Old 08-13-2020, 01:05 PM   #1
swisstyphoon
Former GM Technician
swisstyphoon's Avatar
Drives: 2018 ZL1 A10, 06 Silverado Duramax
Magnuson 2650 pulley chart?
Hi
I will order a Magnuson 2650 for my ZL1 soon.
Is there a chart for pulley vs. boost out yet?
Maybe you guys that own one can post their upper, and lower size, belt length/partnumber, and boost level to help others pick the right parts.
What boost level is recommended having a JMS Voltage booster only? Currently have a 15% lower, what upper do I need with the 2650?
2018 Camaro ZL1 A10
Rotofab Big Gulp, Nick Williams 103, Magnuson 2650, 9.17" (14%) lower, 90mm upper, Vengeance Racing Heads (LME) Cam Package (Cammotion Stage 1), Johnson Lifters, JMS Voltage Booster, Lingenfelter high flow check valve, BBK shorty headers, Custom 2.75" down pipes, Gesi Gen2 high flow cats, MM catch can 791whp, 772ft-lbs SAE
Just added 30% XDI Injectors, LPE big bore hpfp, Flex fuel.
Elite tuning, results coming soon.
2006 Silverado Duramax Diesel
MPI Compound Turbo
40% over Injectors
Efi Live DSP5 Tuning
Follow me on Instagram: Swisstyphoon1980
swisstyphoon is offline   Reply With Quote
Old 08-13-2020, 03:46 PM   #2
IneedAZ
IneedAZ's Avatar
I will be using a 90mm with a 15% lower. For fuel, I'm adding the dsx aux pump and Lingenfelter high flow check valve, lastly cam with 38% lobe.
Old 08-13-2020, 05:41 PM   #3
laynlo15
laynlo15's Avatar
Drives: 2022 Lt1 A10
Not sure but I've run 75 to 90 so which one do you need to know about? I ran all mine with a stock lower.
Old 08-13-2020, 05:50 PM   #4
laynlo15
laynlo15's Avatar
I didn't get a chance to run the 70 mm because I didn't have enough fuel system to handle 20-21 psi of boost, the 75 mm is about 17-18, 80 is about 13-14. The 90 about 8-9 on. I didn't have a chance to run an 85 because we had none available when I put my 2650 on. Much depends on the header size, cats no cats, cam, ported heads or not. Elevation, Etc. So I'm trying to say your results may vary. I would order any additional pulleys from Griptec and not from Magnuson. Its only because once you get to higher boost the grip tech is not going to slip.
Old 08-13-2020, 05:52 PM   #5
laynlo15
laynlo15's Avatar
I would stay with the 90mm since you have a larger lower. You will probably be 13 psi with the 90 and 15% lower. Buy a boost gauge or have HP Tuners to data log to know exactly what your boost is.
Old 08-13-2020, 09:07 PM   #6
ExorsistzL1
ExorsistzL1's Avatar
Drives: 2018 zl1 10 speed
Whats interesting is i 1st ran 80mm and stock lower and was seeing 19 to 21lbs i went to 85mm and still hitting 17 to 18 . I currently have texas speed heads 19 zr1 cam 2650 with 103 nick williams TB AR headers cattless x pipe alky meth DSX low side aux fuel 93 im about to put a cam with 38% lobe so ill drop psi and get off the methanol. ( worried about pump failing on WOT) The kit came with 90mm but i think ill stay with 85mm and hope im around 13 to 14lbs
ExorsistzL1 is offline   Reply With Quote
