrous.
08-14-2018, 11:10 AM | #7 |
I suppose I should find out if I need standalone fuel control... Car will be making about 520-550whp N/A and then I'd like a 150 shot on top, so I think I'd be out of fueling
-Seven
08-15-2018, 07:26 AM | #8 | |
2016 loaded 2SS
Drives: Maverick X3 Turbo R Join Date: Feb 2015
I think the factory fuel system should be able to handle this; with a boostapump.
08-15-2018, 12:42 PM | #9 | |
I'd like to stay away from boost-a-pump/voltage boosters and just buy a skidmark fuel pusher system if need be.
-Seven
