08-19-2019, 11:39 AM | #1 |
Former GM Technician
Drives: 2018 ZL1 A10, 06 Silverado Duramax Join Date: Sep 2009
Need wiring diagram
Hello yall
I just imported my 2018 ZL1 to Switzerland. Preparing it now for the inspection at the DMV over here. We have to have headlamp washers with Xenon lights. Now I have to hook up the new pump. I want to install it, so it only sprays when I have the low beams on. Can someone send me a wiring diagram of the lighting system, and the one for the power distribution please. Thanks alot in advance. Greetings from across the pond.
2018 Camaro ZL1 A10
Rotofab Big Gulp, Nick Williams 103, Magnuson 2650, 9.17" (14%) lower, 90mm upper, Vengeance Racing Heads (LME) Cam Package (Cammotion Stage 1), Johnson Lifters, JMS Voltage Booster, Lingenfelter high flow check valve, BBK shorty headers, Custom 2.75" down pipes, Gesi Gen2 high flow cats, MM catch can 791whp, 772ft-lbs SAE Just added 30% XDI Injectors, LPE big bore hpfp, Flex fuel. Elite tuning, results coming soon. 2006 Silverado Duramax Diesel MPI Compound Turbo 40% over Injectors Efi Live DSP5 Tuning Follow me on Instagram: Swisstyphoon1980 |
08-19-2019, 11:56 AM | #2 | |
Can't you get around this requirement by installing a lower output HID bulb? That headlight washer will very likely look a bit, hm, homegrown... no offense, I just don't see how it can be done well with such a low profile recessed unit as ours. (The EU and its idio[syncra]tic regulations... but I won't digress now )
08-19-2019, 03:22 PM | #3 | |
Thanks Maybe I could, but then I would have to get that light output certified, that shows that the output is below 2500 lumens. That document would cost me way more than a whole washer kit. I found one that is actually not looking all to bad.
2018 Camaro ZL1 A10
08-19-2019, 04:31 PM | #4 | |
Actually, this one doesn't look bad at all, I underestimated the aftermarket a bit .
735 rwhp | 665 rwtq Magnuson TVS 2300 80mm pulley | Kooks 1 7/8" LT headers | JRE smooth idle terminator cam | LT4 FS & injectors | TSP forged pistons & rods JMS PowerMAX | DSX flex fuel kit | Roto-Fab CAI | Soler 95mm LT5 TB | 1LE wheels | 1LE brakes | BMR rear cradle lockout | JRE custom tune 1100 - 1/30/18 | 2000 - 1/31/18 3000 - 2/06/18 TPW 2/26/18 3400 - 2/19/18 | 3800 - 2/26/18 4300 - 2/27/18 | 4B00 - 3/01/18 4200 - 3/05/18 | 4800 - 3/14/18 5000 - 3/16/18 | 6000 - 3/19/18 Last edited by arpad_m; 08-21-2019 at 07:38 AM. |
08-20-2019, 12:01 AM | #5 | |
Awesome thank you! I just need to find a suitable power source that provides + with the ignition on. And I would also need the scematics for the windshield washer. Will use the same switch for the headlamp washer.
2018 Camaro ZL1 A10
08-20-2019, 08:19 AM | #6 | |
735 rwhp | 665 rwtq Magnuson TVS 2300 80mm pulley | Kooks 1 7/8" LT headers | JRE smooth idle terminator cam | LT4 FS & injectors | TSP forged pistons & rods JMS PowerMAX | DSX flex fuel kit | Roto-Fab CAI | Soler 95mm LT5 TB | 1LE wheels | 1LE brakes | BMR rear cradle lockout | JRE custom tune 1100 - 1/30/18 | 2000 - 1/31/18 3000 - 2/06/18 TPW 2/26/18 3400 - 2/19/18 | 3800 - 2/26/18 4300 - 2/27/18 | 4B00 - 3/01/18 4200 - 3/05/18 | 4800 - 3/14/18 5000 - 3/16/18 | 6000 - 3/19/18 Last edited by arpad_m; 08-21-2019 at 07:39 AM. |
08-21-2019, 04:19 AM | #7 | |
Thanks alot! Saved both diagrams Yes we have all the bells and whistles.. lol
2018 Camaro ZL1 A10
