08-12-2018, 04:31 PM | #15 |
Drives: 2016 camaro 1ss Join Date: Jan 2016
I have the same issue with my 416. I can’t do 2nd or 3rd gear under high RPM.
What clutch do you have? My clutch pressure always feels the same and fluid has been flushed 2x recently.
2016 1SS (M6) Kooks headers and exhaust, pray ported MSD/TB, JLT CAI, JLT catch can, TSP heads/VVT-2 cam, E85, Centerfirce clutch, g force axels and DS, most of what BMR makes, blah blah blah
08-12-2018, 04:52 PM | #16 |
Drives: 1987 Buick Grand National Join Date: Mar 2016
You both might want to check the install on the clutch. There could be too much clearance between the HRB and the clutch.
08-12-2018, 05:32 PM | #17 |
So I spent a lot of time on the googleand I have a few things that could be doing this. Throw out bearing, pilot bearing, weights on clutch are too much making it not disengage at high RPM, the “clutch pressure relive valve” plunger thing.
Opinions?
08-13-2018, 02:57 AM | #18 |
Drives: 2002 Camaro SS Join Date: Jun 2012
Subscribing for the answer
2017 1SS Hyper Blue M6
2001 Ford Lightning |
08-13-2018, 03:33 AM | #19 |
I had this issue a while back. I fixed mine by machining a .05 spacer to set between the slave and transmission faceplate and bled the system out till there wasnt a single air bubble. Shifted perfect thereafter.
08-13-2018, 03:54 AM | #20 |
Drives: 2016 Camaro LT1 RS Black on Black Join Date: Apr 2017
This is sounding right online. I also would check the tune. Hardware does seem to be at the center but it also could be a misalignment in the computer with the rev matching section of the new transmissions.
NowAChevyGuy 2016 RS - Trifecta Tuned, 3.23 diff swap, Borla S Type, JMS Throttle Controller, Lambo doors, Monster stereo, GM LED rear tail lights, BMR swaybars/End Links/Trailing Arms, tinted dark and murdered out.[/br] Car kicks ass! $20k.. and I get 20mpg with my foot in it, everywhere I go!.... Say somethin about V6's now... |
08-13-2018, 06:59 AM | #21 |
My car was being datalogged and we couldn’t find anything weird. I don’t see how rev matching would effect and up shift at high rpm
08-13-2018, 07:23 AM | #22 |
Drives: 18 Silverado 1500 Join Date: Dec 2015
I'm sorry to hear that this is happening to you OP! All I keep thinking about is that I'd need to re-mortgage the house to pay for all this! LOL Definitely hoping that you get it all sorted out soon, because that car is going to be a beast!
08-13-2018, 08:33 AM | #23 |
Drives: 2017 SS 1LE Mosiac Black Join Date: Nov 2016
Sounds like this could be the issue. OP, have you discussed this problem with any of the clutch/transmission companies (Monster, Centerforce, RPM, etc) or maybe a good cali shop like CMS?
Frankenstein Engineering Dynamics Stage 1 H/C/E85 536HP/488TQ |
08-13-2018, 01:48 PM | #24 |
Drives: 2017 2ss, m6 Join Date: Jan 2017
You both need to get back in there and check/set the release bearing to pressure plate clearance. It sounds like you are not getting 100% release and the continued drag is overpowering the synchronizers, and it just grinds away. Continued operation like this will eventually wear out the synchros and require a transmission repair.
08-13-2018, 02:37 PM | #25 | |
Drives: 2017 SS 1LE, 2016 1SS (previous) Join Date: Apr 2016
What is going on sounds clutch related, though. How is shif effort? What clutch setup are you using? Flywheel machined? Sounds like the clutch isn’t disengaging enough. |
08-14-2018, 12:48 PM | #26 |
Drives: 2017 ZL1 and 2018 SS 1LE Join Date: Oct 2015
Car is at the shop let’s see if they find anything
08-16-2018, 01:20 AM | #27 |
did you put better fluid in it?
Thread Tools | |
