08-15-2018, 02:36 PM | #57 |
Drives: 2018 ZL1 A10 Join Date: May 2017
It looks like that but with half chopped off. Haha. I talked to ADM and they are sending me the right hose.
08-15-2018, 09:03 PM | #58 | |
Drives: Anything I want Join Date: Oct 2008
So for the mix up |
08-15-2018, 10:33 PM | #59 |
Drives: ZL1/335i Join Date: Apr 2014
08-16-2018, 03:23 PM | #60 |
Drives: 2018 ZL1 Join Date: Aug 2018
I have what I hope is not too silly a question. Is the cavitation issue a track-only issue based on the coolant heating up, or do the cars experience the issue even as a daily driver? In other words, did those of you that put the reservoir on do so because you track your ZL1s or did you do so because it just makes sense to do so to avoid the cavitation issue altogether?
08-16-2018, 03:31 PM | #61 |
Drives: 2013 ZL1 and 2019 Ram Laramie Join Date: May 2017
A reservoir facilitates expelling air in the system and topping off fluid as it is at the highest point in the system, track or street.
08-26-2018, 05:33 PM | #62 |
Drives: Red hot ZL1 A10 2017 Join Date: Nov 2016
Received from ADM last week
Everything perfect. Put it today, had to change the position of the elite catch can. -intercoller reservoir aft original position -catch can between rotofab and réservoir (Had to modify a little bit the fixation and run the out pipe in the front instead of the back of the LT4) Didn’t use all the pipe, made it simple Didn’t disconnect the intercolling pump pipe Used the OEM, used a part of the pipe shipped as an extension Kept all the connections Super easy, if you keep the pipe high you won’t have coolant leak I had just a few drop when disconnecting and reconnecting... Pictures to come I did that mod because next year I will go back to France, there is no Chevy dealer, I want to check my level and make sure pump is not cavitating I have no tool to add coolant under pressure. With this tank : super easy Recommend |
08-26-2018, 05:38 PM | #63 |
For ADM perf:
Which level do you recommend in the reservoir? 3/4 Upper pipe top level? Full? Tx |
08-26-2018, 06:48 PM | #64 |
3 mods:
-rotofab CAI dry, -Intercooler additional reservoir, -Elite 2X dual catch can. |
08-27-2018, 04:30 AM | #65 | |
Drives: Grandad's C2 L89 Join Date: May 2017
One question; Is that an Elite bracket or did you fabricate it? Thanks in advance.
2018 ZL1 1LE sw/PDR
08-27-2018, 06:46 AM | #66 |
Tx
I thought about CC on the rotofab But there is less clearance below to drain because of the AC pipe. (AC line on the side mid engine, Moving into close to the CAI) Plus the side of the rotofab has an angle (Should have worked an homemade fixation except if you accept the CC to have this angle what I didn’t for the look...) Yes the bracket is from Elite (Just worked dremel a little bit as you can see to clear the second bolt on the bar, and add extra clearance for the AC pipe because I wanted CC to be closer to the side to clear the cooling line of the new reservoir). |
08-27-2018, 07:32 AM | #67 |
08-27-2018, 08:05 AM | #68 |
08-27-2018, 08:14 AM | #69 |
Drives: 2016 Challenger Hellcat, 2018 ZL1LE Join Date: Dec 2009
For some reason, I’m still on the fence on getting this. I’ll probably only track the car 2 times a year. Is it still worth doing?
2018 ZL1 1LE/Red hot 2019 Shellby GT 350R/ Oxford white/ Matte Black Stripes/ Carbon Fiber Dash/ Electronics Package #413 |
08-27-2018, 08:51 AM | #70 |
